Question about Car Audio & Video
I need wiring schematics for a pioneer gmx304 series amplifier
  • 27 Answers
SOURCE: AMPLIFIER WIRING SCHEMATIC 2006 VOLKSWAGON TOUAREG
the12volt.com will tell you everyting you need
Posted on Feb 02, 2009
  • 5 Answers
SOURCE: Wiring Schematic Diagram Porsche Cayenne S
in need the same if you get it plese post it to me. sorting@potissimus.sk
Posted on Aug 15, 2009
Skizziks
  • 43 Answers
SOURCE: I need a Wiring diagram/schematic for CD Player
http://www.eserviceinfo.com/index.php?what=search2&searchstring=DEH-P600
Downloads as a RAR file. make sure you have winzip or winrar, and that should help ya.
Posted on Sep 10, 2009
blueextc3221
  • 15935 Answers
SOURCE: pioneer keh-4646 speaker schematic
Please click HERE to see a generic wiring guide for aftermarket radios.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Apr 26, 2010
jturcotte
  • 8572 Answers
SOURCE: Need wiring harness color coded diagram for pioneer dehp3900mp
Hi, the wiring diagram is at the back of the manual. This unit has the standard wire colors for all aftermarket head units. Please get back to me with the car model and year if you need to know the car wire colors to match up.
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/130/130DEHP390.PDF
Posted on Nov 21, 2011
Do you have a schematic for Pioneer VSX-37TX?
I don't have a schematic for this model but you can listen when the problem starts and you can isolate it by using a can of freeze spray into the amplifier section when the noise disappears try heating the ares until the noise starts again until you zero in on the defective component .replace the defective component and you are all set.
Aug 06, 2014 | Pioneer Audio Players & Recorders
I bought the deh-2200ub to replace an infinity stereo in a 2005 kia optima. There's less wires on the pioneer, which I just taped off, I have no sound. AARRRGGGGGG!!!! help
Hi, the wires should be connected as indicated below. Please let me know if you have questions, and thanks for using FixYa.
2005 Kia Optima Car Stereo Wiring Schematic Pioneer wire color
Car Radio Battery Constant 12v+ Wire: Orange yellow
Car Radio Accessory Switched 12v+ Wire: Yellow red
Car Radio Ground Wire: Black/White black
Car Radio Illumination Wire: Brown/White none
Car Stereo Dimmer Wire: Gray none
Car Stereo Antenna Trigger Wire: Gray blue/white
Car Stereo Amp Trigger Wire: Green blue/white (same as above)
Left Front Speaker Positive Wire (+): Yellow white
Left Front Speaker Negative Wire (-): Black white/black
Right Front Speaker Positive Wire (+): Blue gray
Right Front Speaker Negative Wire (-): Red gray/black
Left Rear Speaker Positive Wire (+): White green
Left Rear Speaker Negative Wire (-): Brown green/black
Right Rear Speaker Positive Wire (+): Orange violet
Right Rear Speaker Negative Wire (-): Green violet black
Apr 10, 2011 | Pioneer DEH-P4000UB CD Player
I have buy a amplifier of pioneer model vsx-rs319v-k. My question is that can I please the bose acustimass 6 series 111. please let me know by email : sabree_7111@yahoo.com
Bose speakers are specifically designed to be used in conjunction with the Bose Acustimas Power Module and won't work properly just as ordinary loudspeakers connected to the Pioneer amplifier
You could connect the Bose Acustimass module to the auxiliary output of the Pioneer or via the HDMI repeater. However, if you do this you will still need a set of loud speakers connected to the speaker outputs of the Pioneer.
Feb 25, 2011 | Pioneer Audio Players & Recorders
Need schematic for pioneer sa6850 thanks
While the SA6800 is not exactly the same, it should be close enough to help you, The website below has the schematic for the SA6800.
Dan
www.hifiengine.com
Jul 07, 2009 | Pioneer Audio Players & Recorders
Wireing diagrams
Hello stingerman20,
Your Directed D2400 amp is CEA2006 Compliant. It is stable at 1ohm and will produce 1,200 watts into that load. So you want your subs wired as close to 1 ohm as possible.
The only 3500 watt Pioneer Premier series subs I could find were the models number TS-W3002D2 and TS-W3002D4 with dual 2ohm and dual 4ohm voice coils respectively. The wiring options for the D2's result in 0.5ohm (too low), 2 ohms, and 8ohms. Your best option would be the 2ohm configuration which would be voice coils in series and subs in parallel. Options for the D4's result in a 1ohm load and a 4ohm load. Your best option would be the 1ohm configuration which would be voice coils and subs parallel.
To see the wiring options, try Rockford-Fosgate's "wiring wizard".
Select 2 woofers and the appropriate voice coil impedance and quantity and click "search". It'll bring up all of the possible wiring configurations along with the final impedance load.
Hope this helps.
May 11, 2009 | Directed 2400d Car Audio Amplifier
Wire gauge
For this amp, 10 gauge would be large enough. Install a 30 amp fuse in series with the 10g wire where it connects to the battery.
Let me know if you have any other questions.
Sep 08, 2008 | Pioneer GM-X352 Car Audio Amplifier
Subwoofer help
You need to wire your Subs in Series. This way the current that passes through one has to pass through the other. Bridge your amp. and follow the wiring below.
Amp+ to Sub1+
Sub1- to Sub2+
Sub2- to Amp-
Nov 22, 2007 | Pioneer GM-7200M Car Audio Amplifier
Car Audio & Video Logo
197 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
