Question about Sharp Office Equipment & Supplies
My sharp qs-1660 paper feed will not stop running
Paper feed motor run continuously
  • 40 Answers
SOURCE: Oki ML395 printer, paper continues to feed
your paper feed sensor maybe stuck or a piece of paper could be stuck in the sensor.Hope this helps ?
Dezzi
Posted on Nov 29, 2008
SOURCE: Sharp UX-184 Paper Feed
On inside of machine it states how to:
1. Place new paper roll on the left hub while pushing it in, lowering the roll into the compartment making sure it is inserted onto the right hub.
2. Pass the leading edge of the paper through the paper cutter guide and the cutter.
3. Remove any slack in the paper.
4. Close the cover. The paper will feed out automatically.
The paper rolls over top front to back.
Posted on Mar 05, 2009
  • 133 Answers
SOURCE: Paper no longer feeds in. Motor works.
Please check the sensor is on or off.
if paper is feeding completely then it means you need to buy a new one.
Posted on May 23, 2009
SOURCE: canon pc 420 paper feeds only part way
I had the same problem. I found a parts diagram here http://techno-parts.org/canon/220/320_220.php which showed that the springs hold the bar down. On mine, on each side, one of the spring tabs was broken.
I made a metal pin for one side and insert a screw on the other. Be sure and wrap the spring over the nylon bushing.
Posted on Apr 04, 2010
  • 23 Answers
SOURCE: wire feed motor will not run even without the wire
Probably the bridge rectifier. I had a 120 and thats what happened to it...
Posted on May 18, 2010
When I put the paper in the feed, it just feeds without printing anything. I am unable to stop the printer, what can I do?
I have had part of this problem in the past. My printer kept printing and would not stop. In the end, I pulled the plug. Once up and running again, it was fine.
I expect you've checked ink levels. If they are ok, try taking out the ink cartridge and putting it back in, the start up again. The printer should then print a test page, and stop afterwards.
This is very basic, I'm not techie. If it continues to continually send out paper without printing, you probably need an expert. Good luck, hope it sorts itself out.
Aug 22, 2015 | Office Equipment & Supplies
My shredder worked fine but now when I turn on it does not stop running and does not shred paper ?
Most shredders will have a shred and a reverse setting. Is it running in reverse? Has the bin been emptied? With the power off, you can remove the bin and manually pull excess shredded paper jammed in the cutting heads -watch out, sharp metal . Once cleared run single sheets for the first minute to help clear rollers.
Jan 05, 2015 | Shredder Office Equipment & Supplies
The motor on my shredder does not run smoothly anymore. The motor is pulsing. This started when I think I feed the machine too much paper.
Turn off power and turn the shredder upside down. Check for paper shreds jammed in the shredder wheels. Remove all that remains. If the motor continues to pulse, you may have damaged the drive mechanism
Jan 02, 2013 | Office Equipment & Supplies
Sharp AR 207 paper gets lifted out of tray but will not continue to feed into machine. Side feed works fine
try cleaning the paper feed rollers in (above) the tray. and the rollers on the right side (theres 3 gray rollers) If thats works you will need to replace the rollers soon.
Aug 28, 2010 | Sharp AR-207 Copier
Continue warmup sound, even copier is redy for use
Hello sir;Would you let the machine running until it stop( it will stop) if after it stop with the red triangle simple show out the mean the machine toner motor defect, please let me know the resolve.
Jul 23, 2009 | Sharp AL-1642CS Copier
Paper feed roller continuously rolling
The problem lies in the solenoid and or the frame that hold the solenoid so your feeder roller never stop rolling
Jun 08, 2009 | Sharp AL-1000 Laser Printer
Hp LaserJet 1100: Runs louder than normal and continuously, BUT will not grab paper and print
Fred shine a flashlight down the paper feed throat and see if the feer roller is rotating when the printer tries to print.
I have had to replace many of the feed rolls and separation pads in this series of printer.
the tires get dirty or worn and feed multiple sheets or none at all. check for obstructions as well-sometimes the black mylar sheet which sits in front of the feed roll gets in the way of the paper path and has to be pushed in place. I have also seen paper pieces stuck next to the paper path switch which is visible after removing the toner cartridge. hope this helps.
Mar 28, 2008 | HP LaserJet 1100 Printer
Sharp AL-800 Paper Feed
Is this something that has been getting worse or just happen at once? If it just appeared it good be something in the paper tray stopping it from liftting or something behind the paper tray or in the paper path of the copier. If it has been slowly happen try to clean the paper pickup rollers with WD-40 and a rag and clean the rubber only. If that works you done, but if it say's to add paper you may have a broken paper present sensor. The jams could also be the paper feed clutch is worn out. Worse case use the bypass tray. Good Luck!!
Feb 07, 2008 | Sharp AL 800 Copier
Ativa DQ120D shredder
I had the same problem with my Shredded. In the centre of the paper feed slot is a little sensor that detects when you put paper in, it breaks some sort of light beam that is connected to the motor circuit.
Over time paper dust gathers on this sensor, covering it completely and fooling the machine to think that there is ALWAYS a piece of paper being fed into the shredder, the result being that the motor just runs continuously.
Clear the dust from this sensor and you'll fix this particular problem - a toothbrush worked great for me - don't use it to clean your teeth afterwards :-)
FIXYA!!!
Dec 11, 2007 | Office Equipment & Supplies
My techko SH 3112Fa won't turn off
FIXYA!!!
Oct 11, 2007 | Office Equipment & Supplies
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
