Question about Cisco Computers & Internet
Wher can i download cisco connect for BEFSR41
Following LinkSys support; if the powerled flashed, it mains that the firmware is corrupt, I change my PC after my BEFSR41 becomes dead, so my PC do NOT have Cisco Connect, and if I try to install Cisco Connect from the LinkSys CD, I come in a loop because the BEFSR41 is not yet working, And also I cannot install a new firmware ! Ho can I get out of this loop ? Thanks in advance for your help. Knd rgds Fan TWEN
XBRMann
  • 38 Answers
SOURCE: Cisco VPN Client won't connect
You'll want to enable the VPN transparency. In the router's administrative web interface, click the Security Tab, then the VPN Passthrough sub-tab. Cisco VPN's usually use IPSEC, so enable the IPSEC Pass-through and click "Save Settings". If this doesn't work enable the PPTP Pass-through as well and give that a shot.
Posted on Feb 09, 2008
techjuli
  • 157 Answers
SOURCE: cisco 857 router
You might need to reset the password. In order to do this, follow these directions:
  1. Console into the router, then power cycle it. As its rebooting hit the "break | pause" button on your keyboard, and you get to the rommon1> prompt.
  2. Then type rommon1>confreg 2142 rommon2>reset
  3. The router comes back on as if it were new---answer no to the first question, and sometimes it asks a second question (do you want to terminate autoinstall, or something...)---answer yes to the secondquestion if it asks. Then hit enter and you get router> in a few seconds.
  4. Then router>en router#copy start run
create a new account:
  1. router#conf t
  2. router(config)#username bob priv 15 password bob
set register back:
  1. router(config)#confreg 0x2102
  2. router(config)#exit
  3. router#wr
  4. router#reboot
and that should let you login with bob/bob
Posted on Nov 30, 2008
mravikreddy
  • 9 Answers
SOURCE: cisco router startup config
yes thats possible.
Posted on Dec 18, 2008
  • 286 Answers
SOURCE: cisco 1721 router serial port not showing any loop.
the problem is with your modem....did you tested the local loop from router to modem....are u getting local loop from one modem till router or not...try first checking local loop from modem to router...
Posted on Feb 11, 2009
SOURCE: installation of cisco asa 5510 firewall
The problem is your version of java, you need to uninstall java 6 update 11 or 12 and install java 6 update 6. you can download this from the archive section at the java web site. I had the same problem but this solved it.
Good luck
pls send me a line if your problem is solve
asowe@lastingsolutions.gm
Posted on Mar 10, 2009
Why is the cisco light flashing on my Linksys router after a power outage?can't connect to internet
It is due to some internal problem with setting. first, resetting the router and update wireless adapter driver on the device and change your wireless settings.
Downloading the latest firmware for your router if possible.
I think it will give you some ideas.
Apr 30, 2014 | Cisco Computers & Internet
Can i hook my westell 327w to a linksys befsr41
Absolutely, it is as simple as plugging in the westell to the befsr41. However all that will do is split the cable so it can accomodate multiple devices. BUT, the befsr41 is a wired router, to go wifi pick up a wireless router. This wireless router replaces the befsr41. I like the linksys (Cisco) 1000 or the 2000. If they have the Wrt54g thats best. Good luck! Dont worry it is pretty simple.
Jan 01, 2012 | Computers & Internet
I forgot the password for cisco befsr41
To fix this problem all you have to do is access your router and leave the username blank and type admin for the password. To access your router put this http://192.168.1.1 into your browser address bar.
Apr 23, 2011 | Cisco Linksys EtherFast Cable/DSL Router...
I bought a Linksys BEFSR41 Cable/DSL Router W/4 Port, it dosnt seem to work with windows 7 and i dont know why, need help...
pcnn
To get this right,you're also going to need your hardware version number.It's on the same sticker that all the info is.It'll be 1.0,2.0 or 2.1.
Go to the link below,it will take you to the support page for the router.It doesn't include Windows 7 drivers,but it should run on the Vista drivers.
Read the different links to info and see if it can answer your questions.Probably so.
You can also download firmware for the different hardware versions.If what's listed there is newer than yours,you absolutely want to install the firmware.
You also want to go to the Linksys router setup page and go through the wireless and network setup processes again.I have to do that periodically with my D-Link because the power fails here a lot and it resets to default.
Let me know what happens,and if you need,I'll keep trying.
For good or bad,please rate my post?
Thanks
Bob
http://homesupport.cisco.com/en-us/wireless/lbc/BEFVP41
The url for Linksys to set up your router is 192.168.1.1
Aug 11, 2010 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Losing connection constantly, when I hok up computer directly to the modem I have no problems, but with the router my internet does not work. The lights on the router are flashing and indicate that it is...
have you done a chat with Linksys? What do you use to manage your network?
May I suggest you get Network Magic, a free download and eval period.
Using Network Magic, you may find you have settings on the router that prevent your getting past your 'fire wall'.
Oct 12, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys router limits speed to 5 meg.
Try to access the router's setup page and change the MTU settings. The default address for the Befsr41 is 192.168.1.1. Here are instructions:
1) Use a computer wired to the router.
2) Launch a browser and type in 192.168.1.1, leave the username blank and the password is admin or the password you have set when you first configured the router.
3) Click on the Advanced tab then click on the Filters tab. On the bottom part you have MTU.
4) Enable that option and set MTU to 1500, 1400, 1300 (for cable ISP connection) and 1492 (for DSL connection) and check if it will work.
4) If that does not work, you can try upgrading the firmware of your router.
Apr 29, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Idle
befsr41 it seem to be a old router......and it have old firmware on it.....so upgrade latest firmware ....and i hope you will not any issue with the router.
Apr 06, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Firmware update.
Get the latest firmware Upgrade from Website
www.linksys.com/downloads
Mar 08, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Red Diag light blinking on the BEFSR41
This is caused by the firmware not loading correctly. Follow the steps below to fix this: 1. You will need to gain Internet access to download the latest firmware for your router. The firmware must be present on the computer that will do the upgrade. Temporarily bypass the router and plug directly into your Internet Service Provider?s modem to gain access, or use another location other than your own to get to the Internet and download the firmware. 2. Download the latest firmware for your router from http://www.linksys.com/download/firmware.asp. Select the model number of the Linksys router you have (BEFSR41) as firmware upgrades vary by model and version (select BEFSR41, do not select BEFSR41 Ver. 3 ). 3. Click the ?Get Upgrade? button. 4. After the firmware page opens, click the link that says, ?Click here to download the latest firmware...? and download the firmware file. 5. Once you download the Zip file, unzip it and extract all files. If you do not have an unzipping program, go to http://www.winzip.com and download WinZip, which will allow you to unzip the file. Before performing the upgrade, assign your computer a static IP address. For more information, please see Answer ID 534 for instructions. If using a 10/100-network adapter, change its speed to 10Mb, half duplex. For instructions on doing so: Windows 95/98/ME 1. At the Windows desktop, click on Start then choose Settings and click on Control Panel. 2. Double click the Network icon. This will bring up the ?Network Configuration? window. 3. Locate and highlight the icon with the green logo for your network adapter and click Properties. 4. This will display the network adapter's Properties. 5. Select the Advanced tab and click Connection Type (this may also appear as Media Type, Connection Speed, Mode, Link Speed, etc). The current default value should be set to "Auto sense" or "Auto". 6. Change the value of this option to 10Base-t, half duplex mode (usually the lowest possible option). The wording of this value may also vary, depending upon the make and model of the Network Adapter. Other possibilities include 10T half, 10Mb half duplex, 10Mbps half, etc. 7. Once this has been changed, click OK to return to the Network configuration screen. 8. Click OK again and Windows will ask to restart your computer. Click ?Yes? to restart. Windows 2000/XP 1. Go to Start click on Run and type in control ncpa.cpl. 2. Double click on the Local Area Connection that controls your network card. 3. Click Properties under Local Area connection status. 4. Click the Configure button. Then, click on the Advanced Tab. 5. Click Connection Type (this may also appear as Media Type, Connection Speed, Mode, Link Speed, etc). The current default value should be set to "Auto sense" or "Auto". 6. Change the value of this option to 10Base-t, half duplex mode (usually the lowest possible option). The wording of this value may also vary, depending upon the make and model of the Network Adapter. Other possibilities include 10T half, 10Mb half duplex, 10Mbps half, etc. 7. Click OK after you made the change then click Close. Reloading the firmware 1. First, hold the reset button located on the back of the router for 30 seconds. 2. Next, to test communication between the Router and the network card: Go to Start, and select Run. Type in command and press [Enter ]. This will bring upthe MS-DOS promptwindow. 3. Type ping 192.168.1.1 and press [ Enter]. 4. You should get the following results: Pinging 192.168.1.1 with 32 bytes of data: Reply from 192.168.1.1: bytes=32 time<10ms TTL=128 Reply from 192.168.1.1: bytes=32 time<10ms TTL=128 Reply from 192.168.1.1: bytes=32 time<10ms TTL=128 Reply from 192.168.1.1: bytes=32 time<10ms TTL=128 5. Once you get these replies, close out of the command prompt by typing in exit and pressing [Enter ]. 6. You may now proceed to upgrade the router?s firmware with the files that were downloaded. 7. Once the upgrade is complete, the router's red Diag light should no longer be blinking. Note: Be sure to go back to your network card settings (from the steps above) and change the speed of the link back to ?Auto sense? or ?Auto? (the original default setting) to restore full speed to the adapter. If any of the steps do not work, or if you are having other difficulties, please contact Linksys Technical Support for further assistance.
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
How to upgrade the firmware on a BEFSR41
Firmware upgrades may erase all previous settings to your router's configuration. Before upgrading your firmware, make sure to record your settings. 1. Unplug and disconnect all computers from the router except for one. This computer must be plugged into the router directly. There can be no other network activity on the router during the upgrade, so be sure to power off all other computers. 2. Go to http://www.linksys.com/download 3. Select the model number of the Linksys router you have (BEFSR41) as firmware upgrades vary by model and version. You can find your router version underneath your router after the model number. For example, ?BEFSR41 Ver. 3?. 4. Click the Downloads for this Product button. 5. Once you arrive on the download page, click the Firmware button. 6. After the firmware page opens, click the link that says ?Click here to download the latest firmware...? and download the firmware file to your computer. 7. Once you download the firmware Zip file, unzip it. If you do not have an unzipping program, go to http://www.winzip.com and download WinZip, which will allow you to unzip the file. 8. After unzipping the firmware files, one of them will be called TFTP.EXE. Double click on it. 9. When the ?Upgrade Firmware? window opens, you will have three prompts. The ?Server? field is for the IP address of your router; by default this would be 192.168.1.1. 10. Enter the routers password into the ?Password? field; by default the password is admin. 11. Browse for the file in the Firmware Upgrade utility program by clicking on the button next to file with the '?' symbol on it. Look for the file named 'code.bin' in the folder where the firmware files were extracted to. 12. Highlight the code.bin file and click on the Open button to direct the TFTP loader program to put that file into the "File" box. 13. The full path should be displayed [example: c:\linksys\code.bin]. 14. Click on the Upgrade button to begin the upgrade process. 15. The upgrade should take about 1 minute, and you will be prompted after the upgrade is complete and successful. If you are still having troubles, contact Linksys Technical Support.
Computers & Internet Logo
43 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
