Question about Consew 226R-1
Stich length is too short how to adjust it - Consew 226R-1
  • Val
    Val Feb 21, 2012
    What is the model number of your machine?
Can not adjust stitch length
You might need to Google "stitch length adjustment" for your particular machine (brand, model). However, here some pages with generic information:
Sewing Machine Stiches Adjusting Stitch Length and Stitch Width
How and Why to Set Your Sewing Machine Stitch Length Sew4Home
Check for a user guide or a forum or tips on the maufacture's site, as well. You might even find a YouTube video about the suject.
Feb 05, 2018 | Sewing Machines
Is a satin stich programed in the machine.
Perhaps newer machines have it, but usually the sewists programs it. All it requires is a wide stitch and short stitch length. The length is adjusted so the thread actually covers the fabric between stitches, but does not overlap itself. Even if the sewist has a programmed satin stitch but there may still be some required adjustments needed since the thickness of the thread will alter the way the stitch looks.
Sewing Perfect Satin Stitch Wildly Wonderful Wearables Patterns Notions...
Mar 20, 2016 | Sewing Machines
I have a singer 2868c i cannot get the stitches to lenghten from a tight stich how di i change the length?
The stitch length lever/dial should control that for you. Consult your owner's manual. If it is not changing the stitch length even though you've adjusted it, then it probably needs service.
Feb 13, 2016 | Singer Sewing Machines
What number and or letter shold i but it to sew stait stich
Set the Stitch Width to zero and the Stitch Length to 2. You'll probably want to adjust the stitch length to fit your needs for your project but 2 is a good place to start.
Nov 20, 2015 | Sewing Machines
How to change stich to long stich for gathering?
http://www.singerco.com/uploads/download/3e3e5558857ed68836712ac8545abb48178772a5.pdf is the manual for your machine; look at p. 27. You want stitch 00, and then increase the stitch length with the up/down buttons on the control panel.
p. 24 of the pdf covers adjusting the top tension of the machine; you'll have an easier time of gathering if you reduce the top tension about 1-2 number setting.
May 29, 2014 | Singer 5400 Sew Mate 60-Stitch Sewing...
I have forgotten how to work my Decorative stitches on my Bernina 930
select the 1-20? stich pattern on top of the unit, then select the pattern you want, select widest stich and turn the length adjuster to the length that best suits that stich, (it could be from almost zero to full length depending on the pattern)
Feb 07, 2013 | Sewing Machines
Hi, I have a Juki ddl 552 that does not have te stich setting nob. I am wondring how can I change my stich seting? please help.
Here is a threading diagram for this industrial machine
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Juki_Sewing_machine_threading/Juki_552_553_555_227_Threading_Diagram.htm
You can also buy a manual here
http://www.sewusa.com/Sewing_Machine_Manuals/Juki_Manuals/Juki_Industrial_Sewing_Machine_Manuals/227-552-553-555_Instruction_Manual.htm for this model.
I would have thought there would be some sort of screw or adjustment to control stitch length but I can't find an image for your model.
However this image might help, http://www.johnharbsew.com/images/threading/JUKI-DNU-241-TD.jpg, my Singer 20U, has a dial like this with numbers on that you adjust for length, is there something similar on the Juki?
Apr 19, 2011 | Juki MO-644D Mechanical Sewing Machine
Yamata FY 920: Lost the manual. Can't figure out
Stitch length dial on the front.
Mar 05, 2010 | Yamata FY920
How to adjust the stich lenght on a juki ddl 553 strite stich.
I still don't understand this. I have acquiured a juki DDL 553 recently to discover I have no idea how to change the stitch length and that there is no reverse stitch. I have pressed the black button and have tried to turn the side?( the wheel?) but when i push down on the black button there is no way to turn the wheel it doesn't move, maybe there is some other part I'm supposed to be moving??
Jan 24, 2009 | Juki MO-655 Mechanical Sewing Machine
Hole width
After putting on the buttonhole foot, you lower the foot, put in the size button you want into the button hole foot. Lower the button hole lever all the way (so machine does not blip) Then the machine automatically sets the length and width of the button hole...you can adjust the length and width manually by pushing the button on the top right hand part of the machine above the LED screen the top one is stich length the other is stich width....if you put the levers to the left it will be the smallest stich length or width...if to the right it will be the largest stich length or width the machine allows. But, really the machine automatically does this for you...so I don't see the need to do it.....but you can....BBill01
Jul 22, 2008 | Juki HZL-E80 Computerized Sewing Machine
Consew 226R-1 Logo
Top Consew Sewing Machines Experts
Michael Galve
Michael Galve
Oloyede Monsuru
Irene Tulloch
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
