Question about Bosch Dryers
Can I fit a Ntc sensor to a Bosch condenser myself or is it a job for an engineer?
2 Suggested Answers
  • 16376 Answers
SOURCE: How to fix recurring F09 error in Bosch condensing dryer WTE86300US
How long is the connection including the duct work in the house?
Posted on Aug 01, 2014
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
Tip
Tumble dryer not heating how to fix heater, thermostats, Ntc sensor.
We have all these tutorial guides that will help you with your Whirlpool 6th sense
How to clear error codes
How to service a pump unit on condenser tumble dryer.
How to replace belt, motor or bearings.
Tumble Dryer Not Turning, How To Replace Capacitor
We have all repairs guides on these Whirlpool 6th sense Tumble Dryers
http://www.how-to-repair.com/help/tag/6th-sense/
on Jan 21, 2015 | Whirlpool Dryers
Jul 31, 2014 | Bosch WTE86300US Axxis Electric Dryer
Zanussi ZWD 1270 no heat
E72 can also be caused by broken wiring to the NTC(Sensor). If the wiring is low voltage( very thin wires) then pull gently on the wires where they go into the NTC. If they break away there is the problem, you would need to replace the wiring harness for that NTC. Also, check the fan motor is running and the belt on the ventilator has nt stretched. If all is ok check the condenser is nt blocked with lint
Mar 11, 2014 | Zanussi ZWD1270 Front Load Washer / Dryer
Bosch champion dishwasher tripping switch. need to fing the float switch
can go on-line and search for a free dowload of the repair/parts manual to locate the sensor. call a local repair man about price of part and see if its easy to replace to find location of the part.
Sep 29, 2010 | Bosch Dishwasher NTC Sensor 165281
Bosch 5410 Electric Dryer heat issue The dryer tumbles fine, but the heat turns on for about 30 seconds and then stops. If I stop and start again this scenerio is repeated. I have check out the following:...
There is also another overheat module below the front door too. Check that.
Also, forgive me for asking the very obvious, but have you checked the entire exhaust pipe to make sure that there is no restriction that would cause overheating.
Mar 18, 2017 | Bosch Axxis WTL 5410 Electric Dryer
E60 error code
Found These Fault Codes On Internet, Hope This Helps, Daz
ALARM CODES
E00(E00)- Problems with water fill during washing
-Tap closed; solenoid valve, water distributor, wiring ,main PCB, pressure switches
E01(E00)- Problems with water fill during drying
-Tap closed; solenoid valve, wiring , main PCB, pressure switches
E10(E10)- Problems with water drain during washing
-Drain hose kinked, filter blocked, drain pump, water distributor, wiring , main PCB, pressure switches
E11(E10)- Problems with water drain during drying
-Drain hose kinked, filter blocked, drain pump, pressure switches
E20(E20)- Door open
-Cycle in Door delay, wiring , main PCB
E21(E20)- Fault in door delay power triac
-Wiring , main PCB
E30- Fault in electronic pressure switch
-Electronic pressure switch, wiring , main PCB
E31- Fault in electronic pressure switch circuit
-Main PCB (fault in electronic pressure switch circuit)
E32(E10)-Calibration error in electronic pressure switch
-Electronic pressure switch, drain pump, wiring , main PCB, filter blocked
E33- Incongruency between electronic pressure switches and safety switch 1
-Electronic pressure switch, safety pressure switch,wiring, main PCB
E34- Incongruency between electronic pressureswitches and safety switch 2
E35- Intervention of anti-overflow pressure switch
-Solenoid valve, water distributor, wiring, main PCB,anti-overflow pressure switch
E36- Water leakage (maximum number of resets exceeded)
-Water leakage, drain hose too low, pressure switch,wiring, main PCB
E40- Motor power triac short-circuited
-Main PCB (triac short-circuited)
E41- No signal from tachimetric generator
-Tachimetric generator on motor, wiring, main PCB
E42- Fault in tachimetric generator circuit
-Main PCB (tachimetric generator sensing circuit)
E43- Intervention of motor overload protection
-Motor, wiring, main PCB
E50- Insufficient heating during wash phase
-NTC sensor setting incorrect, heating element, wiring,main PCB
E51- Overheating during wash phase
-Heating element (to earth), main PCB (relays)
E52- Insufficient heating during drying phase
-NTC sensor setting incorrect, safety thermostat,thermostats, drying heater, wiring, main PCB (relays)
E53- Overheating during drying phase
-Drying heater (to earth), main PCB (relays)
E55- Fault in power relay for heating element (K3)
-Safety pressure switch 2, wiring, main PCB- 6 -
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
E61- Fault in drying NTC sensor(condenser)
-Drying NTC sensor (condenser), wiring, main PCB
E62- Fault in drying NTC sensor(duct)
-Drying NTC sensor (duct), wiring, main PCB
E63- Fault in 1/2 power thermostat
-Drying NTC sensor (duct), 1/2 power thermostat, wiring,main PCB
E70- Power triac to distributor motor short-circuited
E71- Fault in power relay to distributor loads
-Main PCB (relay open)
E72- No distributor position signal
-Water distributor motor, wiring, main PCB
E73- Incorrect timing on distributor contacts
-Water distributor, wiring, main PCB
E90- Fault in tank fill pump
-Hoses obstructed, tank fill pump, wiring
E91- Fault in tank drain pump
-Hoses obstructed, tank drain pump, wiring
E92- Fault in power triac to tank fill pump
-Tank fill pump, wiring, main PCB
Jan 04, 2008 | Zanussi ZWF1440 Front Load Washer
Tumble dryer not working
I managed to solve the problem the following way: I noticed that if you unplug the Sensor-NTC(part nimber 154431 https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=WET2820GB%2f13 ) that controls temperature of air in the air channel, the drying cycle runs as you describe above. So this circute was checked up to the power module. Contacts of the Sensors plug were tightened; I think this solved the problem; resistance of the sensor checked. It must be 4.8K at 25 degree C. and decrease when temperature increases. I dipped the sensor in a glass with hot water.
Oct 25, 2007 | Bosch WET 2820 Front Load Washer / Dryer
Dryers Logo
49 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
