Question about Logitech Z-340 Computer Speakers
How to disassemble Logitech Z-340 sub-woofer
Anyone know how to disassemble the Logitech Z-340 sub-woofer. Apparently the speaker bezel, and then the speaker needs to be removed to get at the power transformer. What's the secret to removing the speaker bezel?
  • Anonymous Jan 29, 2009
    ditto same question
  • 3 Answers
The speaker bezel can be removed in only two ways:
1) Somehow remove the grille in order to get a the screws which hold the bezel onto the cabinet. I tried to do this and couldn't get it to budge. Once I got the thing open I observed that Logitech used a LOT of glue to hold this thing together.
2) Drill holes THROUGH the grill above each of the 8 screws large enough so you can loosen the screws.
Once you get it open, you'll be shocked to discover what you thought was the subwoofer cone is actually A ROUND PIECE OF CARDBOARD fastened to the foam. The 4" driver is behind this fastened to a board halfway back pointing into the chamber containing the electronics.
You can get to the power transformer, but good luck removing it. The screws are nearly impossible to unfasten; more glue but more importantly incredibly awful access to the nut and screw (yes, a screw, not a bolt).
I wouldn't pay 5 bucks for this system. Luckily, I didn't.
Posted on Feb 01, 2009
You just remove the grille by prying it out with a flat head screwdriver. In mine sub it wasn't glued. Then you unscrev those black screws visible through the grille.
Posted on Feb 18, 2009
Do i have to have the sub-woofer in order for my logitech X-230 speakers to work with my computer?
Certainly any large speaker itself cant be used with
very weak computer out signal
The signal should have power amplification in addition to
voltage amplification to energise large speakers
Oct 09, 2012 | Audio Players & Recorders
Can I use my Logitech x-230 speakers without the sub-woofer? My sub-woofer got busted!! Any suggestions?Perfectly good speakers!
i had the same problem with same speaker system. the amp for this system is inside the bass speaker. if your amp is still working but your bass speaker is not you could cut the wires to that speaker making sure the cut wires do not short out. i was quoted more to repair them than it was to buy a new set. but i wont be buying logitech again as ive had two lots fail.
Jan 18, 2012 | Logitech X-230 Computer Speakers
Where can i purchase the audio cables that connect the Logitech X 230 sub woofer to my laptop and mp3 player
Usually you can purchase audio cables for speakers and sub-woofers from any or authorized PC outlets.
Just explain to the dealership what you want to connect it to and they will shoe you the right "jack" to buy.
G.
Nov 01, 2011 | Logitech X-230 Computer Speakers
Only have the sub itself, Can I still use it and if so how?
Unfortunately you will not be able to use the sub-woofer by itself because the input for the Logitech X-530 has a special cable to connect to the sub-woofer. You could always try looking on eBay or Craigslist for replacement parts.
Aug 18, 2011 | Logitech X-530 Computer Speakers
I recently purchased a new Denon AVR-391 receiver and am having a problem hooking up my subwoofer. It seems that the Denon has a pre-out RCA looking output and my subwoofer uses conventional speaker wire. ...
Your sub-woofer apparently does not have an amplifier built into it. This type requires you to use your front left and front right speaker output to got through it to your regular speakers. It is called a passive sub-woofer for that reason.
To set it up, Connect your front speakers to the "output" of the sub. It should say "to speakers" on it.
Then connect the Speaker Outputs for the left front and right front on your Denon AVR-391 directly to the Sub. It should say on the back of the Sub "to amplifier".
Here is some theory you should know, if you don't already know it, that will help you get a satisfactory result in setting up this system.
There is a condition on setting up all speakers and subs that not everyone know. It's call "phase alignment". Phase alignment (A Good Thing) refers to all of the speakers in a system moving in the same direction (in and out) at the same instant in time. This gives you much clearer sound and better response from your sub-woofer.
Phase Cancellation (a bad thing) is when some of the speakers are moving out and other moving in during the very same instant in time. It causes problems in sound.
IN A SUB-WOOFER, IT CAN CANCEL OUT THE LOW NOTES.
Here is how to handle it:
On the back of the receiver the speaker terminal outputs are colored Red and Black. Black is considered negative and Red is considered positive. On the back of the Sub woofer and on the speakers the same colors apply. MAKE SURE THAT ALL OF THE CONNECTIONS GO BLACK TO BLACK AND RED TO RED WHEN CONNECTING UP THE SPEAKER WIRES.
The system will work either way. But you will have severe bass loss if the woofer wiring is out of phase because of phase cancellation.
Hope this helps,
Best Regards,
Mark
"Phase Cancellation"
Jan 05, 2011 | Audio Players & Recorders
How do you connect logitech speakers on the pc
1) plug the cable coming out of the satellite with the sub-woofer at the reat 2) plug the 3.5 cable jack coming out of the second satellite to the computer audio out ( generally green color connector ) connect the power adapter with the sub woofer
and you ready to enjoy the music. make sure yo switch on the the power adapter.
Oct 22, 2010 | Logitech R-20 Computer Speakers
Harmon Kardon SoundSticks II sub-woofer cleaning
These "proposed solutions" obviously have absolutely NO relation to the problem stated. Which by the way is far too typical of this site. :(
Apr 29, 2010 | Harman Kardon iSub Computer Speakers
7000684, 7000787, 7000947, 7001364 power cable for gateway 2000 media theatre
In DEC 1998 I bought a Gateway PC with a Digital Media Theater, P/N 7000787. In the meantime the speaker in the sub-woofer got damaged (because of age). Is it possible to disassemble the sub-woofer and replace the speaker?
Where can I buy the same or a very similar speaker for this sub-woofer? Thanks, Andy Szekely
Mar 02, 2010 | Boston Acoustics MediaTheater Computer...
Logitech x-230 speaker system
Ironically enough, I went on here because I have the satellites but no subwoofer! LOL, what are the odds. Anyways, if you happen to receive this information, can you please email me at ben.petrofsky@live.com?
Like I said, I'm searching for the same exact information for a similar problem and this would REALLY help as I can't power the speakers without this.
Apr 02, 2009 | Logitech X-230 Computer Speakers
Woofer Quit
Check the pin connection it is loose or the pins may be bent. Check Connection to sub hold it in tight if no pins are bent and see if the hum stops. Hope this Helps it is what was happening to my set>GOOD LUCK>If pins are bent straighten them>
Aug 13, 2008 | Logitech Z-340 Computer Speakers
Logitech Z-340 Computer Speakers Logo
5,002 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
