Question about Zhone (6218-I2-200) Router
How can i set apassword on wireless network - Zhone (6218-I2-200) Router
  • 58 Answers
Please download the user manual (click here)
Now log in to the admin panel (page 26)
Open the Security section under wireless (page 67-68)
There you can set the password. Page 68 has the description of what security type you have to select according to usage.
Posted on Feb 20, 2012
Hi i am using the pc sony vaio i have the problem on wireless adabter it was in desable mode and difficutl to active it ,while i am useing the bottom in front of pc on and off of wirless adabtor but i i on...
In Vista, you can either go to control panel, device manager and right click on it and click "eneble"
or go to control panel > network sharing and set up wireless network connection
or
go to task manager (press and hold ctrl . alt . delete for a couple of seconds), until task manager comes up. Then click on the services tab, scroll down till you see "Plug Play or Plug and Play and make sure it's running. If it's not, right click on it then click "enable"
In XP
Open Network Connections
Right-click Wireless Network Connection, and then click Properties.
On the Wireless Networks tab, do one of the following: •
To enable automatic wireless network configuration, select the Use Windows to configure my wireless network settings check box. This check box is selected by default. For information about what happens when you enable automatic wireless network configuration, see Notes.
To disable automatic wireless network configuration, clear the Use Windows to configure my wireless network settings check box.
To connect to an existing wireless network, do one of the following:
Access point (infrastructure)
To connect to an existing access point (infrastructure) network, under Available networks, click the network name, and then click Configure.
In Wireless Network Properties, specify the wireless network key (Wired Equivalent Privacy) settings, or, if the network key is automatically provided for you (for example, the key is stored on the wireless network adapter given to you by your administrator), select the The key is provided for me automatically check box. If you are unsure about whether a network key is needed or which settings you need to enter, contact your network administrator or the wireless network adapter manufacturer.
Important
If a network does not broadcast its network name, it will not appear under Available networks. To connect to an access point (infrastructure) network that you know is available but that does not appear under Available networks, under Preferred networks, click Add. In Wireless Network Properties, specify the network name (Service Set Identifier) and, if needed, the wireless network key settings.
Computer-to-computer (ad hoc)
To connect to an existing computer-to-computer (ad hoc) network, under Available networks, click the network name, and then click Configure.
If you want to connect to a computer-to-computer (ad hoc) network and both computer-to-computer and access point (infrastructure) networks are within range of your computer, click Advanced, and then click Computer-to-computer (ad hoc) networks only.
To configure a new wireless network connection, click Add, and then do the following: •
If the network connection that you are configuring is to a computer-to-computer (ad hoc) network, select the This is a computer-to-computer (ad hoc) network; wireless access points are not used check box.
To change the order in which connection attempts to preferred networks are made, under Preferred networks, click the wireless network that you want to move to a new position on the list, and then click Move up or Move down.
To change the wireless network connection settings for a network that is listed in Preferred networks, click the wireless network for which you want to change settings, click Properties, and then change the settings as needed.
To remove a wireless network from the list of preferred networks, under Preferred networks, click the wireless network that you want to remove, and then click Remove.
To update the list of available networks that are within range of your computer, click Refresh.
To automatically connect to available networks that do not appear in the Preferred networks list, click Advanced, and then select the Automatically connect to non-preferred networks check box.
To open Network Connections, click Start, click Control Panel, click Network and Internet Connections, and then click Network Connections.
When you enable automatic wireless network configuration, you can connect to an existing wireless network, change wireless network connection settings, configure a new wireless network connection, and specify preferred wireless networks. You will be notified when new wireless networks are available. After you select a wireless network, your wireless network adapter will be automatically configured to match the settings of that network, and a network connection attempt will be made.
To configure settings on the Wireless Networks tab, you must be logged on as an administrator, and you must use a wireless network adapter that supports the Wireless Zero Configuration service. If you are unsure whether your wireless network adapter supports the Wireless Zero Configuration service, contact your network administrator or the wireless network adapter manufacturer. For more information about automatic wireless network configuration, see Related Topics.
If you are using third-party wireless networking software, clear the Use Windows to configure my wireless network settings check box.
If you are unable to connect to an existing wireless network and the name of the network that you want to connect to appears under the Preferred networks list, click the preferred network name, and then click Properties. In Wireless Network Properties, review the settings to ensure that they are correct. If you are unsure whether the settings are correct, contact your network administrator or the wireless network adapter manufacturer.
If the Preferred networks list includes both access point (infrastructure) and computer-to-computer (ad hoc) networks, you cannot move a computer-to-computer network to a position in the list that is higher than the position of an access point network.
To provide enhanced security for 802.11 wireless networks and for wired Ethernet networks, IEEE 802.1x authentication is enabled by default. For more information about how to set up 802.1x authentication.
Hope this helps
Dec 12, 2010 | HP Broadcom NetXtreme Network Adapter
How to find the network security key on wrt54gh
1. Step 1 Open your web browser, type " http://192.168.1.1/ " into the address bar andhit "Enter." 2. Step 2 Use"Admin" as the username in the pop-up box and leave the passwordblank. 3. Step 3 Connect to the Internet and click on "InternetSetup." 4. Step 4 Select your connection type from the drop-down menu.Choose "DHCP" for cable modems or "PPPoE" for most DSLmodems. If you are unsure of these options, check with your ISP. 5. Step 5 Set a service set identifier (SSID) to identify therouter and change the password. 6. Step 6 Encrypt your wireless connection using a WirelessEncryption Protocol (WEP) key. Under the "Wireless Security" option,enter a passphrase and click "Generate." This will generate apassword which will need to be used by any client connecting to your router.
Dec 02, 2010 | Linksys Wireless-G WRT54G Router
Virgin has installed. D link wireless router (home address) I have 2 laptop xp window vista and pc upstair they detect the vg 50Mb broadband but can not connect ! When I go with my 2 lap top elsewhere I...
1.
2.
3.
• To enable automatic wireless network configuration, select the Use Windows to configure my wireless network settings check box. This check box is selected by default. For information about what happens when you enable automatic wireless network configuration, see Notes.
• To disable automatic wireless network configuration, clear the Use Windows to configure my wireless network settings check box.
4.
• To connect to an existing access point (infrastructure) network, under Available networks, click the network name, and then click Configure.
Important
• If a network does not broadcast its network name, it will not appear under Available networks. To connect to an access point (infrastructure) network that you know is available but that does not appear under Available networks, under Preferred networks, click Add. In Wireless Network Properties, specify the network name (Service Set Identifier) and, if needed, the wireless network key settings.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 30, 2010 | D-Link DIR-300 Wireless Router
How do i replace apassword installing a used router apparently it has old password in it.
We are going to reset your password.
On a computer connected to the linksys now.
Click the link below
192.168.1.1
On the page that comes up, it will ask for a username and password.
type in admin for the password, leave the username blank
You are inside the router..
Click on wireless, then right under it click on wireless security.
Where it says, PSK / Passphrase / Or Network key .. There is a text box to the right
In that text box is your password.. If it looks like **************
You will have to type in a new password, and click apply / save settings.
Then.. The router will restart..
You have now found out, or reset your wireless password.
***Note*** If you changed the password.. The current computer will also have to reconnect to the network, and enter the new password.
Let me know how this worked out for you. If my solution helped you, please rate this solution!
It doesn't cost anything and only takes a second, but it is greatly appreciated.
KittyTech
If you need further help, reach me via phone at https://www.6ya.com/expert/carolyn_427ff26936286336
Aug 26, 2010 | Linksys Wireless-G WRT54G Router
I need help to get my sons xbox working with a wireless adapter
Hi Joanne,
If the wireless adaptor is the one shown in your picture, you simply plug it in the back in the USB slot.
Configure your wireless settings loadTOCNode(2, 'whattotry');
  1. Go to My Xbox, and then select System Settings.
  2. Select Network Settings.
  3. Select Configure Network.
  4. On the Basic Settings tab, select Wireless Mode.
  5. Select Scan for Networks.
  6. Select your wireless network name. If your wireless network is not listed, select Specify Unlisted Network and enter your wireless network name.
  7. Enter your wireless network password, and then select Done.
  8. Press B on your controller to retest your connection.
Kind regards
m-press.biz
Jun 15, 2010 | Microsoft Wireless Network Adapter Xbox...
When trying to access wireless conection signal strength is 100%, yet association fails and connection status says dissconnected. error code 011. what does this mean? how can i fix?also how do i verify...
it depends on the router you use go to start all programs under accessories look for Run, cick run then in the run window typ CMD then press enter, then in the Dos prompt type IPconfig then press enter it will show the ipaddress and default gateway ofr your router copy the default gateway type it in Interent explorer tha should open a page where your router settings are it will ask for apassword and user name which you must know to access the router settings and be able to get the network key from the router to be able to input in your computers wireless settings to gain acces to the router and wireless internet, Call your internet service provider if you can remeber having a user name and password,
for Edimax routers user name is admin password should be 1234, linksys user name admin password eitheradmin as well or leav it blank, and yeah for further info under the router there should be a sticker with the router default user name and password on it if not on the sticker call your ISP or whoever provided the router to you for the router user name and password ^_^ hope this info will be helpfull to you ^_^
Jun 05, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
I want to protect my computer by setting apassword to my router how
in the address bar you need to type the gate way it ask for user name and password you need to enter and you can find wireless in that you can find the security in that you can type your password its minimum 8 digits then save then its secure
Feb 25, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Tries to connect sees wireless network and continues to try and connect but never will
when you try to connect to the wireless network does it ask for the wireless password ?
If your wireless network is secured then it should ask you for the password of the network.
You can try to remove the network from the preferred network list.
Also check the wireless settings of the router.
Make sure that you have all the correct wireless settings.
To check the wireless settings of the router , you will need to open the router set up page.
Click here for more information about the routers and wireless networks
Jan 31, 2010 | Linksys WPC54G Wireless-G Notebook Adapter...
I misplaced my cd to connect my other laptop to the wireless router, WRT54G, and I'm trying to get it through your site
If your router is already set up and you want to add a new computer, you don't need to run the set up CD for the router again.
If you want to add a new wireless device ( laptop or any other wireless device) to the network, then you should know all the wireless settings of the router. What wireless settings do you need to know ?
You should know the wireless network name ( SSID ), wireless channel and the wireless security password
( network key ). Once you get all the wireless settings of the router , you will need to connect to the wireless network on the computer. when you try to connect to the network , you will see your wireless network in the list. You just need to select your network and connect to it. If it is secured then you will need to enter the network key and you will be able to go online.
To check the wireless settings of the router , you will need to access the router set up page. On the set up page you will find all the wireless settings of the router.
Click Here for more info
Dec 19, 2009 | Linksys Wireless-N WRT150N Router
How can i make apassword on my dsl
go here http://www.portforward.com/guides.htm and then got to wireless security guide
Sep 10, 2009 | D-Link DSL 500 (DSL-500) Router
Zhone (6218-I2-200) Router Logo
447 people viewed this question
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
