CD disk drive won't work or open
Running vista, and my disk drive won't open/work? I have run diagnostic and says its running properly, thats false. The release button doesn't respond and the disk wont spin/read. Please me know mcneilp@live.com
  • 43 Answers
You need to replace the disk drive , the optical lens is not working and that way is not spin
Posted on Feb 20, 2012
Windows xp won't open
Run diagnostics on the disk to see if the drive is failing.
If it's ok then do an XP repair install.
Sep 10, 2012 | Computers & Internet
No diagnostic utility partition found to run diagnostics
Think about this for a min.
The Primary hard disk cannot be found by the System.
The Diagnostic Utility is ON the Primary hard disk.....OF COURSE IT WON'T FIND IT...
Since the motherboard is not able to even detect the drive as being present, there is nothing YOU can do to get it 'going' unless you replace the BAD hard drive with a new one.
[PS: I hope you've backed-up any important data....]
Aug 31, 2012 | Dell Latitude C640 Intel Pentium 4-M...
I have an Acer Aspire 5332 and the CD-Rom/DVD Drive (Optiarc DVD RW AD-7580S ATA Device) is not working properly...every time I put a disk of any kind (i.e CD/DVD/Game) it doesnt recognize it and load
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Mar 22, 2012 | Acer Computers & Internet
The CD won't spin
there are lens cleaner cds with liquid cleaner. get that kit & run this cd with cleaner on its brushes. if still not working unplug the system & open the cover & see there is lens on cd drive unit. clean upper surface gently with soft cloth. if not working then replace the cd drive mechanism.
Aug 25, 2011 | Bose & Wave& Music System
My cd/dvd drive G:\ (hl dt st rw dvd gcc h21n version.1.00) does not reads windows 7 dvd .. and it only reads cd-r/cd-rw.... plzzz help i want to install windows 7... plzz help...
It sounds like your drive is having issues, you can always install windows 7 from a flash drive (so long as your computer supports booting to one). Instructions on setting this up are here: http://www.intowindows.com/how-to-install-windows-7vista-from-usb-drive-detailed-100-working-guide/ You will need to do this from a computer with a working DVD drive to transfer the info to a flash drive.
Jun 28, 2011 | Computers & Internet
My 5 year old Toshiba U300-13u is extremely slow and the disk drive isn't recognised and doesn't open. It is core2duo but is supremely bad. The battery life is about 20 minutes. Can Overuse be...
No, it is not need to apgrade, it will be good to reinstall your windows system, on it you can install Windows 7 32bit too, /if you have driver pack for windows7/, if no, reinstall vista 32bit, no problem, will be right, After it if your cd\dvd drive will not work, you can change only it.
May 30, 2011 | Toshiba Computers & Internet
I was doing an "update" and when it asked to
Sounds like your update went didn't work right. This could have been caused by a corrupted update file that Vista tried to install or you might have a hardware problem (i.e.bad hard drive). Try running the Dell diagnostics. Do you have any CD's thatcame with your computer? If so, look for one that has "Diagnostics and utilities"listed under the "Contents". You will have to boot from that CD disk. To dothis, power on your laptop and tap the key to bring you to the "Onetime boot menu". Insert the CD and then select CD/DVD drive and hit key. Select the "Run the32 Bit Dell Diagnostics". Next select the "Express Test" and see if any errorsare detected. If no errors are reported, then your operating system software isprobably the culprit.
May 15, 2011 | Dell Inspiron 530s Desktop Computer
My dell inspiron 1721 is stuck on start up. The screen with ctrl + F to enter build utility. Ive tried to reinstall vista but on the install. I get stuck on the load drivers screen. I have the drivers on...
Hi, first of all have you tried to run the diagnostics just to ensure the hardware functionality of your computer? if not, here's how: As the computer boots, press when the Dell Splash Screen appears. When the Boot menu appears, highlight the Boot to Utility Partitionoption, or the Diagnostics option and then press to start the 32-bit Dell Diagnostics. Press the key to highlight Test System Press to continue to 32-bit Diagnostics. Note: Express Test is the only test that will not require user involvement.
If there's no error found, that means, that your hardware most esp the hard drive (HDD) that came with your system is perfectly working fine and this isolated your issue that it's the operating system problem. It's good to know that you attempted to rebuild the OS just make sure it's the recovery cd that came with the computer. try to boot from the OS cd once again and reload / reinstall Vista. Here's the link for your reference (see step 4): http://support.dell.com/support/topics/global.aspx/support/kcs/document?&docid=DSN_339949&isLegacy=true#Issue4
Apr 23, 2011 | Dell Inspiron 1721 Notebook
My pc was dislpaying''DISK BOOT FAILUER, INSERT DISK AND PRESS ENTER'' but I did not install any new hardware neither do I have any cd on any drive.
I'm afraid you need to reinstall your windows/linux again. That or check if your harddrive is connected and working properly.
Oct 20, 2010 | Computers & Internet
I have an acer laptop with vista home premium and recently the cursor has started to blink for some reason. It blinks regardless of what form it takes like if its loading or just a normal cursor and it...
As for the running slower on windows vista, you need to actually turn off all the graphics on vista and roll it back to the 2000 interface.
But first, however, try a system restore to when it worked properly. If that doesn't work, then if you have the windows vista cd, load that into the system (even if it is a recovery cd, and fix the boot record). Try this first, then, if it doesn't work, post a response.
Aug 09, 2009 | Microsoft Windows Vista Home Premium...
Computers & Internet Logo
David Payne
David Payne
