Question about Garden
Mower left out in the rain - wont start
Lawnmower starts when I manually add fuel added into combustion chamber - healthy spark -but feels as if fuel not being pumped -
  • 306 Answers
SOURCE: S10 won't start after it rains. Replaced fuel
Dump the gas in the fuel tank
Posted on May 07, 2009
  • 10865 Answers
SOURCE: lawnmower wont start
your carbeurator is gummed up. a common problem after the lack of use in the winter season. Since you havve a new plug you are partway home. Empty out any old fuel and put in new fuel which you buy now at the gas station. Then buy a can of carbeurator cleaner. Remove the air filter. Look and see if it is dirty, if it is replace it also. Spray two short ssquirts of carbeurator cleaner into the air intake opening exposed while the air filter is removed.
Pull the cord and try to start the engine. Even if it won't start you will be drawing the cleaner into the carb. so it can start to dissolve the problem gummy deposits. Wait half hour and repeat the spray and the attempt to start. If this fails after four attempts you will probably have to remove the carb. and soak it in carb. cleaner for three hours to dissolve the gum.
Posted on May 23, 2009
  • 3 Answers
SOURCE: My Mower won't stay started after it uses the gas that has been pushing into the mower via the primer bulb
either the magneto or the governor is damaged check them
Posted on May 30, 2009
SOURCE: Keurig B60 coffeemaker stopped pumping water
This morning my Keurig sounds like it begins to pull water then stops. I tried to cut it off then back on. Still didn't work.Removed water from reservoir and K-cup and added pure vinegar. Ran machine several times without filter or Kcup by pressing cup selector several times. You must open K-cup holder and close each time. I had to do this about a dozen times before the water began to draw again. Flushed system by filling water reservoir with fresh water, and brewed just plain water until vinegar was gone.Works like brand new.
Posted on Jun 21, 2009
  • 496 Answers
SOURCE: I have a bolens 4.5HP push mower that wont start
Is the spark plug firing? If it is, gently remove the bowl from the carburator and see if you have any beads of water. I kinda suspect you do... dry off everything with a clean cloth or paper towel. You might even want to drain the gas and dry out the gas tank to insure no more moisture is in the gas system.
Hopefully this is all that's wrong...
Hope this helps. Good luck!
Posted on Sep 16, 2009
Replaced spark plug and battery...gets fire but motor will not start???? Any answers?
check the timing and the fuel supply to the combustion chamber. Spark and fuel supply to the point of combustion/ignition must coincide other wise you have fuel with no spark result no ignition, or spark with no fuel, result ...no combustion
That is the first step to diagnosing
Jul 04, 2015 | Garden
Starter works trys tostart but wont
if it tries to start, i.e. it is catching check the level of fuel into the combustion chamber and the power of the spark.
If you crank over several times on a fully charged battery, remove one of the spark pluvs if it is a petrol/gas engine, and check the spark plug tip, it should be moist with gas/petrol or at the very least, smell stronly of it.
cHECK THE PLUGS ARE CLEAN, UNDAMAGED AND CORRECTLY ADJUSTED.
If you attach a plug lead to a plug and lean it on the engine and crank the starter over you should see a healthy blue spark between the electrodes.
If the fuel is there and the spark is there at the same time the engine should start, (assuming there is no makor internal problem.)
The issue might be the timing, getting the spark and the fuel to coincide in the combustion chamber when the piston is at the optimum position in the bore.
If there is a weak spark or too little fuel these should be investigated work away from the combustion chambers to the source of the fuel and electricity.
If the spark and fuel are healthy and the timing is okay check compression in the cylinders.
They should be healthy and withing a couple or five pounds of each other
It might be sensors playing up and affecting the ECU, (engine management system)
There is a lot to check, A GOOD MECHANIC SHOULD BE INVALUABLE TO DIAGNOSE.
GOOD LUCK
Jun 23, 2015 | Cars & Trucks
Toto lawn mower wont start
Hi, do it have a spark plug
Sep 23, 2012 | Garden
My brut lawnmower wont start?? what can be wrong??
try starting fluid if it fires on that then you have spark if not no spark then if it does then then look into the carb old gas left in for more than 30 days can plug up jets
Aug 26, 2012 | Garden
Scotts 2554 mower wont start added new battery, cleaned carb and needle seat. new pto switch but still pops fuse when u pull the pto switch, put new swi=tch in and now wont even turn over at all
Does the engine turn over?. The pto switch you mentioned is this the POWER TAKE OFF switch? In other words starts the deck? If so, it must be off when starting the mower. Any internal combustion motor needs fuel and spark. If it cranks over check for a spark. If no spark determine if it has points or breakerless ignition. Also check magneto coil. If you have spark then, be sure fuel is getting to the carb. With today's gasoline, you can't let it sit in the tank long without adding an additive. If the PTO switch you described, is blowing a fuse, then it cold be a bad coil on the clutch. You can disconnect this coil to see if it stops blowing the fuse. you didn't mention if it is a Kohler or BS engine. Try this link:http://manuals.deere.com/cceomview/OMM141871_D0/Output/OMM141871_D014.html#34531
Jun 30, 2010 | John Deere Garden
Mower wont start
About the only suspect is water in the fuel - even after you drained it. If your Masport has a 'Quantum' style engine with a float type carb, undo the bowl nut and allow the float chamber to drain. Odds on there's water in it. A single drop will block the jet. If it's a 'carb-on-the-tank' engine, chech for water droplets in the bottom of the tank. They wll be obvious if present.
Mar 11, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
I have a 1999 gmc Yukon it is getting fuel and spark i even sprayed starter fluid in the intake but it still wont start it turns over good but wont start
ok make sure you have good fuel pressure
you must have good spark must fire a spark tester
if all that is good then check compression
and don't use STARTER FLUID on a GAS ENGINE it can blow a hole through the piston
hope this helps
Nov 12, 2009 | 1999 GMC Yukon
White smoke coming out of lawnmower my son was cleaning garage and thought he would save space so he tilted the lawnmower on its side my brother said that gas and oil may have mixed together and thats...
The oil is drained by removing the drain plug on the underside of the mower, where the blade is. The gas can be drained by removing the gas line from the carburetor and letting the gas drain into a container. Remove the spark plug wire from the spark plug before any work is done to the mower. But, really depending on just how long the mower was on its side, the mower should be OK after running for a few minutes. Have you let it run for several minutes? The oil in the combustion chamber should burn off. The one thing to check is the spark plug. It may have some carbon buildup on it from the oil. It can be cleaned with some spray carburetor cleaner, or you can just replace it for a few dollars.
Aug 12, 2009 | Garden
Lawn mower keeps cutting off
from the sound of what you are describing the piston/rings/cylinder are damaged in some way shape or form this causes compression loss in the engine, and allows oil to enter the combustion chamber, in this case a new lawnmower would be in the near future
Aug 11, 2009 | Garden
I have a 1999 honda cr 250 and it wont start it will start for a second every about 10 kicks and then stop again... help me
You will have to perform some basic checks like tht of sparks reaching the spark plugs and tht the fuel too enters the combustion chamber, wth your explanation it seems fuel is not entering correctly into the combustion chamber... you will have to clean the carb/s.
Jun 14, 2009 | Honda CR 250 R Motorcycles
Garden Logo
448 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
