Question about Kenmore Dryers
How to change the door swing on a Kenmore HE2 Dryer
I have a Kenmore HE2/Model #110.86562500 dryer that I would like to change the direction of how the loading door opens. Can you please tell me if/how this can be done? Thank you.
4 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Kenmore He2 front load dryer
cant seem to find a fault code f 26, if you remove the top panel on your machine there should be a tech sheet explaining most f codes on the right side in an envelope, if not remove bottom panel (its in there somewhere)
Posted on Feb 26, 2008
  • 5 Answers
SOURCE: Kenmore HE2 door bellow
Here is the repair manual for the he2
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
Posted on Nov 06, 2009
blueextc3221
  • 15935 Answers
SOURCE: 82822 / 82824 / 82826 Electric Dryer: kenmore HE2 electric dryer, beeps and all display ...
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 25, 2010
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
Is it possible to reverse door swing on dryer? My daughter has a new Elite front load dryer that swings from left.
REVERSING DOOR SWING
Your dryer is designed so the door swing may be reversed at any time without additional parts. Conversion is accomplished by transferring hinges to the opposite side of the cabinet.
To change the direction of the door opening:
1. Open the dryer door. Remove the four hinge hole plugs from the left side of the door opening. Place nearby for future installation. NOTE: You may need a plastic knife to help pull out the plugs. Be careful not to scratch the paint.
2. Remove the four screws that secure the door hinges to the dryer front panel (see below). NOTE: Remove one screw from each of the two hinges first. Hold the door firmly before removing the last two screws.
3. Rotate the door 180° and reinstall the door hinges to the dryer front panel with the four screws.
4. Install the four hinge hole plugs in the open screw holes on the right side of the door opening.
Hope this helped Tim
Dec 01, 2010 | Kenmore Elite HE4 Electric Dryer
Can you change the door direction on a Maytag
Unfortunately, you can only change front loading dryer door directions on some models. Washing machines do not allow this. If the units are stacked i may be easier to switch loads, otherwise the dryer door may be able to have the door swing direction changed but without the Dryer model # I couldn't say for sure.
Dec 29, 2009 | Maytag EPIC MFW9700S Front Load Washer
Can i reverse the door opening direction on this model? thanks
no you cant but if you have the matching dryer swap machines and reverse dryer door .hope this helps .please rate my response :)
Dec 09, 2009 | Kenmore HE2 Plus Front Load Washer
Switching the door swing opening?
only if there are capped off screw holes on other side, look for caps mirror image to other side.
Sep 02, 2009 | Kenmore HE2 Plus Front Load Washer
Can't locate stacking kit for HE2 Plus Washer and HE2 Dryer
more of the model number would help, but i can get them parts for you at www.whirlpoolpartssurplus.com feel free to give us a call
Jun 23, 2009 | Kenmore HE2 Plus Front Load Washer
Change door opening on Kenmore HE2 washer and dryer
yes - there is a hinge kit to do so.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 28, 2009 | Kenmore HE2 Plus Front Load Washer
The door on my dryer and washer open the wrong way
Are you planning to reverse the door swing direction on your
DUET®dryer? To do so, you will need to purchase a Door
Reversal Kit.
To order, call the dealer from whom you purchased your dryer or
refer to the "Assistance or Service" section of this manual. Ask
for Part Number 8530069 (Shield Blue), 8530070 (Shield
Platinum), 8530071 (Biscuit) or 8530072 (Pewter).
Door Reversal and Stack Combination Kit
® ® DUET dryer and stack your DUET washer and dryer? To do so,
you can purchase a Door Reversal and Stack Combination Kit.
for Part Number 8530073 (Shield Blue), 8530074 (Shield
Platinum), 8530075 (Biscuit) or 8530076 (Pewter).
From the manual, Page 4. Hope this helps
Eric
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0802161.pdf
May 24, 2009 | Whirlpool Dryers
he 2 are a little similar to all H E washer ,, it has spring clamps (2) remove and install them same way
Dec 12, 2008 | Kenmore Elite HE4 Electric Dryer
Need to change door from left hand to right hand open on kenmore HE2
I am looking for the same answer on the washer. You can definitly change the dryer. The holes are on the other side under black tape.
Nov 16, 2007 | Kenmore 43142 Front Load Washer
Dryers Logo
197 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
