Question about Philips 32PF5321 32 in. HD-Ready LCD Television
Philips FlatTv problem
I was wondering if you could help me. I have a Philips 32" FlatTV which doesn't always turn on. It powers up and you can hear the speakers pop a bit but no backlight or anything from the screen.
If I then turn it on and off a few times it eventually will work. It seems to be more of a problem when turning on from fully off (not standby).
Do you have any ideas of what may be the problem?
Thanks
Rob
  • Anonymous Dec 24, 2008
    I have the same problem! I'm form Italy. My tv it's 2 years old and no warranty! Any idea?
    Tnx
    Problem Solver:
  • 7 Answers
POWER SUPPLY PROBLEM TRY UPGRADE POWER SUPPLY KIT FROM PHILIPS
Posted on Aug 31, 2009
Philips flattv will not turn on after blackout how do i turn it back on
hola amigo lo mas probable es que se halla ido un fusible en la fuente de tu tv por el apag?n te recomiendo que lo reemplaces por el mismo tipo de fusible con la misma corriente ,para que no halla percances ,si se lo vuelve a llevar tienes problemas con la fuente i debes buscar ayuda profesional por q la fuente de los tv manejan voltajes elevados,... saludos...
Nov 18, 2016 | Philips Televison & Video
HOW DO I RECIEVE MY CHANNEL ON A PHILIPS FLATTV 42" BUILT IN FREEVEIW
Ask this web site thell know http://www.google.com/aclk?sa=l
Sep 26, 2011 | Televison & Video
LOST CHANNELS ON MY PHILIPS FLATTV 42" RETURNED
Problems in the IF section of your tv.or tunner is faulty.replace tunner.have a tech repair your tv. good luck.
Sep 26, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a Phillips FLATTV model ... Problem with the Philips Flat Panel Televisions I have a Phillips FLATTV model 42PFL7662D/ 05 I have no picture, the audio is OK, I have had a hissing noise for about 2...
Try with that...
http://www.filestube.com/3c4e959f7e53ba6703e9,g/PHILIPS-42PFL7932-LC420WU5-V2-CIRC.html
Symptom:
Sound but no picture.
Cure:
Master or Slave inverter is defective.
It can be that the driver IC is defective or MOSF
inverter transformers, or 470uF 35V C
Replace driver IC BD9897FS or MOSFET's.
996500046243 IC BD9897FS
996500046242 Mosfet FDD8447L
996500046241 Zener KDZ100V
Oct 18, 2010 | Philips Televison & Video
When i turn my philips flattv on a message pops up.... (no video input) then turns off in 20 seconds. Unable to controll.
The TV may be turning off as a power saving precaution as it thinks it's not being used.
What are you plugging into it? No video input suggests the tv is waiting for sky or DVD player to be plugged in. Is it?
Jul 23, 2009 | Televison & Video
Menu screen won't go away.
Try to hard reset the tv..Leave it unplugged for 4-6 hours and then plug it again and use..If this did not help Try to contact a service centre or service person because this is probably a hardware problem which definetly needs service and replacement!!...Thank you..
Hope this helps you....
Kind Regards!!
DON'T FORGET TO RATE;
Jul 21, 2008 | Philips 50PF7320A 50 in. Plasma HDTV
How to set up high definition xbox with flatTv
If your talking HDMI cables yes you can go Cablemart.com and get HDMI splitter boxes. a slew of additional parts and they are about the cheapest and the best built.
Have two 50" HDMI cable from them.
Jun 04, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips 32PF5321 32 in. HD-Ready LCD Television Logo
253 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
