Question about Kenmore Washing Machines
Only hot water is coming . cold water none
Turn on the machine set temp water to cold and hot water come set to hot water and hot water come
    New Friend:
  • 90 Answers
Cold water under pressure from mains.hot water not so pressurised.tbh if you have a hot feed pipe blank it off and justuse cold feed.the machine will heat the water.if its hot fed you are paying to heat the water.then its pumped into machine.which then dumps more cold in the lower to wash temp.so using more water .pretty much all european washers run cold feed only
Posted on Oct 30, 2015
  • 4 Answers
Ensure the hose's at the back are in the right places, Could be you or the fitters has put them in the wrong place.
Posted on Feb 20, 2012
Cold water comes into the tub but no hot water comes in when switch to hot water
I am a little puzzled by your clues--
SO let me ask it back:
When you set the Hot/Cold control to HOT-- you just get HOT water?
That is normal-- -- at least that is the way it works on most Washing machines--
If you want some cold water also-- you have to set the temp lower than HOT--
Doesn't that make sense?
Maybe I am missing something--
Tell us more-- so we can help more--
Mack B
Jan 25, 2011 | Kenmore 22622 Top Load Washer
Whirlpool washing machine...only uses hot water
Make sure the hoses are connected correctly to the water valve on the machine. The connections will be marked with an "H" and a "C".
Given they are correct, most current washing machines have and auto temp feature on the water fill. It allows even cold water settings to bring in some hot water to make sure the water temp is hot enough to efficiently disolve your laundry detergant. The preset temps are usually around 75* for cold, and 105* for warm. Hot water comes in at whatever temp your household water temp is.
Sep 12, 2009 | Washing Machines
Kenmore top load water temp switch problems and hot water rinse
Hi, Switch the hoses around going to the mixer/inlet valve. I am sure this will take care of the problem.
If not, please let me know so I can assist you further.
Vic
Jul 01, 2009 | Washing Machines
Cold water starts and stops when washing
sounds like your washer has an auto temp. control if so the washer mesures the temp of the water and put in the manufacture set temp for that setting this board could be bad alowing only cold water to come into the machine. you could also have low hot water pressure at the washer be sure the hot water is turned all the way on. you may want to check to make sure no trash is in the hot water side of the water valve there is a screen in there where the hose conects you can remove that screen and clean it im sure one of these solutions will help you
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
My Admiral Washing machine only runs the hot water (not cold)
the water temp switch is bad call aplience parts store in the area
Nov 25, 2008 | Admiral AW22 Top Load Washer
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washer is a top load set it hot water and starts with hot and then will go cold willnot stay on hot G E Profile ,model wwa8350g
most new washers sense water temp and will try to adj final tub water temp by alternately running cold or hot as needed ..most hot settings are not faucet temp but a predetermined temp so if your hot water is 140 degrees coming in the control will switch the cold on to bring final tub water temp down to preset ..which could be as low as 100 degrees the industry's way of energy conservation
Sep 23, 2008 | GE Washing Machines
Maytag mav6000 hot/cold problem
hi try to just regulate the temp by turning down the water flow from your taps if more cold is coming in than hot turn cold water down a bit to your satisfaction thanks THE APPLIANCE DOC
Sep 05, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Front Load Intellisense 6.5kg
washer may not be detecting water temp but water flow ..if you never use hot water may try hooking cold water to a Y-connector and then hooking to both hot and cold inlet valves ..however it is also possible washer is detecting inlet temps in which case you're out of luck ..i suspect the latter
Sep 01, 2008 | Washing Machines
When temp is set on hot water--hot water shuts off & cold water comes out
In the machine, you have a solenoid that the water hoses come into. That piece is controlled by a timer. The hot water during the cycle, does it shut off completely during fill or intermittent?
Mar 16, 2008 | Washing Machines
Washing Machines Logo
123 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
