Question about HP LaserJet 3050 All-In-One Printer
How do I fix the squeak in my HP Laserjet 3050
  • 42 Answers
SOURCE: HP LASERJET 3050 SCANNER: ERROR (not set up on pc).
Hey,
did you windows install drivers when you connected this printer?
is the interface usb version or LAN network?
Windows version ?
best regards michael
DIY site 'Why pay when you can play'
Posted on Dec 14, 2007
  • 35 Answers
SOURCE: HP Laserjet 3050 No paper pickup
NOTE:
If the printer DOES NOT PICKUP paper .
That is a jam also so the places to look are smoth rollers or smoth spots on the rollers.
trays not adjusted properly and if they have it some trays have a coustom/standarsd switch (should be in standard for letter/legal paper
Posted on Jun 13, 2008
SOURCE: low memory display on HP Laser Jet 3050
I had the same problem, tried clearing memory, etc. but no luck. Turns out the pages I was sending were printed on a darker colored (purple) paper which made the size of each page very large.
I tried again with the pages printed on light colored paper and had no problem.
Posted on Jul 14, 2008
JackHeath
  • 1049 Answers
SOURCE: MY HP LASERJET 3050 WON'T SEND FAXES
While its possible, I doubt your doing it wrong...
  • Select [FAX], place the paper as indicated on the tray, type the number, and hit send. That's about it.
However, Fax machines will not send when attached to a digital phone network, used over IP phones, or in conjunction with DSL service without the lines being conditioned. This is a small device which hides the higher frequency noise from the fax machine. Any sort of signal shared on the lines may interfere with sending, recieving, or both. If you use DSL for example, I'd almost guarentee this is part of your problem.
Posted on Aug 01, 2008
SOURCE: HP Laserjet 3050 installation
i WANT TO INSTOL PRINTER
Posted on Oct 08, 2008
how do I change the language? everything is in German.
Nov 11, 2008 | HP LaserJet 3050 All-In-One Printer
HP Laserjet 3050 blank print
Have you tried a new toner cartridge? Usually blank pages are due to a missing bias voltage to, or in the cartridge.
Aug 11, 2008 | HP LaserJet 3050 All-In-One Printer
Replacing Print Cartridge
Turns out there was an easy solution. I filed a support case and had an answer in half a day:
"Often this issue is caused by a sensor. â Therefore the first thing we should do is try to trigger the sensor.
1 Turn off the HP LaserJet 3050
2 Remove the toner cartridge from the HP LaserJet 3050
3 Remove all of the paper in the paper tray
4 Check the entire paper path for any obstructions
5 Reseat the toner cartridge and paper
6 Power on the HP LaserJet 3050
If the issue is still not resolved we will need to try some resets on the HP LaserJet 3050.
1. The first reset we can try is a soft reset, it is done by pressing the MENU key then holding *# together. â This will bring you into a Developers Menu. â Scroll through the options until you find reinit FFS and then press the ENTER key.
2. If this reset doesn't clear the issue we can try a harder reset. â We can do this by pressing MENU, scrolling over to SERVICE, pressing ENTER, scrolling over to RESTORE DEFAULTS and pressing ENTER to restore the defaults and ENTER to confirm.
WARNING: Restoring the defaults will clear your fax settings, phonebook numbers and headers so you may want to print a phonebook report and Config Report first. â We can do this by accessing the Reports menu.
3. If these two resets do not help there is a third reset we can try.This reset will completely put the HP LaserJet 3050 back to factory defaults.WARNING: Before doing this reset we will need to disconnect the power cord, the phone cable, and the USB cable from the back of the HP LaserJet 3050.We can do this reset by unplugging the power cord from the back of the HP LaserJet 3050 then holding down the MENU/ENTER key and * symbol at the same time,then powering the HP LaserJet 3050 back on with the keys compressed.We will release the keys as soon as PERMANENT STORAGE INIT appears on the display screen."
I tried all the steps in sequence; it took #3 to fix it. Fortunately I didn't have a big fax address book or custom settings, so a factory defaults reset didn't cause any extra problems. It retained the time and date, and now it works fine.
Mar 12, 2008 | HP LaserJet 3050 All-In-One Printer
Hp laserjet 3050 all in one
Ok fine the same prolem with 3050 . Is haviong the some manufating defect . check your usb cable, reinstall the new driver from the hp site. if the problem dose't fixs pls call the hp help for replacment
Thank you
Mar 02, 2008 | HP LaserJet 3050 All-In-One Printer
Low memory on HP Laserjet 3050
low memory error on my hp laserjet 3050
can anyone help
Dec 31, 2007 | Nikon COOLPRINT Thermal Printer
Drivers instalation
Hp Laserjet 3050 Drivers for 3050 Series Printer Download
Easy come
Oct 05, 2007 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 3050 All-In-One Printer Logo
69 people viewed this question
Seeker5211
Seeker5211
