Question about Poulan Pro " Pro" Self Propelled Mower
Engine starts then dies
When primed it will start but it then dies
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: after priming it will start but dies after a few seconds
Hi fuzykids213
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper and or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of sharp instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line/s condition...after a while they will degrade and need replacement.
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel lines from the carburetor be sure to make a drawing or take a picture of how the lines are connected to the carburetor.
Also a good time to take a picture for later reference for reassembly.
If the mower is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Mar 17, 2013
1988 aric cat 440 jag when primed will start and run then dies
Sounds like there is water in your fuel. If there is, you can see it in the bottom of the tank or just drain it and put fresh new gas in it. If straight fuel is left in small engines in the off seasons, they will gum up the carb with varnish and the carb will need to be removed, cleaned, and reinstalled.
Sep 21, 2014 | Garden
Starts but dies in 2 seconds
You can use obd2 reader to check the engine system.Maybe it got fault codes.
Jul 26, 2013 | 2002 Saturn S-Series
1993 Chevy C1500 4.3L V6 TBI starts but dies at idle after warming up.
Low pressure from fuel pump, when the pump is cold the pressure increases, as it warms up the pressure drops (this happens in a pump that is going out) the normal pressure should be at 40 with the key on and engine not running, when started the pressure should stay around 36, any less it won't idle and may run as long as you hold the pedal down. The injectors are opened electronicaly, so as long as there is fuel flow the engine gets fuel to run.So check the fuel pump, soundslike you need a new one
Apr 04, 2013 | Chevrolet Cars & Trucks
Accord fuel pump won't prime
sounds more like the ECM than a relay, to me.
Mar 17, 2017 | Honda Cars & Trucks
When I start my 10hp mercury outboard after priming it will run for a few seconds and then die. IF I push the throttle only button and rev it up before priming or set the low idle up higher and then prime...
Be sure to run the recommended fuel mix. most modern 2 stroke outboard engines run on 100 to 1, some times the mix is on a decal inside the cowl.
Cheers, Timo.
Feb 27, 2010 | Light Outboard Motor Boat Bass Fishing...
My engine will start then die
Remove the float bowl from the carburetor, clean it out and use a commercial spray carburetor cleaner to clean out the main jet in the center of the carburetor where the bowl nut screws in
Sep 19, 2009 | Toro Lawn Mower With Toro Power Tools
I have a troy built self propelled mower, it ran great last season, now it will not stay running. I checked to see if it was getting fuel and it is. I primed it and it acts like it is going to run and then...
The jets in carbs are really small and clog easily. If you stored your mower with gas in it start by replacing the gas. Remove the air filter and prime the carb. Start the engine and place your fingers over the air intake on the carb. This will cause the engine to stall as it will be starved for air. It will also create a powerful suction on the jets and possibly dislodge a blockage. Prime the engine again and start. If does not continue to run, repeat the steps again. If after 3-4 tries your engine wont run you will have to remove the carb and clean the jets manually. The reason your engine runs for a short time is because it is burning the fuel that you put in there by priming it. After that the fuel comes through the jets in the carb and if these jets are clogged the engine will die.
Jun 06, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Engine wont start without priming with gas first, then runs well
i have the same problem on a 98 jimmy 4.3 4x4.
i replaced the fule pump and have good pressure.
new wiers & coil (good spark) no MIL & no codes.
will only start when primed. it will run & drive all day
with no problems.
but once it has been turned off (warm or cold) i will
have to prime it once again to start it.
i have another engine that was in it before it spun a bearing.
it ran fine so i know all parts are good.
i swaped the mass air flow and throttle body but i still have
to prime it everytime to start it. am i forgetting something?
should i swap out the intake with the injectors?
any help would be sweet. thanks.
Apr 28, 2009 | 2000 Chevrolet Blazer
Ran it out of gas,now wont start
Turn the key without starting the engine, you should hear the fuel pump engage. Do this a few times to prime the engine. If it still doesn't start, spray "starting fluid", available at parts store, into your throttle body. It should start now.
Nov 20, 2008 | 1997 Infiniti.5 Q45
Poulan Pro " Pro" Self Propelled Mower Logo
51 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
