Question about Delta Plumbing
Installation of delta 3s-10h/c stem - Delta Plumbing
  • pattydelaros
    pattydelaros Feb 20, 2012
    instructions to install
Faucet still running
Change the O rings in the mixer.
Mar 10, 2014 | Danco Faucet Stem
Installed new delta leland 978 kitchen faucet. Water pressure from faucet is low. Cleaned screen and there was no change.Could there be a clog some where else in faucet system?
check the angle stop under sink as sometimes the washer gets lodged in the orifice to stop..make sure water is off to house before removing handle to stop...check the hose...then the stem and seat to faucet itself.
Dec 09, 2010 | Delta Faucet Delta 2578SS-278SS Leland...
I bought a 3h-10h/c but it only works for hot. do you have the same product for the cold side?
The same part works for both Hot & Cold sides. Usually preset to work on Hot (counter clockwise on, clockwise off). To set for Cold, simple remove the plastic clip from the top, slide the ring tab off, flip it over and put back on (you can only put it on one way since there's a flat "key" in it matching the stem) Now its set for Cold (CCW of, CW on). HTH
Aug 05, 2010 | Danco Faucet Stem
I bought a Danco 3H-10H/C, Hot/Cold stem. The problem is, it seems to be setup for hot (clockwise closes the valve, counter clockwise closes it). Is it reversable? Or is it not really a hot/cold...
One of two things has happened. I'm assuming you only get hot water when you open the valve and that this is for a single handle control shower fixture. If so either this is the wrong valve for your shower control or it is installed backwards. Sometimes the valve can be installed at either 180 degree angles. See if it can be installed any other way. If so this may solve the problem.
Jul 18, 2010 | Danco Faucet Stem
Delta single lever faucet leakingafter bing shut off.
Will need to get delta faucet rebuild kit. Available at home depot, lowes or hardware store. It consists of valve stem seals & springs. The larger kit will contain ball assembly. Turn off water to faucet. Unscrew handle via set screw under plastic cap. Unthread cap over ball assembly. Pry out valve seals & springs. Reverse procedure to install.
Jun 26, 2010 | Delta & Single Handle Shower Faucet
Where does the rubber cup with the hole in it and the spring fit?
They go in the bottom of the stem on most two handle faucet's, Remove stem and replace spring and seat onto it.
May 21, 2010 | Delta Faucet DELTA/PEERLESS FAUCET CO....
Can't get stems out after I take off the bonnet of my delta fauc
you will have to gently pry them up and out,or grasp real good and work them out.nothing else is holding them down.
Mar 10, 2010 | Delta Faucet DELTA/PEERLESS FAUCET CO....
Plumbing Logo
477 people viewed this question
Top Delta Plumbing Experts
Donni Steen
Ed Mac
john h
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
