Question about AOC MW0811 Breeze 8Inch Tablet PC Black
My AOC MW0811 Breeze Tablet Wont Charge
The power cord no longer seems to charge my tablet. I USB cord, at first, kept it powered on, Just not charged. That no longer works either. What Can I Do To Please Fix My Tablet?
HiSense Sero 7 tablet. Why no charge, no power?
About 1,620 results (0.80 seconds) Search Results
    HQRP USB to micro USB Cable / USB Charging Cable for ...
    www.amazon.com > ... > USB Cables
    Amazon.com, Inc.
    Rating: 2.9 - ‎22 reviews
    1A AC Wall Power Charger Adapter Cord for Hisense Sero 7 LT Lite E270BSA .... If you try to use the tablet while it is being charged, no charging will take place.
    HQRP AC Adapter / Battery Charger / micro USB Charging ...
    Amazon.com, Inc.
    Rating: 3.7 - ‎6 reviews
    HQRP USB to micro USB Cable / USB Charging Cable for Hisense Sero 7 LT E270BSA / Hisense... ... HQRP Micro-USB AC Adapter rapidly charges your Cell Phone / Tablet PC ... This one does not. ... Yes No Sending feedback. ... $3.91. 1A ACWall Power Charger Adapter Cord for Hisense Sero 7 LT Lite E270BSA Tablet.
    HQRP AC Adapter Dual microUSB Charging Cable for ...
    www.amazon.com/HQRP-Adapter-microUSB-Chargin...
    Amazon.com, Inc.HQRP AC Adapter Dual microUSB Charging Cable for Hisense Sero 7 LT E270BSA... Do not wait until charging one of your devices to charge the second.
Feb 09, 2016 | Tablets & eReaders
Isnt there a charging cord i can buy to use while online to plug in
yes - it is a usb charging wire that you plug into a power point and the tablet and it powers the tablet while charging the battery
Nov 06, 2015 | Tablets & eReaders
Tablet discharging
Probably a faulty motherboard. How old is your tablet?
has it been dropped in water or has water entered it by any means?
Sep 02, 2014 | AOC MW0811 Breeze 8Inch Tablet PC Black
Unlock a aoc tablet
You will need to do a factory reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the Samsung logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
Oct 30, 2013 | AOC MW0811 Breeze 8Inch Tablet PC Black
Tablet wont turn on
Try to charge it by the original adapter as the PC USB output is not power full enough to supply charging for it
Apr 29, 2013 | Sanei N78 7 Inch Android 4.0 Tablet PC...
My tablet wont charge unless turned on but battery is so low it wont turn on so cant charge it up.heeeeeelllllpppp
You Power Cord must be bad. If you cannot get on the laptop by using just the power cord, then the power cord is bad and needs to be replaced. Also it sounds like you've been operating off your battery since the power cord is bad, but now the battery is dead because the bad power cord was not charging it.
Get a new AC Adapter and Power Cord. Or it could be that the pin where you plug the power cord into the table is damaged or broken.
May 15, 2012 | Archos 101 Internet Tablet 16GB 10.1"...
How to unlock aoc breeze tablet pattern
i have to many pattern attempts, how I can reset hard , AOC tablet.
Apr 17, 2012 | AOC MW0811 Breeze 8Inch Tablet PC Black
Buenas noches, tengo problema con mi tablet. me sale un mensaje android.process.acore
A mi tambien me salio, no me dejaba entrar a ninguna aplicacion, no lo podia quitar. Tuve que recuperar el sistema operativo para regresar al inicio de fabrica aqui te dice como hacerlo es muy sencillo http://latin.aoc.com/support/troubleshooting.
Te borra las aplicaciones que tengas instaladas pero lo que tienes guardado en tu memoria se mantiene.
No se como evitarlo para, si alguien puede decirme, tks.
Jul 13, 2011 | AOC MW0811 Breeze 8Inch Tablet PC Black
AOC MW0811 Breeze 8Inch Tablet PC Black Logo
258 people viewed this question
Top AOC Tablets & eReaders Experts
Are you an AOC Tablet and eReader Expert? Answer questions, earn points and help others
