FixYa.com
Tags:
Motorola DCP-501 5.1 Channels Receiver
No sound
posted by TTM77 on Aug 26, 2006
Moto DCP501
Sound was very low when I first got it. But didn't use it much so didn't care. Now there is no sound at all. I've tried everything from switching A/B input, audio mode, plug in diff speakers, etc.
I even plug in a DMM to check the voltage just for the hel of it. a constant 2.49v on all speakers out while the movie is playing on the internal DVD player. Speakers measured 8 ohm as specified. I did a resistant check on all the speakers connection on the receiver side too and none of them shorted.
I"m stumped and need help before I open this thing too far off to put it back together correctly.
Thanks.
Comment by TTM77, posted on Aug 26, 2006
That's what I measured... DC voltage. I was hopping to see it changes but instead it give a constant 2.49v. I measured the speaker and it's still 8 Ohm so it's still good. If the speaker is fried the Ohm should be overload or short. But it didn't smoke or anything.
Open the receiver and don't smell any burn either. Inside there seem to be 2 decoder board because it has mpeg written on the board and chip. 1 board seem to do the amplification and it seem to not getting anything either. The main board will be a problem to troubleshoot since it has everything on it.
Anything else I could try?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Thanks for Trying (70)
techman
Rank:Guru Guru
Rating: 87%, 6564 votes
If you have a constant 2.49 volts on the speaker output Im surprised that your speakers are not smoking or making a BIG racket!!!? Sorry my friend you must have measured wrong as if you had a constant voltage on the speaker output, unluss the unit is a real cheapo unit, you wouldnt have speakers left or you would have smoke, as there should never be any DC voltage on the speaker outputs and if it was an ac voltage it would be making a big noise. Sounds like you should get a new unit or take this one into a repair shop. Good Luck
Rating Locked! (?) TTM77 has rated this solution as Thanks for Trying
Can you Help with these Receivers problems?
Activating Motorola DCP501
To whom this may concern, I... Answer This...
DCP501
Hi. I just bought one of these... Answer This...
Reciever is pumping out really...
My reciever is about a year... Answer This...
DVD player doesnt work...wont...
I bought the DCP501 used. When... Answer This...
DCP501 sound problem
Need board Digital Amp... Answer This...
Repair Service
Find Receiver Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
