Question about Maytag MFI2568AE Side by Side French Door Refrigerator
How to program HV board maytag refrigerator - Maytag MFI2568AE Side by Side French Door Refrigerator
SOURCE: programming hv board
I have the same Maytage MFI2568AEB on the inside top left of the refrigerator the code is 0302, i still cannot enter the code, showing PEO OOO.
Posted on Jan 26, 2009
  • 220 Answers
SOURCE: I replaced my HV Control Board on my maytag
First did you program the board correctly and second make sure all the connections to the board you replaced are in correctly.
Posted on Sep 01, 2009
Sea Breeze
  • 4654 Answers
SOURCE: I Have Maytag mfi2568aes I replaced both the HV
On most the motherboard will reset itself once unplugged. I believe you need to test the low voltage power supply transformer. This by far will not be a one answer solution so if you could follow through the service manual and technical notes with me I will be glad to assist you. Any time a board is disconnected on your model the motherboard should reset back to factory settings once disconnected from a power supply. Hope you have not discarded the old boards and you can put them back in and see if something is different. Let me know later what you decide to do. For now I will leave these=> Service Manual and=> Technical Information I will return later to see if you respond. Please rate my solution after I have helped you resolve the problem and communicate with me. I am offering my help to you free. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Posted on May 14, 2010
Testimonial: "Thank you. Your Tech information was the KEY to the fix."
  • 5 Answers
SOURCE: Maytag programming code for HV
One indirect way is to buy online a replacement board wich comes with the code. Use the code. Return the board for a credit. Make sure you can get a return credit before opting this way.
Posted on Nov 28, 2010
bobicehouse
  • 1524 Answers
SOURCE: I replaced Refrigerator Electronic Control
1. Open the Fresh Food door and press and hold the Door Alarm keypad DoorAlarm .
2. Press and hold Refrigerator Temperature UP keypad .
3. Release the Door Alarm Keypad DoorAlarm and wait 3 seconds.
4. Press the Refrigerator UP Keypad again.
5. Display will show 001 in left display and numeric or dashes in right display.
6. Press Freezer Up keypad and Freezer Down keypad to toggle through Service Test numbers
Posted on Aug 13, 2011
Installed new hv board in maytag french door
With this board you should have also received a paper to program the unit. THe code you need is on the model number plate within the refer section of the unit your working on. I hope this helps.
Good Luck
Sep 27, 2014 | Refrigerators
Hv board needs to be replaced
Try www.searpartsdirect.com Or Give me your city and state I'll find you a local appliance parts supplier.
Oct 29, 2013 | Maytag MFI2568AES Stainless Steel Bottom...
I replaced Refrigerator Electronic Control hv board and I can't program it successfully? DOthe doors need to be open to program?
Aug 13, 2011 | Maytag Refrigerators
Maytag programming code for HV Board.
Nov 27, 2010 | Maytag Refrigerators
Changed HV board on a Maytag MFI2266AES because ice dispensor and water did not work. Now PEoo ooo is shown on the display where temp read out used to be shown.
Did you check the low voltage supply going to the board? I'm pretty good with that model Only problem is I can't pull that model number up. Looks like you have an extra number or letter. You should get 16 volts from the low voltage side of transformer. Sea Breeze
Oct 15, 2009 | Maytag MFI2266AES Stainless Steel Bottom...
Aug 31, 2009 | Maytag MFI2568AE Side by Side French Door...
Programming hv board
Jan 10, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
FRONT DISPLAY SHOWS (PE0-000)
Usually the owners manual would show the error codes so check there first. As for the compressor running, it "should" be cooling if the compressor is running. But lets go back a little, why was the HV board replaced?
Feb 05, 2007 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MFI2568AE Side by Side French Door Refrigerator Logo
238 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
