Question about Sony DAV-FR1 System
Needwire diagram for hooking up a Sony DAV-FR1 Surround Sound to CABLE BOX
How to connect to cable box
  • 231 Answers
SOURCE: Sony HDZ235 HDMI
use component outputs of that unit to play on tv.Or use component or video output of sony unit and connect to cable box if available and use the source switching on cable box to change sources that way you wont have to unplu HDMI cable..By the way HDMI has a new challenger in the near future called ' DISPLAY PORT' ..
Posted on Dec 03, 2007
SOURCE: Sony surround sound hookup
Did you get a reply? I need the same answer
Posted on Jan 08, 2008
SOURCE: surround sound
How do I hook-up my surround sound system with powered sub woofer to my Sony stereo receiver and sony dvd player?
Posted on Dec 15, 2008
  • 21 Answers
SOURCE: Sony Bravia Dav-HDX279W and comcast HDTV Cable box connection.
Like above, use an optical connection (need fiber optic cable) or a coaxial connection (single RCA cable). HDMI might also work, but I personally haven't checked. Connect the audio outs from the cable box to the audio ins on the home theater. The TV will only need a video connection from the cable box, as well as one from the home theater (for DVDs, onscreen menus).
This discussion can help you set up the universal remote.
Posted on Feb 20, 2009
welcomejee
  • 10594 Answers
SOURCE: Surround sound to work with sky+
I think it should work if sky+ transmit surround sound signal.
How do i connect to sky hd and sony kdl 40w 4710 and dav-is10 i have hdmi from skyhd to tv and hdmi from home cinema to tv what else is required as i cant get surround sound from tv
you need a Optical audio cable, run this from the back of your Sky HD box to the Surround sound. Not all Broadcast are transmitted in DD so press your i button on the sky remote and you will see this on the yellow bar above the program information if it is..
Might be worth running a set of White and Red audio cable from the HD box to the Surround sound as well that way you can just mute your telly and have the lot coming through the surround sound system.
Hope this clears things up for you
Little Dish Fitter
Jun 05, 2009 | Sony DAV-IS10 System
hi yes it is....
wot u need to do is.....our red and white audio leads go from sky box to dvd box...we then put our dvd player onto video 1 using function button on remote
hope this helps
Feb 20, 2009 | Sony DAV-S300 System
Hooking up sony dav-hdx 475 with digital cable box and hdtv
Plug the digital cable box audio strait into the dvd player. Plug video from the digital box into your tv.
Thats what i did and it works perfectly.
Jan 04, 2009 | Sony DAV-HDX500 System
Nov 18, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Problems with hearing sound from bravia LCD tv through bravia DAV-HDX275 theatre system
The fiber optic port on back on your bravia tv is only for when your using a over the air antenna and watching local atsc channels in your local market. You need to run the fiber optic from your hd cablebox if it has one or your hd sat box if it has one. If you don't have a set top box with the fiberoptic port on it you can use a digital coax cable from the cable or sat box to sound system. The only other way to get sound if you don't have a cable or sat box is to run the red and white rca audio cable from the tv to the sound system and got to the audio setup on tv and turn the tv speakers off and you might have to adjust the audio to fixed instead of variable.
Nov 05, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Surround sound
Sep 19, 2008 | Sony DAV-HDX500 System
Using the speakers to listen to other componest of my stereo system
Yes, you could have two complete systems crossing over to each other but the sharing will only be in Stereo either way and you will have to decide which one you want to be the Home Base for the other. I would think the deciding factors would be 1) Do you want multiple channel sound; 2) Are your existing speakers far superior to the DAV-FR1's?
DAV-FR1 in charge: If your receiver has one unused Tape (*) or Line Out pair, run a pair of RCA cables to the DAV's SAT Audio In and when you want to hear its attached program sources choose SAT on the DAV. You could also leave the 4 speakers in place or arrange them to augment 5the DAV and hear them all.
* If you use a Tape Line Out pair DON'T select the Monitor on the source or it will de-select any non-tape source going Out to the other Receiver.
Your receiver in charge: Run the DAV's Audio OUT (L/R) jacks to any Line Level input on the receiver (AUX, Tape In).
If whichever direction you wish to use doesn't have a spare Line Input or Output get yourself a pair of RCA cable splitters of the appropriate gender (one male end / two female ends) and share the jacks. Just make sure whichever source you're NOT intending to hear has something inactive selected.
You could even have both. but you would have to take care to NOT induce a circular loop by having each selecting the other as a source.
Feb 10, 2008 | Sony DAV-FR1 System
In short, the answer is: Hook up all three to each other. I have a Samsung DLP HDTV, and I was trying to hook up a Sony DAV-HDX500 home-theater system and a Comcast HD set-top box, but I found that the Sony user guide is helpful only for setting up the speakers. Most of what it had to say about HDMI and getting the TV sound or cable sound to go through the speaker system was wrong (or, at least, it didn't work for me). So, here's what I did. I connected Component video cables (Y/Pb/Pr out) from the Cable box to the TV (Y/Pb/Pr in), audio cables from the Cable box (audio out) to the Sony system ("SAT/Cable" audio in), and an HDMI cable from the Sony system (HDMI out) to the TV (HDMI in). This allows me to 1) watch DVDs with surround sound through the TV's HDMI source (when the "DVD" format is selected on the Sony system), 2) watch cable with surround sound through the TV's Component source (when the "SAT/Cable" format is selected on the Sony system), and 3) watch cable WITHOUT the surround sound, as I did before I ever had the Sony system. One item of note: When watching a non-HD channel with the surrond sound on, the audio is slightly out of synch with the video; thankfully, there's no such problem on HD channels. Anyway, I hope this helps. It drove me crazy for two days straight!
Dec 31, 2007 | Sony DAV-HDX500 System
Sony DAV-FR1 System Logo
19 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
