Question about Brother MFC 7840W Printer
MFC-7860DW TONER LOW LIGHT DOES NOT GO AWAY
3 Suggested Answers
  • 133 Answers
SOURCE: MFC 7420 always say toner low after you change new toner
If you are using the MFC 7420, then you should see the option buttom just next with the LCD. press the option and hit 00. then the message will just go away.
Posted on Jun 14, 2009
SOURCE: I replaced the toner for brother MFC 7860DW and
Basickly, Toner cartridge has two sides one side to refill the toner,
other side has two screws, this is the side you have to work on,,
A- Remove 2 screws,,Remove cover out (( SLOWLY )) do not loose ther Gear
or the Spring,,
B- Turn The Big white Gear Full Turn,
C-reinstall the gear back.
D-But back two screws,
Good Luck,, Some times you have to try it 3 or 4 Times,,
Aslo you can see it in youtube...
David J.
Posted on Dec 10, 2011
After replace toner keep geting message JAM INSIDE but there is no jam papper
I have a brother printer too, nine times out of ten you have to make sure everything is closed tight
May 30, 2015 | Brother MFC 7860DW - Multifunction fax /...
How to reset " replace drum" for brother MFC-7860DW
Time to really order a new drum and really replace with a new one.
Resetting the drum unit will not improve print quality. It only resets your drum and allows you to continue to print. You decide when to replace the drum unit not the manufacturer!
1.Remove the drum unit and toner cartridge. Wait 1 or 2 minutes.
2.Replace the drum unit and toner cartridge into printer.
3.The error message "Change Drum Soon/Drum end soon" will continue to appear if the drum counter was not reset when you replace the drum unit.
4.To clear this error message, you need to reset the drum counter as instructed below.
5.Make sure that the machine is turned on.
6.Press Options.
To confirm you are installing a new drum, press 1.
7.When the LCD shows Accepted, close the front cover.
8.Your drum is now reset.
Jul 30, 2014 | Brother MFC-7860DW Laser All-In-One
Why do printouts have increasingly larger blank margins?
Go to the printer's settings menu and look for an option to "Restore Default Settings" or similar words.
Jul 30, 2014 | Brother MFC 7860DW - Multifunction fax /...
Says manual feed. Load paper
There is a manual fee slot just above the paper tray. Sounds like the manual feed slot isn't closed all the way. Here's a link to support for your machine: MFC 7860DW Others Brother Solutions Center Note there is a firmware update available.
Jun 19, 2014 | Brother MFC 7860DW - Multifunction fax /...
How do you reset a replace toner error on brother printer
Open the front cover of the printer
Press and release the "clear" key
Press "start", then press the up arrow until you see the number 12 on the display
Press "ok", you will see "accepted" on the display
Close the front cover, your toner cartridge should now work.
Apr 07, 2014 | Brother MFC-7860DW - Laser Multifunction...
I replaced the toner for brother MFC 7860DW and still getting replace toner message. I cannot print. Please help. thanks
1. lift lid and open front cover
2. press clear/back. "Replace Drum?" will appear on the screen.
3. Press "*00" it will then read accepted and the toner low error (End
of Toner Life) should go away.
4. close it all up and your done.
Oct 17, 2011 | Brother MFC 7840W Printer
Feb 10, 2009 | Brother MFC 8300 Laser Printer
Brother MFC 7840W Printer Logo
76 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
