Question about Rosen Car Audio & Video
Ihave no audio for my overhaed dvd player, what do i do first?
Picture shows, but i have no sound coming out
jusus
  • 57 Answers
SOURCE: my system hp pavilion dv4000 cannot play out audio and picture from my dvd and window player files, no sound card foud
Have you try installing the driver for your pc?
the sound driver and the
DVD software need to be installed
Posted on Jul 21, 2008
make sure you got the right drivers for your unit... specially if your using operating systems that exactly supports that drivers you 've loaded with...
Posted on Aug 13, 2008
SOURCE: dvd player stuck in progressive mode
My brother came over to "help" me and we put on the progressive scan...then no picture and you can't see the menu to change. DO NOT use the solution noted here suggesting holding the stop button - this puts on the child lock.
Open the door on the front of the unit; push the DVD button; then push and hold pause button for 5 seconds or more. And progressive scan light will turn off and your picture will reappear!
Thank goodness...I was thinking my brother would be buying a DVD player - hahaha.
Posted on Dec 26, 2008
  • 814 Answers
SOURCE: my portable dvd player has sound but no picture on the screen. pl
If you still have use of the on screen menu functions, you can try using the restore to factory setting option in the preferences section of the set-up menu. Press the setup button on the remote control and use the up and down arrows to find and highlight the preferences section, press ok to enter the sub-menu.In the sub-menu use the up and down arrows to find and highlight the default option. Press ok. This will reset the dvd player to the factory settings. If you do not have the use of the on screen menu, you can use the a/v outputs to a external monitor or television to perform the abouve procedure to try to restore the dvd player to normal operation. If all this fails you can call Phillips customer support at this telephone number. 1-888-744-5477 They will be able to help you, either solve your problem or get the dvd player serviced.I hope this information helps you with your problem.
Posted on May 31, 2009
  • 7 Answers
SOURCE: I have sound but no picture
it does not support pictures
Posted on Jun 21, 2009
I have sound from my DVD player but picture is from the cable show how do I fix and make them both the tv sound and picture or dvd sound with picture, what settings
take sound from audio out from back of TV rather than from back of DVD player.
Move the red and white rca cables to the audio out of the TV
Jan 18, 2017 | Televison & Video
Tf d Ihave a tf dvd7100 I am trying to hook it up to my tv to plac a movie cd
HI,
Before connecting the the DVD to your TV First of all you have to the audio out put of your for the do the following using the setup menu.
Press SETUP button of of the DVD player to show "setup" menu. Select the audio setup the select the digital out then change to OFF from SPIDF/RAW.
Here i have added a picture which shows how to hookup the dvd player to a TV. Its for the same model that you have .
to make the connection you need two codes
1. 3.5mm stereo to two RCA (for audio)
2. 3.5mm mono to single RCA(for video)
connect the first cord to inoptical/audio and second one to video output of the dvd player.
connect the cable which comes from the video out out of dvd to the video input (yellow) of your TV. then connect the cable which comes from the inoptical/audio of the dvd player to the audio input of the TV (red and white ).
You have to select the input of your TV by pressing the AV/ source selection on the remote of the TV. check where you made the connection on the tv AV 1 or AV 2. then select the corresponding input. hope you will get it worked.
Also Added the image of the cable that you need to make the connections.
25383850-eev1v0sv1zwox43luwgxtns5-4-5.jpg 3.5mm stereo to two RCA (for audio)
Electronics Equipment Repair Center
Jan 25, 2015 | Coby TF-DVD7107 Portable DVD Player
There is no sound on my Sony SLV-D350P DVD Player / VCR Combo. The only section that works great is the VCR, but the DVD player sound just went out for some reason. I've changed the RCA cables, and...
Hi, As long as you have the picture it means that DVD's Laser Eye is Ok.. Pls Check your connections to make sure the audio and video cables of both VCR and DVD are properly hooked up to the television. Color coded cables should be matched with the jacks of equal color. Yellow corresponds to video while red and white are both audio.
Ensure the DVD is in standby mode if you are not getting picture from the VCR. The DVD cannot be running at the same time as the VCR is playing when you want to see the VCR picture.
Connections with combo units are often inconvenient, forcing you to use separate video hookups for each section (DVD, VCR), a problem for older TVs. This player has it figured out: a single RF or composite-video connection to a television will display either the DVD or the VCR signal, depending on which format you're viewing. If you want to view DVDs in S-video or in component-video (either interlaced or progressive-scan), you will need to use two inputs. though: any component- or S-video-equipped TV will offer sufficient inputs for both of the SLV-D350P's formats.
It's a different arrangement for audio: you can listen through a single set of stereo analog-audio cables for each component or--if you want to enjoy DVDs in discrete 5.1-channel surround sound--you can send the DVD's audio to a compatible audio/video receiver and a multichannel speaker system through a digital-audio interconnect (either optical or coaxial,). The unit also comes with an RF cable that will transmit DVD/VHS audio and video to your TV.
In conclusion,for a best tech solution I prpose you to connect DVD audio directly to your Stereo and listen as separate audio source.while Video goes to TV as usual. Hope this helps! if you need more help pls contact me..Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Jul 02, 2011 | Sony SLV-D350P DVD Player/VCR
Ihave sound on my wharfdale tv but no pictore
Check you video cable if it is well connected if it is then interchange the cables using the one for the audio for the video and other one for the video to connect the audio . If there is no sound then the video cable is bad and need changing but if it produces sound then you will need to visit a local repair man
Apr 11, 2010 | Wharfedale DVD-M3 DVD Player
Only dvd plays properly but vhs will not show picture.
Most likely you have the dvd part connected through component or svideo cables. Despite the fact that this is one unit, like other vcr/dvd combo units it acts as two separate units in the same box. The vcr will probably not play through those cables. As you have audio coming through I'd imagine that the audio is connected using red and white composite cable. Connect the video on the vcr side with composite yellow cable or run direct to tv with a coaxial cable.
Feb 04, 2009 | Sansui VRDVD4005 DVD Player/VCR
Sudden loss of picture, sound comes though ok
It sounds like the exact same problem that my son recently created. The only solution I've determined is to reset the player to it's default settings. Although it took a little while (since the video display was not present), I finally found the right combination of buttons to push on the remote and now the problem is fixed. Insert a disk, then push the following buttons: Stop, Stop, System/Menu, >, >, >, v, v, v, v, v, >, OK
After the above sequence of buttons, the main player screen should reappear on the tv.
Croce23
Jan 04, 2009 | Philips DVD727 DVD Player
My dvd player doesnt show picture but sound is good
Did you try replacing the video cable normally it is yellow right, Ok with the audio cable red and white, try to use them as video because theres sound meaning cable is ok, if the picture shows with red cable or white that means you have to change the video cable (yellow). hope it helps.
Nov 06, 2008 | Televison & Video
Picture but no sound only loud hum
You have to double check the inputs of the video in as well as the audio in on the TV set. they come from the video and audio output on the DVD player. Good Luck
Jun 28, 2007 | Samsung DVD-V9650 DVD/VCR Player
Car Audio & Video Logo
41 people viewed this question
Top Rosen Car Audio & Video Experts
Jerry Naidoo
Are you a Rosen Car Audio and Video Expert? Answer questions, earn points and help others
