Question about HP Pavilion dv1000 Notebook
NIC problem no connection between card and network but ido formatting for pc and no result and replace it but the problem it stil
  • yasser-dhank Oct 27, 2008
    i have problem in computer dll ."booting " but every thing is good
    Scholar:
  • 136 Answers
What kind of card? Wireless? If so, the computer's IP address must be configured to the same range as the router, and the router must be configured to accept incoming connections from your computer.
Posted on Oct 28, 2008
Nic card not working? How to troubleshoot? Is there a plug and play nic card that can be installed onto this desktop PC?
Hello Sqis,
You can purchase any nic card which is compatible with WinXP or 7.
Insert the card in PC Slot of the motherboard.
Install the driver for the card and it will work.
May 05, 2011 | HP Compaq Presario SR1650NX...
Will any Wireless Adapters work without the PC's NIC?
Yes even without any NIC card installed on your computer , the wireless adapter will definitely work since its a different device that work for wireless connection and has nothing to do with your NIC card configuration.
May 15, 2010 | Linksys WUSB54GC 802.11g/b Wireless...
I have lost my network connection Icon. As I heard I have NIC problem. please help me.
well I wonder exactly what the "Nic" fault is? To troubleshoot, the first thing to do is go into "Device manager" and see if the Network Adapter is there. If it is, then right click the icon & choose "Update Driver". It should search the PC for the driver and install it. If it cannot "find" it. Then you need to go here http://www.emachines.com/support/product_support.htmland download it. Then run the installer. If this doesn't work then you may need to replace your Nic adapter, this too is simple. You locate the card, withdraw from the slot, replace with the new one, install the "Driver" from the CD that came with the Nic adapter.
If you can find your Nic, but it just isn't showing in your "Task Bar" then right click the icon and select "Show icon when connected".
Feb 22, 2010 | E-Machines eMachines Desktop PC
I have a dell deminsion 3000. I have high speed
ya sure u can.
i don't know why people are afraid of such things.
Aug 14, 2009 | Dell Ethernet Card Network Adapter
How do I replace the nic card in my computer?
a Nic card is a simple device (Network Interface Card) presumably a desktop machine I suppose. Just go to a local ABC warehouse or Walmart and by a new Network Adapter "NIC" PCI card and install with the drivers provided. Should be around $12-25.00 depending on the model... this should work:
http://www.walmart.com/catalog/product.do?product_id=2067722&findingMethod=rr
Aug 04, 2009 | HP Pavilion 523n (P9851AR#ABA) PC Desktop
Failed Server Enumeration Test (Sony Vaio)
Buy a Nic and install it, disable the on board old NIC
Apr 05, 2009 | Sony VAIO VGC-RB42G PC Desktop
Dell 4700 Computer Integrated NIC Problem
Check for the pins inside the integrated NIC to check if the pins are bent / disfigured. Does not look like the additional card is making any different, looks more like a moving NIC cable is makin the difference.
Lemme know if this helped!
Dec 13, 2008 | Dell Ethernet Card Network Adapter
Can I add a NIC card to my compaq presario pc sr5250nx? I keep loosing my internet connection every five minutes and have to reboot the computer to reconnect
you should be able to
http://h10032.www1.hp.com/ctg/Manual/c00840496.pdf
if your system is still within warranty I would think twice about opening the case yourself to installing a new network card.. you will be voiding your warranty.. so think about it
another thing i would try before deciding on going for another network card is to check your onboard network adapter has updated drivers... or you may want to reinstall the drivers for that adapter.. either one of those may probably fix your issue assuming is not a hardware failing given that your system may not be that old.... make sure you check the windows update and look for any new hardware driver for your network adapter that may be avaliable through windows update.
before you install your new network pci card you may have/want to disable the one on board going into your bios for that. so to ensure there's no resource conflicts when installing the driver for your new card (it may not be a problem even if you don't but if you run into problems while installing the new card consider this suggestion)
Oct 02, 2008 | Compaq Computers & Internet
Integrated 10/100 nic card problems
The card has developed a loose connector, it's just worn, it happens and is fairly common with these, and there nothing you can do about it, other than replace the card, and yes you can replace it with a 10/100 wireless/combo. Just remember to uninstall the drivers for the old card prior to installing the new card in order to keep from having a conflict. That is, if there are drivers, a majority of these cards are plug and play. With the wireless/combo there will be drivers.
Jul 15, 2008 | Dell Inspiron 5160 Notebook
Emachine model t3302 ethernet card
This is how the wireless world works. You buy a wireless router with a four port switch. Your DSL or cable connects to that. A cable called a Rj45 connects the DSL or cable to the back of the wireless router. You also buy a wireless network card for your PC. After running the software for the router & the wireless nic card including setting up a home network through windows your daughter will be able to connect that computer to your network from any room in the house. Below is a link to a wireless router:
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=10005578
You can connect up to four computers to the wirless router. A computer that does not connect to the router by a Rj45 must use a wireless network card. Linksys WMP54G Wireless-G PCI Adapter Retail: http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=252286
As you will see there is a big differance between a NIC card & a wireless card.
Jan 01, 2008 | E-Machines eMachines Desktop PC
HP Pavilion dv1000 Notebook Logo
27 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
