Question about Watches
Maxum watch adjustments
The band is too big how do I shorten the band ?
SOURCE: How to adjust the watch strap
I just bought the o-ring watch by Starck, and it looks to have the same style of strap. If you look on the side of the clasp, you will see a pin on both ends. You have to remove these retention pins first (which may require tools that are unavailable to you). First, stabilize the watch on its side on a soft mat - I used the back of a mouse pad. Then, use a thin, stiff piece of metal tool to push the pins out slightly. I used a crafting tool. Once the pin sticks out enough, you can use a fine set of pliers to pull them the rest of the way out. (If this does not make much sense at this point, you may be best off going to watch shop.) Once you remove the pins, the clasp can be removed from the strap simply by lifting the clamp. You then trim the strap with a pair of sharp scissors to the appropriate length - make sure you see exactly what the end looks like, because the shortened strap will need to have the same apperance. After trimming, reclamp the clasp onto the strap, and reinsert the pin. You may need a small hammer to get the pins seated completely. Then, you're done. So obviously intuitive, why would anyone need directions, right? Honestly, Fossil did not make this one easy at all. Kind of irritating.
Posted on Aug 09, 2008
  • 51 Answers
SOURCE: shorten watchband
You can find here step-by-step instructions with pictures:
How to shorten a metal watchband
It is for a casio watch, but the watchband has the same principle with "arrows" on the links.
Posted on Sep 13, 2008
SOURCE: how to adjust metal wrist band on casio watch?
Take it to walmart or any store with a jewelry section, they'll fix it
Posted on Sep 20, 2008
slp11508
  • 43 Answers
SOURCE: adjust expandable watch bands- Timex watch
Most expandable watch bands aren't sizable. IF it is sizable you will be able to tell when you stretch the bracelet out. If it looks like you can unlatch the links when you stretch it out then you might be in luck, but like I said, most are not sizable.
Posted on Jan 05, 2009
escapement
  • 2334 Answers
SOURCE: how to shorten the watch band without breaking it
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Apr 09, 2009
Montres Carlo. How can I shorten the band?
WATCH BAND ADJUSTMENT / RESIZE - HOW TO - YouTube
? 5:51
https://www.youtube.com/watch?v=N42D4lwD5Ok
Dec 25, 2013 - Uploaded by Phil Crockett
This video shows how to adjust the size of a watch band by removing extra links. This video is "to ... +Jay Carlo Aguilar Glad my video helped you out! Makes my .... Can't wait to challenge my smartass Grandkids to figure it out.
How to Resize / Adjust a Watch Band - YouTube
? 6:39
https://www.youtube.com/watch?v=o3NfebIjLlU
Sep 15, 2012 - Uploaded by Nils Rasmusson
Learn how to adjust a metal / silver / gold watch band or how to resize a ... A couple of pins on my watch broke and I bet I caneasily fix this for ...
Jan 19, 2016 | Watches
Tip
Watch band shortening/lengthening
Follow this link and see how to adjust watch band. <a href="http://emea.skagen.com/en/Customer%20Service/Watch%20Instructions.aspx#adjustment">http://emea.skagen.com/en/Customer%20Service/Watch%20Instructions.aspx#adjustment</a>
on Feb 27, 2011 | Watches
How do I shorten ******** my Tag Heuer Formula 1 watch?
Take a look at the watch from the side where the band attaches to the buckle. You should see four holes with one of them having a visible pin in it where the band is connected to the buckle. Moving the band to the right will shorten it moving it to the left will make it bigger. To move it simply get something that you can push the pin in with like a paper clip. Push the pin in and the band should come out move it to the left and push the in again and simply move the band into proper position. Once you do that the pin will snap back into place. If that does not adjust it enough go to your local watch store and they can remove links from the bracelet for you. Shouldn't cost you more than $10.
Dec 14, 2013 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
Maxum Watch Band X6003L2 - Australia Need a replacement band, but distributor says it can only replace whole watch not band. It is only 18 months old. Any advice?
You might be able to replace the band with a generic watch band (meaning a band that will fit the watch but is not the exact band that it came with) Some good companies would be speidel or Hadley Roma to get the bands from. Just find out the millimeter length (or the size of the band) and you probably could change it.
Jun 26, 2013 | Watches
Shorten wrist band on a RADO CERAMICA JUBILE mens watch
mcdevito75 here, Rado a great watch and with a $50.00 band, at least. BEST BET, look for a small watch repair shop in your area for this band adjustment. Links are held in by special pins and a link remover tool is need to remove these links.
Feb 11, 2011 | Watches
Purchased fossil ladies watch am4183 at Macy's, stainless steel band is too big, is this band adjustable, if so how.
Check the sides of watch band and you will see the pin ends. They are holding all links together. If there are arrows inside the watch band, they are pointing the way the pins must come out.
To shorten the band you have to:
Extract the pins.
Take link(s) off.
Join the rest of band together and drive pins back.
Jan 01, 2009 | Fossil JR8096 Wrist Watch
Need to shorten a band
you better pick one and size it according to your size, if not enough, pick one again to other side of the band in order to balance ,,until reach the size you want....
Jun 24, 2008 | gossip Watches
Item number L12445 band adjustment
How do I shorten the links on a woman's eco drive citizens watch band?
Apr 22, 2008 | Watches
Watches Logo
66 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
