Question about Compaq Presario 700 470024-192 Notebook
Sound problem of compaq presario C797VU
When i use headphone ,both the headphone speaker and laptop inbuilt speaker remains active and volume control panel does not work properly, mute all is not working.I have installed operating system windows XP professional version 2002 service pack 2
  • Anonymous Nov 19, 2008
    exactly same problem
Sir i have no sound crivers can u give me c700
Posted on Oct 27, 2008
Onkyo mute channels. When turned on, one or more channels remain mute. Acts like a contact problem; when switched on-off-on multiple times, mute channels may vary
follow this steps and fix it. God bless you
The speakers are not connected properly. Check the speaker connections. The Mute function is activated. Turn off the Mute function. The volume is turned all the way down. Turn up the volume. Neither set of speakers is selected (if unit has A/B buttons to select sets of speakers). Press either A or B to select a set of speakers. Both sets of speakers are selected, but only one set is connected (if unit has A/B buttons to select sets of speakers). Press the appropriate button to deselect the speaker outputs which are not connected. The receiver is set to TAPE MONITOR (if applicable). Turn off TAPE MONITOR mode. Headphones are plugged into the main unit. Unplug the headphones. The source selector is set to the wrong source. Select the proper source. The impedance of the speakers is less than the rating for the system. Use speakers with the correct impedance rating.
Oct 11, 2013 | Onkyo TX-SR500 Receiver
Speakers don't mute with headphones on
When you plug headphones into a laptop computer, the laptop speakers are usually cut off automatically. However, if you wish to do this manually, there is a way. One common reason for shutting off the speakers is so that your quiet workplace won't fill up with sound if you should unplug the headset for some reason while playing music or performing some other sound-filled activity.
Muting the Speaker but Not the System On a typical laptop running Windows, left-click on the double chevrons of the "Show hidden icons" button in the Quick Launch toolbar at the bottom-right corner of the screen. This will display all your hidden quick-launch icons, and usually these will an include an icon of a speaker that launches the "Volume Control" utility. If not, then you can also access the Volume Control utility from the Control Panel, via the "Sounds and Audio Devices" application. Simply launch that application, click on the "Volume" tab, and click on the "Advanced" button in the "Device volume" section. In the Volume Control utility, click on the "Advanced" button near the bottom-left area of the window. Near the bottom of the advanced controls window, there will be a section labeled "Other Controls." Here you should see some kind of check-box option labeled something to the effect of "PC Speaker Mute." If you check that box and save your changes, the laptop's speakers will be shut off, but you will still be able to listen to any music or other sounds through your headset. It's as simple as that. To cancel the shutoff, simply uncheck the box and save your changes. This method works for all versions of Windows still widely in use. Hope this helps.
b>
Dec 23, 2012 | LG E500 Express Dual Series Notebook PC
The mike of my headphones is not working.Even the inbuilt sound recorder of windows XP can't record any sound from the mike..The mike is working fine in other Laptops.I have installed all the...
make sure that your mic input is not muted. look under control panel/sound and audio devices, then under your microphone, select "volume" and make sure the input is selected (with a chack mark in the box under the mic volume control) and not muted.
Oct 12, 2010 | Compaq Presario 700 470024-192 Notebook
Inbuilt speakers not working
Since you limited the details. See if the speaker wire is connected properly and to the proper audio card connection. See if the speaked control panel is not set to mute output and see if the volume control is not at min.
As you plug in the speaker wire to the card with the PC on do you hear andy crackling noises at all.
If not see if the speaker hardware is powered amd the hardware dials are working.
See in the device manager that the drivers for the audio is correct.
Aug 23, 2010 | Lenovo Computers & Internet
How can i set up the microphone on my acer ( aspire 3680 )
Go to Start - Control Panel - Sound - Recording - Recording and you will see a list of connected devices. Check that the Microphone is live and has a green tick and also that the driver name is present. Double click or Right Click the Microphone for setup options. If it is not working you may have to reinstall the sound driver.
If this is not working then check Start - Control Panel - Device Manager - Sound, Video and Game Controllers to see if there ay alerts or errors (highlighted in Yellow and Red respectively).
Also check Start - Control Panel - Device Manager - System Devices to see if there ay alerts or errors (highlighted in Yellow and Red respectively).
If there are no errors then you should be able to use the microphone successfully.
The volume may be muted. In Windows, look at the volume control icon on the taskbar. If it is crossed-out, click on the icon and deselect the Mute option.
• The volume level may be too low. In Windows, click on the volume control icon on the taskbar, and then use the slider control to increase the volume level.
• If headphones are connected to the headphone jack on the computer, your computer's built-in speakers will be turned off.
Oct 02, 2009 | Acer Aspire 3680 Laptop
My laptops speakers stopped working
Have you tried a pair of headphones to see if they work?
Is the sound ouput muted? (a lot of laptops have a physical button to
do this...
check to see if the laptop is muted. Also, check the
volume control to see if everything is up where it should be, including
Speaker Out.
If I've got this all straight, the only thing that it can be is an
issue with the plug on the speakers and the jack on the laptop.
Obviously the computer is putting out sound to the headphone jack as
evidenced by your ability to listen through headphones. The speakers
work on another computer. So, it has to be something specific about
the Speakers on this laptop. Plug/Jack problem is the only thing that
comes to mind.
Jun 24, 2009 | HP Compaq Presario 2500LA Notebook
Audio input/output problem
Dear user,,
Pl go to control panel and select sound/audio device and click and see you see install sound device.
pl double click on speaker symbol at taskbar.
see volume controler and selecting hedphone device and see it is mute or not
Regards,
Ravindra Shah
May 23, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
My Toshiba Satellite has a sounds problem
Make sure your volume controls are not muted and levels are midway.
Right Click on Speaker icon in lower right system tray and choose Open Volume Controls.
Nov 24, 2008 | Toshiba Satellite A100-S8111TD Notebook
Can't mute inbuilt speakers
That is not a software problem.
The headphones/external speakers jack socket has a switch to exclude from audio the internal speakers, when a jack plug is connected.
This is a very simple device and is not software controlled.
The fact that it has gone faulty at the same time you reinstalled the system is a coincidence.
If it does not mute when you insert headphones, all you can do is trying to play with the jack plug , inserting and pulling it out. If this does not unlock the switch, the alternative is having the jack socket replaced by a technician. This is generally an expensive repair, asthe socked is soldered on motherboard.
A cheap alternative to a proper repair is using an external USB to Audio Adapter and mute the internal audicard when using headphones.
Oct 19, 2008 | Computers & Internet
Mic
Try a different set of headphone, if it works, then it is the headphone set.
If you get same problem with all headphones, then
If you get no sound: ensure that you have sound from speaker, if you get sound from speakers and no headphone working, then there is a problem in the headphone connection.
If you have no sound at all , not even with speakers, then check audio settings in control panel, ensure audio is not muted. If audio settings are OK, then you need to reinstall audio driver, or you have a faulty audio card.
Additionally, if it is only the mic not working then do the following:
Go to control panel and open sound and audio device.
Open volume settings and find settings for mic.
Tick off the mute option.
The mic is muted by default in Windows, that is usually the reason why it is not working.
Sep 14, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 700 470024-192 Notebook Logo
177 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
