Question about Kenmore HE2 Dryers
Change the door swing on a kenmore he2 dryer
I would like to switch the direction the door opens on my dryer. Can you please tell me if it is possible and how to do it? Thank you.
SOURCE: Need to change door from left hand to right hand open on kenmore HE2
I am looking for the same answer on the washer. You can definitly change the dryer. The holes are on the other side under black tape.
Posted on Jun 26, 2008
ginko
  • 19396 Answers
SOURCE: how to change the dryer door switch
To remove the panel you need to undo two screws.
How to take apart the dryer:
Older (29 inch) Whirlpool/Kenmore models.
Newer (27 inch) Whirlpool/Kenmore models.
How to replace door switch:
Free Dryer Repair Guide - Replace your dryer door switch
Door switch replacement help for a common door switch
Posted on Feb 24, 2009
erpaalai
  • 999 Answers
SOURCE: the door on my dryer and washer open the wrong way
Are you planning to reverse the door swing direction on your
DUET®dryer? To do so, you will need to purchase a Door
Reversal Kit.
To order, call the dealer from whom you purchased your dryer or
refer to the "Assistance or Service" section of this manual. Ask
for Part Number 8530069 (Shield Blue), 8530070 (Shield
Platinum), 8530071 (Biscuit) or 8530072 (Pewter).
Door Reversal and Stack Combination Kit
® ® DUET dryer and stack your DUET washer and dryer? To do so,
you can purchase a Door Reversal and Stack Combination Kit.
for Part Number 8530073 (Shield Blue), 8530074 (Shield
Platinum), 8530075 (Biscuit) or 8530076 (Pewter).
From the manual, Page 4. Hope this helps
Eric
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0802161.pdf
Posted on Jun 09, 2009
Greg20
  • 149 Answers
SOURCE: kenmore he2 electric dryer error code f-01
always unplug for 10 minutes and retry first.
Posted on Jun 12, 2009
bozcro
  • 867 Answers
SOURCE: Switching the door swing opening?
only if there are capped off screw holes on other side, look for caps mirror image to other side.
Posted on Sep 02, 2009
How do I switch the door opening to the other side? I would like to change the dryer door opening from the left side to the right side. By looking at the dryer it appears this is possible.
Hello, Frazer -
Without knowing the make and model of you clothes dryer, it is a challenge to provide you with the precise directions for changing the swing of your dryer door. With that being said, this YouTube video may prove helpful to you: https://www.youtube.com/watch?v=VW9183PsCLc .
How did I find the YouTube video? Using Google I entered the following search statement, with quotation marks, as indicated: "clothes dryer door swing" .
This web page with written directions may also prove helpful:
http://homeguides.sfgate.com/change-dryer-door-left-right-66754.html .
Best wishes.
Dec 17, 2017 | Dryers
Light stays on even with door shut, kenmore he2 dryer
The door switch would be the first suspect... make sure the wires are in the proper sequence... does the light go off when you open the door? the tech sheet should tell you what color wires go to which terminals
Apr 27, 2016 | Kenmore Dryers
Is it possible to reverse door swing on dryer? My daughter has a new Elite front load dryer that swings from left.
REVERSING DOOR SWING
Your dryer is designed so the door swing may be reversed at any time without additional parts. Conversion is accomplished by transferring hinges to the opposite side of the cabinet.
To change the direction of the door opening:
1. Open the dryer door. Remove the four hinge hole plugs from the left side of the door opening. Place nearby for future installation. NOTE: You may need a plastic knife to help pull out the plugs. Be careful not to scratch the paint.
2. Remove the four screws that secure the door hinges to the dryer front panel (see below). NOTE: Remove one screw from each of the two hinges first. Hold the door firmly before removing the last two screws.
3. Rotate the door 180° and reinstall the door hinges to the dryer front panel with the four screws.
4. Install the four hinge hole plugs in the open screw holes on the right side of the door opening.
Hope this helped Tim
Dec 01, 2010 | Kenmore Elite HE4 Electric Dryer
Can you change the door direction on a Maytag
Unfortunately, you can only change front loading dryer door directions on some models. Washing machines do not allow this. If the units are stacked i may be easier to switch loads, otherwise the dryer door may be able to have the door swing direction changed but without the Dryer model # I couldn't say for sure.
Dec 29, 2009 | Maytag EPIC MFW9700S Front Load Washer
Can i reverse the door opening direction on this model? thanks
no you cant but if you have the matching dryer swap machines and reverse dryer door .hope this helps .please rate my response :)
Dec 09, 2009 | Kenmore HE2 Plus Front Load Washer
Sep 02, 2009 | Kenmore HE2 Plus Front Load Washer
Change door opening on Kenmore HE2 washer and dryer
yes - there is a hinge kit to do so.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 28, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 door bellow
he 2 are a little similar to all H E washer ,, it has spring clamps (2) remove and install them same way
Dec 12, 2008 | Kenmore Elite HE4 Electric Dryer
Nov 16, 2007 | Kenmore 43142 Front Load Washer
Dryers Logo
151 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
