Question about Garden
Even when I prime my 32cc craftsman weed eater. it will not start. i spray carb. cleaner in the carb. it will start and stay running. The problem I guess is cold starting problems. Any help would be appreciated.
    Sergeant:
  • 316 Answers
Hello sir, my machine will only start when pumping primmer bulb or squirting fluid in the carburetor than stops. the fuel line has broken off, in most small carburetors this is a ongoing problem.old fuel will crystallize when left in tank for a long time.plugging up ports, fuel lines, small screen in carburetor.fuel lines will dissolve clogging carb.this is why it will run when the choke is on creating a vacuum to where there is fuel forced in the carb to rum,also the gas will evaporate leaving the oil behind clogging up carb.the thing to do is remove carb. and clean out,replacing gaskets or fuel line if necessary.use carb cleaner to clean out carb.make sure to make note where fuel line go.the fuel filter broke off of fuel line letting debris get in carb plugging it up.the muffler is known to clog up a lot on these machines where they want run. the compression should be 60 to 120 lbs any thing below 60 is junk. when adjusting the carb screws turn in all the way than turnout 1 1/4 turns turn in slow until machine runs also you need to check for spark by removing plug and grounding against engine to check spark, ok.a new spark plug would be a good ideal too , if you are going to make these repairs use new fuel line and filter,hope this helps,any comments welcome,thank you, --
Posted on Feb 21, 2012
slohry
  • 87 Answers
SOURCE: fuel hoses routed wrong on weed eater fuel tank
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=358795190&productCategoryId=1503820&brandId=0247&modelName=TRIMMER&diagramPageId=00002&componentDescription=CYLINDER/FAN%20HOUSING/CRANKCASE&documentId=P0303202&backToLink=Return%20to%20Sub%20Components%20list
Posted on Apr 10, 2009
  • 109 Answers
SOURCE: Snapper SS312 weed eater. Cranks when primed but won't run
I am sorry to say this, but the compression for that type of engine should be atleast 120 psi. Remove the muffler and look at the cylinder, it is scarred beyond repair.
Posted on Apr 22, 2009
#1 Taper
  • 1041 Answers
SOURCE: craftsman 32cc weed eater wont start. Push in the
Check the fuel lines for cracks/breaks. If they are o.k., then:
You willneed to disassemble the carburetor and spray with carb.cleaner. Makesure the small screen is free of debris.(Should be able to see daylightthrough it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Posted on Jun 28, 2009
SOURCE: repairing fuel line on craftsman 32cc weed trimmer.
Cut the end of the line at a sharp angle. Spray WD-40 on the line and fuel tank hole. Slowly screw the line in the tank far enough so you can connect the fuel filter if you are replacing that line. If not just push the line into the tank if you have a two line system. Remember on the fuel primer, the long tip has the line going to the tank, and the short tip has the fuel line going to the carb.
Posted on Sep 05, 2009
rycgl
  • 1545 Answers
SOURCE: I would like to how the fuels lines go on my sears
The small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb.If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank
Posted on Oct 04, 2010
Weed Eater Priming
Check out the tubing to the carb. If it is good then the top part of the carb with the check valves is defective. If so, you need a new carb since those suckers cannot be fixed.
Aug 21, 2016 | Craftsman Weed Wacker Lawn Edgers
I push primer on craftsman 32cc weed wacker trimmer and gas just runs out carb all lines are hooked up properly any suggestions
its supposed to,thats where the gas goes when you prime it,hold it up or choke it to start
Apr 17, 2015 | Craftsman Garden
Weed eater troubleshooting
Check the ground wire from the switch. The kill switch uses ground to kill the engine.
Aug 20, 2014 | Craftsman Convertible 32cc Gas Line...
Hi curtis, i have a craftsman 32cc bushwacker weed eater. i had to replace fuel line in tank with filter. i also replaced the second line in the tank which is alittle larger in diamiter. i have a primer...
change the fuel lines over on the carby
you are trying to feed fuel through the primer line when the engine is running and that is why it is cutting out
Mar 12, 2017 | Garden
I have a Craftsman 32cc weed trimmer, can't give gas, it stalls
Usually the diaphram is wore out. It is a relatively inexpensive part. Does it run better with a little choke? If the answer is yes chances are it's the diaphram. Also sometimes the adjustment screws can move. There are two, one for low speed, and one for high. With the engine warmed up make small movements on the screws (some are marked low, and high) in, and out adjust til the engine runs at its optimum.
Hope this helps!
May 04, 2010 | Craftsman 25cc Gas Line Trimmer
Craftsman 32cc weed eater wont start. Push in the primer bulb and it does not refill, stays stuck in!
Jim
Jun 27, 2009 | Craftsman 25cc Gas Line Trimmer
My 32cc craftsman weed eater was running fine.when it ran out of gas i refilled the tank and pulled an pulled nothing check spark, ok,an still it wont fire up. thanks for any help.
check for trash in the carb somtimes when you run then out of gas small peices of dirt or on older motors residue builds up in gas tank and it gets sucked into the carb there should be a screen that you can clean
May 07, 2009 | Craftsman 25cc Gas Line Trimmer
Fuel hoses routed wrong on weed eater fuel tank
Apr 04, 2009 | Garden
Garden Logo
114 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
