Question about LG Washing Machines
Door doesnt close tightly on LG wm2020cw, rattles during spin cycle
Model WM 2020 CW
Buschchris1
  • 474 Answers
SOURCE: lg washer overfilling with water during first cycle
Becasue the water level sensor id broken or the shut off valve for the water is malfunctioning. If its brand new and has a warranty, i would take it back immediately and get a better known brand. Call the retailer you got it from and explain whats happening and make sure you pay for nothing. If you return it, they should pick it up.
Also, if the door isnt sealing tight and is leaking that means the latch is faulty or the seal is bad and that should still be covered by the Manufacturers warranty. Most things are for about 1 year from day of purchase.
Posted on Feb 15, 2008
  • 210 Answers
SOURCE: "CD" ERROR ON LG WM-3677HW Front Load All-in-One Washer / Dryer
CD means cool down, press the pause start button, the door lock will open. It is an anti crease cycle. It mentions it in the owners manual, but it is hidden deep in the drying section.
Sgt 48
Posted on Jun 03, 2008
MNTECH
  • 1543 Answers
SOURCE: LG WM-2277HB washer does not drain and make rattling noise.
You will need to replace the drain pump motor. The pump impeller has separated from the motor shaft. You can push it back on, but it will just come off again. I have not tried adding adhesive because I didn't want a call back. That may work if you want to try it. To replace pump motor:
Take the rectangular recess out by using a putty knife on the left or right side, Remove phillips screws mounting pump. Pull machine forward about two feet to allow you to tilt the machine back to lean it against the wall. Reach under to access the pump. It is held in place by a plastic tab you can depress to remove, but if you break the tab, don't worry, as the mounting screws will hold your pump in place just fine when reinstalled. Remove pump by disconnecting hoses and electrical plug. Change out pump motor (three phillips head screws)
Posted on Nov 16, 2008
stradeteox
  • 88 Answers
SOURCE: LG Intello wm-1460FHD stops spinning during the wash load.
OE is a drain error (indicating the machine has not drained out in under 10 minutes). If the drain pump is not coming on at all then you have a bad drain pump motor. If it is trying to drain then you may have a clogged up drain hose. The most likely cause is a bad drain pump motor. Hope this helps.
Posted on Jan 11, 2009
MNTECH
  • 1543 Answers
I would guess that the impeller has come off the pump motor shaft. You can disassemble and push it back on, but it will come off again. I don't know if some type of adhesive would work, but I just replace the pump motor.
Drain water from small drain hose (or by removing filter) Remove the screw in the plastic recess by the filter, then use a putty knife on the left or right side to pop out the recess. Remove two more screws holding pump body to front frame of washer. Pull washer about 18 inches away from wall and tilt it back to lean against wall to allow access to the pump through the large rectangular hole in the base of the washer. There is a plastic locking tab holding the pump body to the plastic washer base, but don't worry if you break that, as the screws (removed earlier) will hold the pump back on just fine. Pump motor is held onto pump body with three more screws. Replace pump motor with a new one and reassemble. On a difficulty scale of 1 -10, this one might rate a 4.5 or a 5. Not too bad.
Leaking is rarely, if ever, caused by the drain pump. Small leaks can come from using too much soap, which backs up in the dispenser area and leaks down inside the machine, or larger leaks from a cut in the door gasket.
Posted on Apr 04, 2009
Noisy during spin cycle
Yes that is definitely bearing noise you here.
Jun 21, 2017 | LG Washing Machines
DOOR LEAKING
Check to see if door is warped or dropped down. Adjust same. Clean boot & door where they meet with detergent. Door lock mechanism worn & not holding door closed tightly. Some model have adjustments on door.
Dec 21, 2013 | LG WM-2277HW Front Load Washer
LG Tromm WM2277HW
Does spin only work well?
Apr 11, 2017 | LG WM-2277HW Front Load Washer
What are the child lock buttons
This feature will lock the control panel of the unit during operation so that the settings can not be adjusted during the cycle. This will not prevent the unit from being powered on or off, or the door from opening or closing.
Dec 31, 2010 | LG WM-2277HW Front Load Washer
During the wash and rinse cycle I have water seeping out of the bottom of the door on my LG washer. WM2277HW.
Give a good clean around the door seal and make sure you close it firmly.This does usually fix it but you can also twist the door manually to help the seal.
Oct 04, 2009 | LG WM-2277HW Front Load Washer
Jan 11, 2009 | LG WM-1480FHD Front Load Washer
Lg washer overfilling with water during first cycle
Feb 15, 2008 | Washing Machines
Washing Machines Logo
97 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
