Clear lines distorting the display at regular intervals across the whole of the screen. The lines have just appeared today. It's apparent directly from the digital input and via DVD player. It's not a signal issue.
SOURCE: I have a Sony Bravia KDL-46Z4100 46' I have a green vertical line
this is probly the lcd control module unfortunatley it comes with a new lcd panel
change these.
Posted on Mar 11, 2009
SOURCE: Sony Bravia KDL-46V3000
turm on the tv for at least 24 hours with rf signal it will automatically get ok.
Posted on Sep 04, 2009
SOURCE: vertical lines on sony kdl-46v3000 bravia lcd tv
i have the same problem, apparently the LCD panel needs to be replaced and this will cost more than the tv is worth... Advice is to not buy a sony again, because this is a common problem and they wont extend the warranty, even if its 2 weeks after it runs out...
Posted on Nov 23, 2009
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Posted on Dec 02, 2009
SOURCE: sony bravia kdl-32l4000 has colored vertical lines
Most of the time the " T-Con" board is the cause. On a lot the Sony models, this board is not replaceable without replacing the LCD Panel. Sony has been making more of them available but you would need to check with Sony's Parts Department if it is available for your Model.
I hope this helps,
Sky Assoc
Posted on Jan 05, 2010
Oct 07, 2016 | Sony Televison & Video
Sep 05, 2015 | Sony BRAVIA KDL-52XBR6 LCD TV
Sep 17, 2013 | Sony Bravia KDL-40V4150 40 in. LCD HDTV
Feb 06, 2018 | Sony BRAVIA KDL-32S2010 32 in. LCD...
Feb 15, 2011 | Sony BRAVIA KDL-52S4100 52 in. HDTV LCD
Nov 12, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Apr 02, 2010 | Televison & Video
Dec 18, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Nov 24, 2009 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
May 25, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
