How do I oil my Ativa HD Pro 1600 shredder - Office Equipment & Supplies
3 Suggested Answers
SOURCE: ativa HD 800 Shredder is showeing a overheating
They all do that.  Just wait a few minutes for it to cool off again.
Posted on Jan 21, 2010
  • 42 Answers
SOURCE: Our Ativa HD PRO 1600 shredder will not operate
SOUNDS LIKE THE SENSOR OR SWITCH MAY HAVE TRASH ON IT.
LOCATE THESE ITEMS USUALLY ON LEADING EDGE CLEAN
SENSOR WITH A "Q" TIP AND ALCOHOL. IF THERE IS SWITCH CHECK
TO SEE THAT IT IS NOT JAMMED AND WORKING PROPERLY.
Posted on Oct 19, 2011
Why Aptiva HD pro discontinued
You may want to contact a local business machine repair service and ask if they can repair the unit. Many times they can repair what the manufacturer does not want to handle.
Apr 22, 2015 | Shredder Office Equipment & Supplies
My Ativa HD Pro 1800 will not power on
First check the power point is still working - plug in another appliance, like a table lamp. If OK check the fuse in the shredder cable plug.
The commonest reason for a shredder stopping is a paper jam, or running the shredder for too long. By 'too long', many shredders will cut-out after 5 minutes continuous working, and the sensor may take 15 minutes to cool down! Read the manual.
It maybe that the shredder cutters are jammed. Unplug from mains, and lift off top and place upside down. Use a small screwdriver and/or long nosed pliers to poke at any compressed paper wrapped around the blades - can take a while.
It may be that the sensors are dirty - use a cotton bud dipped in rubbing alcohol to clean the sensor light(s) and heads
Give a quick spray to cutters with WD40 Replace - turn on - and run in reverse.
May 21, 2014 | Ativa HDM PRO 8000 8-Sheet Micro-Cut...
Need wiring diagram for ativa hd pro 1400
I doubt you will find one, unless a maintenance engineer reads this.
Jan 29, 2014 | Office Equipment & Supplies
Ativa shredder manual
I could not find a manual or support on Ativa website but I searched their FAQ. It said that the shredder basket must be fully closed and integrated with the shredder. I had the same problem. I pushed the basket firmly into place and it stopped. I believe this flashing scheme may be telling you that the shredder and basket aren't properly aligned.
Oct 05, 2013 | Office Equipment & Supplies
Our Ativa HD PRO 1600 shredder will not operate because the "jam alert" light is on, however there is nothing in the feeder or the shredding mechanism. I have misplaced my manual and
Oct 18, 2011 | Office Depot Ativa DQ60M Shredder
I have an Ativa MD 460 shredder, it is misaligned with paper. Can you help?
ativa md460 misaligned Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your ativa md460 misaligned question. Get free help, tips ... I have an Ativa MD 460c paper shredder that reads misalignment. What do I do?
Just purchased ativa MD 460C and it will not work. misaligned
www.fixya.com/support/t9496803-just_purchased_ativa_md_460c
Jun 16, 2011 - Look for a curve in the lip on the back of the shredder and align it with the ... I have an Ativa MD 460c paper shredder that reads misalignment.
Ativa MD460 paper shredder: misalignment light is on - Fixya
www.fixya.com/.../t7580117-ativa_md460_paper_shredder_misalignme...
Jan 1, 2011 - I have a Ativa MD 1000 that I just bought. It ran for a few minutes the first time I used it an then stopped. I turned it off and unplugged it in case it had ...
Office Depot Ativa DQ60M Shredder Misaligned - Questions ...
www.fixya.com > ... > Office Depot Ativa DQ60M Shredder
just purchased ativa MD 460C and it will not work. misaligned is highlighted. can u help... I have an Ativa MD 460c paper shredder that reads misalignment.
Jun 07, 2011 | Office Depot Office Equipment & Supplies
I have an Ativa 1850. When putting papers in to shred the papers move to the right side and bunches up the paper. The shredder now doesn't want to work properly. No papers will go through to be...
You probably need to get some shredder oil and lubricate the cutter heads. see: http://www.walmart.com/ip/Fellowes-Powershred-Shredder-Lubricant-Oil/8207323
Apr 19, 2011 | Office Depot Ativa 1850 (MicroCut)...
I just need to know how to oil the Ativa AT1250 shredder. We no longer have the manual. Is there a specic "well" to place the oil into or is it just spread across the blades.
Just use regular "shredder oil", if you hav'nt put any oil on in some time pour it directly onto the blades....once in a while put the oil onto a sheet of paper you are going to shred and shred the paper with the oil on it.
Nov 15, 2010 | Office Depot Ativa 1250 (MicroCut)...
Does the Ativa CX12W need lubricating,and if so how? I don't see anything in the manual?
Yes!
3-in-1 or Marvel Oil will do just fine.
Start the shredder and squirt a generous amount of oil down back and forth into the feed slot to soak the blades.
Sep 28, 2009 | Office Depot Ativa CX12W Shredder
k24674
jasbo
jasbo
