Question about Poulan Garden
I need fuel line diagram on craftsman chainsaw 36cc 358-350-460
  • 376 Answers
SOURCE: I need the fuel mix ratio for a Craftsman 36cc
40:1
Posted on Jul 02, 2009
dontbother10
  • 2220 Answers
SOURCE: Diagram of fuel line for Craftsman 16" chainsaw
Your saw is a Poulan. Try converting the cc to a model number. A 2.2cc Craftsman is often a Poulan model 2200. go to this link and find something that appears the same under (POULAN-WEED-EATER).
http://www.ordertree.com/cms/illustrated-parts-list/9788.html
The IPL will help. Pay attention to the year there is a different area for older saws.
For a current saw Craftsman should have something available.
Posted on Sep 04, 2009
dontbother10
  • 2220 Answers
SOURCE: what fuel lines go where on a craftsman chainsaw
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly. HTH
Lou
Posted on Nov 02, 2009
Testimonial: "Hi Lou. I did have it backwards. I will change it to what you have and hope it works. Thanks, MIKE"
dontbother10
  • 2220 Answers
SOURCE: I have Craftsman 36cc 16in Model-358-350461no oil to the bar.
We are prohibited from contacting you directly.
Oil System Plugged:
1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution.
• Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out.
• Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability).
• Start the saw and see if it oils when revved up (oozes down side of saw).
• If yes reassemble your saw. If no, continue with 2.
2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go.
• Carefully check the hoses for cracks especially at bends and connections.
• If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread).
• Please make extensive notes & some digital pictures will help during reassembly.
3. If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL for the location).
The IPL (exploded parts list) for your saw is the only detail for the oil system, it is sketchy at best. Oiler components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly:
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=358350461&productCategoryId=1503220&brandId=0247&brandDescription=CRAFTSMAN&modelName=CHAINSAW&diagramPageId=00001&componentDescription=CHASSIS%20BAR%20CHAIN&documentId=P0205138&blt=06
It appears to have an outboard clutch, this will be helpful;
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make certain the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 11, 2010
  • 4088 Answers
SOURCE: how to change fuel lines on craftmans 36cc chainsaw
The best way is to change only one at a time. There are many folks on here that removed everything, then couldn't remember where the lines went. Use original lines, not plastic. Check your work by trying to pump fuel into the primer bulb. Good luck!
Posted on Jul 18, 2010
How do you replace fuel lines on a craftsman 16" chainsaw model#358.352161?
remove the carb and then pull fuel lines from tank ,there should be a filter in tank attached to the fuel line you will put that on the new line then feed it through from in the tank out
Oct 30, 2014 | Craftsman Garden
My craftsman chain saw 18 will not start
The 3 things needed for an engine to run:
1. Compression (Cylinder, Piston, rings, gaskets)
2. Ignition (Spark plug, ignition module/coil)
3. Fuel (Fuel lines, Carburetor, gaskets, bad fuel)
More than Likely I would start by checking fuel related since that is usually the biggest offender (fuel lines broken/dry rotted, bad carb.)
Jun 19, 2014 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
HOW DO YOU REPLACE FUEL LINES ON A CRAFTMAN CHAINSAW MODEL 358355160
The lines are usually a tight fit in the fuel tank. This prevents leaks. They must be pulled out of the tank (one at a time) then cut the new lines end in a "v" pattern, this will allow you to push the new line through the tank. Long needle nose pliers are needed too.
May 09, 2014 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
How to change fuel lines on craftmans 36cc chainsaw
Jul 16, 2010 | Craftsman 118 pc Dual Marked Mechanics...
Replacing 16" craftsman chainsaw fuel line. Problem is one line from tank with two ports on carb and two ports on bulb. There is no diagram to show sequence of connections.
The second carburetor port feeds the primer (bleeder), returns excess fuel to tank.
Filtered line to carb, carb to bleeder, bleeder to tank (probably not visible and no hose in tank).
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
You can find an exploded parts list wit a little detail here:
http://www.searspartsdirect.com/partsdirect/index.action?psid=74199074&sid=PSx20071217x00001a&OVMTC=Exact&site=&creative=3873724584&OVKEY=searspartsdirect%20com
The print is deceptive, it appears the filtered line feed the bleeder it does not!
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Apr 18, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
16" craftsman chainsaw primer pfoblem
Check the condition of the fuel line and filter in the tank and to the carb and primer.Today gas and time will soften them allowing them to become blocked or leak.Replace if needed.
Oct 24, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Sep 04, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Need diagram for fuel lines on craftsman chainsaw
There is two sizes of line. I see the large one goes to the large port on the primer button and then to the fuel tank. The small one goes from the primer button to the carb. The problem is there are two hose connections on the carb. I believe one is a vent, but I am not sure what one it is. I have a 36cc 2-cycle model 358.352161
Feb 27, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
210 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
