Question about Xerox WorkCentre Pro 657 All-In-One Laser Printer
Xerox WorkCentre Pro 657 fix error 41 - Xerox WorkCentre Pro 657 All-In-One Laser Printer
3 Suggested Answers
  • 2072 Answers
SOURCE: Xerox Workcenter Pro 657 Memory Error
With a 657, most likely the main board has failed. It is not uncommon at all, That is a general problem with that model.
What you can try is, looking from the front of the machine, the main board is located on the back right side. removing 2 screws and releasing the levers will allow you to slide the processor board out of the machine. You can try just reseating,,,, removing and shoving the board back into the machine, and seeing if that helps.
Most likely, either the board has failed, or the memory battery had exceeded its life and the memory is not working.
Wish I had a more positive answer for you, but the 657 is getting older, and those lithium batteries are failing. I have to add though, that those processor boards, have failed pretty frequently over the years.
What you can do is go onto Google and look up "the parts drop" ,,, call them and ask for Britt, and see what he has as far as that producut is concerned. That machine is actually made byn Toshiba, you may be be able to find either a Xerox, or Toshiba repair dealer in your area that has that board and will fix it reasonably. If you find a Toshiba dealer other than a Xerox dealer. Tell them it is the same machine as a Toshiba E-120, they are exatly the same.
Posted on Oct 17, 2008
SOURCE: Xerox Workcentre PRO 635, 645,657 Memory Error
error #22
Posted on Nov 01, 2010
Problem connecting Win 7 64-bit to Xerox Workcentre M128 printer - Windows is giving a "no suitable driver found" error.
Try this link, it goes directly to the 64 bit driver download site.
http://www.support.xerox.com/support/workcentre-pro-123-128/downloads/enus.html
If that doesnt work. Go to www.xerox.com. Select support and drivers, in the search box, type 128, then go to the workcenterpro 123/128 and click on downloads and drivers.
You will find 32, 64 bit drivers for all OS.
Jan 27, 2011 | Xerox WorkCentre PRO 128 Copier
Is there a part number for the Xerox Work Pro 657 fax machine, I need to find a replacement
If you like to replace this machine, no, it is outdated.
Try shopping for a new machine.
If you are looking for a certain part, need to know what part is needed.
Jan 25, 2011 | Xerox WorkCentre Pro 580 Plain Paper Laser...
Error 116-364
Error 116-364 Problem with the Xerox WorkCentre Pro 123/128 Copier Finisher Staple Refills Copier. Dear i am also facing the same problem, It would be very helpful if you share the solution you may had come across. Thank you very much .
May 17, 2010 | Xerox WorkCentre Pro 123/128 Copier...
Xerox 657 drum reset instructions
need to replace 1/16 A pick-tale(brown color with strips on it) fuse on blank lamp assembly in drum unit
May 06, 2010 | Xerox WorkCentre Pro 635 Laser Printer
Blank page when I copy or print reports
Re check all the connections. When taking off the paper feed assay, other parts and plug and jack connections were needed to be taken off first.
Make sure the drum seats in its correct position, silver grounds are not bent.
The copy cartridge and Dev housing are not connecting very good somewhere.
Make sure the machine is unplugged.
Try running copies.
Apr 21, 2010 | Xerox WorkCentre Pro 580 Plain Paper Laser...
Work centre pro 657 memory error
at right side you can remove cover for the memory, remove it and clean contact, or else you need to replace it.
Apr 12, 2010 | Xerox WorkCentre Pro 635 Laser Printer
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: RDTCT0128FCZZ
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Oct 16, 2008 | Xerox WorkCentre Pro 635 Laser Printer
Xerox Workcentre Pro 123 error code 016-719
this is not a mechanical error but a software error.
It either doesn't recognise the format or program
as for the driver don't thinkit's the problem the HP can use PCL6
Sep 08, 2008 | Office Equipment & Supplies
47 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
