Konica 1212 whenever I turn on my photocopier the error code F09 appears. How can I fix it?
  • 145 Answers
Current flow to frame ground is detected. This may be caused by an external power surge or internal arcing.
To reset the code:
a. Power the copier OFF.
b. Access the 25 mode (power the copier ON while simultaneously pressing the 2 and 5 keys), P49 to 0.
IT COULD BE A NUMBER OF THINGS,,,BUT TRY THIS FIRST..
LET ME KNOW
HOPE THAT HELP
Posted on Oct 28, 2008
HOW TO SOLVE ERROR CODE C0500 FOR KONICA MINOLTA 211
Error code C0500 and C0501 means Fixing unit's temperature abnormality.
How to reset these codes?
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
http://servicekonicaminolta.blogspot.com/2012/03/error-code-c0500-and-c0501.html
Jun 14, 2017 | Konica Minolta Office Equipment & Supplies
Error code P9 and P21 appears on screen and when printing or photocopying using color black, blank copies are outputed
hi piz Error code P9 and P21 appears on screen and when printing or photocopying using color black, blank copies are outputed
Apr 29, 2010 | Konica Minolta bizhub C250 All-In-One...
I have a konica photocopier modeal 1212, it doesn't work at all and shows P27. what does this means. thanks
The P 27 code is the change the toner.Please change the toner close the doors if the machine it turn OFF press and hold the 4&5 keys and turn ON the copier.Change using the ZOOM key 47,50,51,52 and press the START button the perform the toner setting.
Aug 13, 2009 | Konica Minolta Office Equipment & Supplies
Bizhub 420 Photocopier
Have you check the Printer control board. Also does the toner bottle turn? You can force it in 47 Mode. to turn the bottle motor CW or CCW
May 06, 2009 | Konica Minolta Office Equipment & Supplies
Error code f35
konica f 35 eror code
Aug 06, 2008 | Office Equipment & Supplies
Error code F35 on my konica 1212 photocopier
That's a fuser error condition...I'll have to get back to you because i have to check in my book to remember how to reset it...Thank you for your patient !
Mar 19, 2008 | Office Equipment & Supplies
Error code 27
The error code p27 the toner density sensor unplugged/dirty/faulty
Any problems please get back to me
thank you
Feb 19, 2008 | Office Equipment & Supplies
Konica photocopier
My service info doesn't go back that far either, but this procedure should work to reset the code. However, I would make sure there's no toner build-up on the fuser thermistor or thermostat first, otherwise the code will reappear.
Here's the instructions on clearing the code:
Enter the 25 mode by holding down the 2 and 5 keys while turning on the copier.
Press the P key, then enter 47, then press P again.
Enter 0 and press the Print key.
Turn the machine off/on to exit the 25 mode.
If the code reappears, then theres a problem. If it doesn't, you're good to go!
Nov 11, 2007 | Konica Minolta DiALTA CF910 Copier
185 people viewed this question
jasbo
jasbo
