Question about HP LaserJet P2015dn Printer
Printing problem with HP 2015 Laserjet Printer
My Hp 2015 printer keep on displaying the "Paper Out Light Indicator" and I have loaded the paper tray with much sheet (A4-size) BUT the printer is refusing to print.I Even try to print a test page using the "GO button" but it refused to print.
I tried several attempts by restarting the printer and after restarting , the same Out of paper indicator will remain ON.
Can I any help me out?
I was given this machine as a project and i need help pls,mail me o tobi_bada@yahoo.com...wait to read from you
Posted on Sep 13, 2011
I had the same problem.
I put 10, 20 pages in and the light indicator keeps on blinking.
After I put the tray full of paper (100) than the indicators stops blinking. There is a handle that reacts when he feels something (paper). I lost half an hour with this avoidable problem.
I wonder what will hapen if I place this printer in production and my colleagues will be confronted with a light indicator when there are 50 pages in it.
Posted on Dec 09, 2008
  • 39 Answers
If you have an adjustable paper tray, make sure that the tray is set for the right size paper. Also, you may have some type of sensor in or around the printer tray that tells the computer when the paper tray is empty. Sometimes these sensors get stuck and you have to free them up (very gentley).
Hope that helps - Ghost
Posted on Oct 29, 2008
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Hp laserjet p2055dn tray1 manual feed problem
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
Aug 01, 2012 | HP LaserJet P3005n Printer
On the top of the hp 2015 there is what looks like an 8 with like a sideways N next to it that keeps lighting up on my printer and inhibiting it from printing-- I don't have a manual to tell me what means.
Hello, The printer is indicating a Paper Jam.
Check the tray for proper paper loading, length and width. Check the rear exit, any paper back there? Check under the toner cartridge for loose papers.
1) Turn the printer off 2) Remove the main paper tray 3) look inside the hole in the printer from where the tray came out. You should see black rubber roller. paper dust can build up on this roller and cause the paper to slip. You can wipe this roller down with a water dampened lint free cloth, 4) Re-insert the tray, with paper in the tray. 6) Turn the power on to the printer. 7) Does the printer come ready? Print a test page.
For further information GOHERE
Feb 03, 2011 | HP LaserJet P2015 Printer
Tell me please hp laserjet printer 2420 paper tray setting
    1. Remove the packing material from the printer.
      1. Remove the all orange tape from the outside of the printer.
    1. Load all paper trays.
      1. Pull the paper trays completely out of the printer.
    2. Press the blue tab on the rear paper length guide and adjust the rear guide so that the pointer matches the size of the paper to be loaded. c00318778.gif
    3. Move the side width guides outward to match the desired paper size. c00318779.gif
    4. Add the media to the paper trays, make sure that it is flat in the tray at all four corners. Keep the media below the height tabs on the sides and rear of the tray. Push down on the metal lift plate to lock it in place. c00318780.gif
    6. Install the print cartridge.
      1. Remove the print cartridge from the packaging.
    7. Rock the print cartridge back and forth several times to "mix" the toner. c00318783.gif
    8. Pull the sealing tape from the end of the print cartridge to remove the entire length of the tape. c00318784.gif
    12. Connect the LAN cable (optional). (HP LaserJet 2420n, 2420dn, 2430tn, and 2430dtn models only) c00318788.gif
    Jan 13, 2011 | HP LaserJet 2420 Printer
    Hp laserjet 2015 printer shows an indicator light error that theres a paper jam but actually no paper jam or paper particles . I have cleaned aii the sensors and checked the paper path. Powers on well...
    restart it
    if problems insist check if sensors are working
    if are working you need to replace motherboard
    of your printer that cost to high
    you better replace your printer
    hope i had help you
    Nov 26, 2010 | HP LaserJet P2015 Printer
    My hp laserjet 3005 does has paper loaded in try 2 but always prompts me to load tray 1 to print. I would like the printer to print from tray 2 when it's loaded and try 1 is not loaded. Thank you.
    Thank you for contacting FixYa with your printer inquiry.
    This is a common problem. The device can be set to print from tray 1 if it is loaded, or to print only from tray 1 if the type of media selected is other than standard bond.
    Pull out tray 2 and make sure the paper size adjustments are properly set to match your size of paper. If you are using std bond and the adjustments are set to A-4 it won't pull paper.
    HP Control Print Jobs Support Page: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=115&prodSeriesId=1846088&prodTypeId=18972&objectID=c00764862
    HP Support Page: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00764851&lang=en&cc=us&taskId=101&prodSeriesId=1846088&prodTypeId=18972
    Hope this helps helps. Please keep us updated and remember to rate this answer.
    Sep 02, 2010 | HP LaserJet P3005 Printer
    The out of paper light keeps poping up whens there is plenty of paper
    Check that the paper level indicator is showing paper as being loaded in the tray. Occasionally it will slip and get out of alignment. It is usually just a matter of realigning the indicator.
    Aug 31, 2010 | HP P2035N LaserJet Monochrome Printer
    HP laserjet 4L paper jam after printing one page.
    You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
    Aug 31, 2009 | HP LaserJet 4L Printer
    I have a HP LaserJet 1320n printer and it will not print. An orange light keeps flashing by the triangle with an exclamation point in it. I printed a test page and it was okay. It will not print...
    Possible Solution to your issue!
    Blinking Attention Light HP LaserJet 1320 Series Printer - The printer displays an orange blinking attention light which will not clear. This usually indicates one of the following issues have occurred. Perform the following in the order provided to troubleshoot and resolve the issue.
    1. Insufficient power. Disconnect the power cord from any surge protectors or power strips and plug the unit directly into an electrical wall outlet.
    2. There is a paper jam in the printer.
    3. The top cover is open. Open the top cover, reseat the print cartridge, and close the top cover, making certain it is shut properly.
    4. No paper was loaded in tray 2 or the tray was not loaded properly causing a mispick. Perform the following steps to load tray 2.
    A. Pull the tray out of the printer and remove any paper.
    B. Move the blue side width guide outward to match the paper size that is being loaded. Locate the blue guide pointer on the left side of the tray. If using a letter-size (8.5 by 11 inch) paper, match the guide point with the LTR/LGL engraving located on the bottom, left-side of the lift plate.
    C. Locate the blue tab on the rear paper-length guide. Locate the triangle-shaped pointer in the middle-right on the bottom of the tray. Press on the blue tab and adjust it so that the triangle-shaped pointer matches the paper size that is being loaded. If using letter-size (8.5 by 11 inch) paper, match the triangle-shaped pointer with the LTR engraving on the bottom of the tray.
    D. Place the paper in the tray and make sure that it is flat at all four corners. Keep the paper below the height down arrows on the paper-length guide in the rear of the tray.
    E. Slide the tray back in the printer.
    5. The tray 2 paper level indicator is stuck.
    6. If the printer comes back to a Ready state, print a Self-Test/Configuration page. If the printer is not in a Ready state, proceed to step 7.
    A. Verify the printer is in a Ready state. (The green LED next to the U-shaped icon is on steady and no other lights are on.)
    B. Press down on the green GO button until the orange Attention light comes on (approximately 5 seconds), and then immediately release the GO button. The green GO button will begin to blink and a Self-Test/Configuration page will print.
    7. If the attention light is still on, perform a cold reset. A cold reset, sets most, but not all, default variables stored in NVRAM back to the factory default values. It typically does not reset the page count, paper tray sizes, localization language, or formatter number. Complete the following to perform a cold reset.
    A. Turn the printer off.
    B. Press and hold down the green GO button.
    C. Turn the printer on and continue to hold the green GO button for at least 5 seconds, but not longer than 15 seconds. During the process, the Attention LED will turn on.
    D. Release the GO button.
    NOTE: If both the Attention light and the Ready LEDs turn on before the GO button is released, the cold reset procedure must be started over at step 1.
    E. The printer LEDs begin cycling. The cold reset process runs until completion and the printer returns to the Ready state
    Feb 23, 2009 | HP LaserJet 1320n Printer
    HP LaserJet P2015dn Printer Logo
    632 people viewed this question
    Seeker5211
    Seeker5211
