My pc works but my power button doesnt light up
Computer powers up but no signal to mointor and the perphial accessories work but the power button doesnt com on or turn off the power
Unhook everything but the CPU, memory, and video.
Does it start up? Can you see anything on the monitor?
When you were messing around inside the box, you may have accidentally removed the wires from the motherboard that control the power switch and the power light. Check that you haven't done that and if you have, reattach the little plugs to the pins where they belong.
If you don't get anything, the motherboard is probably toast.
Jan 07, 2012 | Acer Aspire T180 PC Desktop
My Acer Aspire L100 doesnt start. Only the fan works but not the system. I had this problem for 2 years but when i switched off the button and then on again after some tries it worked but now even the ON...
ok, try to locate the battery on the mother board, before that make sure the main power cable is unpluged.
remove the battery , and then remove your ram carefully, wait for 10 minuts, the replug every thing, and dnt forget the power cable :)
it should work.....if not, replug everu thing again and plus the vga...
May 11, 2010 | Acer Aspire L100 PC Desktop
Dlink DIR-625 Doesnt work. Power light blinks when plugged in
hi.. all,
i am facing the same issue.. my new DIR-615 , when plugged with power cord ... make the power led blink continuously... and hence so, no network is accessible neither wifi works in simple terms noting works, no combination of power cord with network cable with computer works.
i have even tried resetting using the reset button.. but still the power button keeps blinking.
and yes it was working in past, its a brand new product(3 months old).
Please help and its urgent..
thanks a lot for your help..
Regards
Dharmendra
Nov 25, 2009 | D-Link DIR-625 (790069292637) Wireless...
When i turn my computer on the big button which is usually green doesnt work. there is a smaller light which is also usually green just below the big one which starts green as i turn it on and then it goes...
Make sure your cables are all firmly connected. Also check the power strip or surge protector. If all is connected well and the pc will still not turn on it looks like the problem is the power supply unit, which can be replaced for around $20. I hope this works :).
Aug 16, 2009 | Compaq PRESARIO SR1475CL AMD Athlon 64...
Laptop is nmot working
hi,
welcome to fixya,
as u said that ur laptop is not working and it is not booting,i mean is it a dark screen or do u see the lights on the computer,can u clarify me pls...u can try and safe mode and if it doesnt load in safe mode then what u can do is that disconnect the ac adaptor and take out the battery and then without ac adaptor and the battery press and hold down the power button for one minute and then release the power button and then connect the power cord and put the battery back in and then turn on the computer,and if still it doesnt turn on then try and connect with the different wall outlet and if still doesnt turn on then try with the different ac adaptor and still if it doesnt work then replace the motherboard and the ac adaptor.
Feb 19, 2009 | Toshiba Satellite A100-S8111TD Notebook
Laptop power is on but no display, doesnt boot
Make sure whether ur display button is on.This button appears on the top of the laptop.
thanks.
Jan 31, 2009 | Computers & Internet
Power button
try one step if that doesnt work contact the dell tech on 18006249896 it could be a major hardware failure
remove the battery and also the power cable and hold down the power button for 10 sec and than connect the battery and the power cable and start the pc that should work
Jan 12, 2009 | Dell Latitude D600 Notebook
My screen doesnt work.
I suggest you to perform these steps.
Test the AC adapter Follow the steps below to determine whether the problem is related to the AC adapter or your notebook system board.
  1. Remove the battery and disconnect all external devices from the computer.
  2. Hold the Power button for several seconds, with all power sources removed. This drains residual power from the system, and may correct many problems.
  3. Connect the AC adapter to a wall outlet and plug the other end into the computer.
  4. Press the Power button to start the notebook PC.
If the notebook does not start or the display is blank then check the power indicator light or power socket LED. I suggest you to connect the notebook to external monitor and check whether its working or not. Then please perform the harddrive self test also.
Jan 09, 2009 | Dell Inspiron 1521 Notebook
A drop image on screen
hi i have panasonic NV DS 65 initially when i power on the cam it started then after 5 to 10 sec the power light automatically flashes and the buttons on camera doesnt work any more. but now the problem has got worsend the powen light keeps on flashing and no buttons work moreover a drop image is flashed on the screen.
plz have me solve my problem
sam_rav
Jan 24, 2008 | Panasonic NV-DS65 Mini DV Digital...
My MD16XDVD9 doesnt work. Its power is on with the small greeen light flickering and the bigger green light steadily on. but the the DVD tray doesnot open automatically. Even if it is force-opened and a...
have you got it set on an IDE cable on it's own and if so have the jumper at the back set to master the other thing to do is power of pc and remove ide cable from all devices and leave power cable to burner then torn on pc if you have removed power and ide cable from hard drive then when pc boots in press button on cd,dvd drive to open tray then place cd lense disk or any cd in drive tray press close button and let device kick in if it picks up disk then try with a dvd disk with power on pc if all goes well try with a ifferent Ide cable to motherboard and reconnect harddrive and power up if all goes well the pc should recagonise it if not then get it replaced
Aug 06, 2007 | Mad Dog Multimedia (MD16XDVD9) DVD±RW...
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
