Question about Yamaha Music
Need to know exactly how an Ibanez AEG4JP-BK-27-01 is supposed to be wired. not getting any sound when plugging in,
I am trying to wire a Delano 4 conductor pickup with a simple volume and tone control harness wiring into my Ibanez Bass guitar. I am new at this and just getting a buzz when testing.
If you are getting a buzzing sound, the ground connection is wrong. If you google how to wire an electric guitar there is a lot of info on it.
Oct 23, 2016 | Ibanez Music
Hi there. I bought my friend's Ibanez RG3EXFM1 and the volume knob doesn't work. When I plug it into the amp, I don't get a sound unless I mess with the knob a bit. I opened the guitar up
your gonna prob have to replace knob but try and re sodder the connections. if that doesn't fix it then its your knob that needs to be replaced
Dec 19, 2012 | Ibanez RG3EXFM1 Electric Guitar
I have an Ibanez s470 and need a wiring diagram for 2humbuckers and 1 singlecoil with a 3 position swicht
What kind of switching options do you want? there are many ways to skin a cat but there are more ways than that to wire a guitar..
Visit the ibanez website for wiring diagrams if it is something simple you want. for more customised switching options,you should contact the pickup brand's customer care...for example,when i bought Dimarzios for my Ibanez,i emailed dimarzio and they replied within 24 hours with a pic of the correct wiring.
Jun 21, 2012 | Ibanez S470DXQMRVK Electric Guitar
There's no sound when I put a cable in input, but when I put headphones too, there is a sound. How to reset ibanez mimx65?
If the sound you when plugging in the headphones is coming from the main speaker, it is just the interupt contacts on the headphones are making or breaking contacts. This can be a good sign if there is volume to it.
Make sure the plugs you are using are the right length for jacks in the Ibanez as there are 5 lengths in use.. If this just developed, the length issue is not a concern. If the jacks are loose, snug them down, it may be a faulty ground relying on the chassis contact with the jack.. It may be a broken wire. It can also be a dirty switch contact or dirty level control, especially the standby switch. make sure they are clean with some contact cleaner. Make sure your level is turned up too,
If you have effects, or a preamp on the guitar, make sure they have fresh batteries or good power connections and are not on mute.
Apr 11, 2012 | Ibanez MIMX65 Modeling Guitar Combo...
I have a Ibanez V Series V70CE. It play well. But sometimes when I connect it to the amplifier, there seems to be loose connection and no sound is heard. When I move the wire little bit sound come...
Many try to use poor quality guitar cables and have the problem. The sleeve of the guitar cable plug turns on the battery in the guitar. Always loop the guitar cable through your belt or the guitar strap to avoid the cable wisting the plug in the guitar causing noise and WEAR that wears the plug sleeve to the point it no longer will activate the guitar.
Sep 18, 2011 | Ibanez V Series V70CE Dreadnought Cutaway...
Need expert to rebuld wire harness for ibanez 2453,howard roberts . one of the pots is damaged.
Almost any guitar shop[ can replace a damaged pot without rebuilding the whole wiring harness. Pots usually only have three wires or some might have an extra pair if the pot has an integral switch. The hardest part will be to get an exact replacement pot.
Sep 27, 2009 | Ibanez AF75TDGIV AF Series Electric Guitar...
Music Logo
138 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
