Question about Brother SE-270D Computerized Sewing Machine
Neddle is hitting the strike plate? - Brother SE-270D Computerized Sewing Machine
  • Brother Master
  • 7,365 Answers
Sounds like the machine is out of time & needs to be taken to a sewing machine repair shop for repair
Posted on Feb 21, 2012
Neddle hits the plate, how do i fix it ?
check that the needle is fitted correctly
check for bent needle
check for correct needle
May 23, 2015 | Sewing Machines
Neddle hits hook plate+how to fix
check needle is straight and fitted correctly
Mar 06, 2014 | Singer CG590 Mechanical Sewing Machine
Singer Sewing Machine 534 repairs
hi it sounds like the timeing has moved on (1) and also on (2) would need to be seen by dealer.
Apr 09, 2013 | Sewing Machines
Using a universal pleating foot, starts out fine then I break a needle, 5 so far. It hist the pressure plate. Using a straight stitch, needle is centered. Bobbin is treaded correctly. Needle is straight at...
Sounds like the needle is hitting the moving part of the pleater once you get going, getting bent then striking the needle plate too.
Its not going to do the machine any good if you keep striking it with the needle as you'll end up putting the timing out.
As the pleater is a generic type it is probably best to stop trying to use it on your machine.
Jun 26, 2011 | Brother XL-2600I
Needle hitting the metal spool housing underneath, mis-timing?
the timing has, gone there is a screw holding the spool carrage on to the shaft lossen this a little so that it still grips but will turn, the neddle should pass the point on the spool case just after the eye comes level with the spool point and hence pick up the lower cotton and just miss the spool case, after re timing turn over by hand to ensure nothing is hitting anything else.
Aug 15, 2009 | Brother Sewing Machines
Neddle problem
Sounds like the needle is hitting the bobbin casing. Take it out and re-seat it. Check your manual.
Aug 11, 2009 | Necchi 3537 Mechanical Sewing Machine
Neddle hitting the bobbon
does the hook assembly move when you turn the handwheel? If no, then your hook drive gears are shot.
Jun 07, 2009 | Brother LS-1217 Mechanical Sewing Machine
Kenmore sewing machine 385.1960180, problem with needle centering
That sounds like it's definitely an internal adjustment. The machine will need to be opened up and the left/right adjustment taken care of. Is this machine one that you can open the top easily, or is it the type that has the front and rear shell?
Feb 20, 2009 | Kenmore 15516 Mechanical Sewing Machine
Will not zigzaz neddle hits the foot plus the plate if u put it on #6 like it shows just bought the machine got it 4/21/08 please help barb1802@hughes.net
If the machine is new from a reputable dealer, they should fix it for free under warrantee.
It sounds like the position of the needle arm swing needs adjusting......my guess is that is off centre and while one side hits the needle plate, the other does not....this is not a serious or difficult problem to fix.
Quick check is to set straight stitch and look at the "centredness" of the needle relative to the foot and presser bar, it will probably look slightly to one side....it may only be a mm or two, but this can be enough.
A quick call to the dealer to explain and you should be sorted. I would not recommend attempting any home remedy on a machine that is in warrantee as it will void the agreement and if something serious goes wrong in the first 12 mths, you will have no recourse.
Apr 22, 2008 | Janome 4623 Mechanical Sewing Machine
Brother SE-270D Computerized Sewing Machine Logo
60 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
