Question about Watches
Nine west watch band adjustment - Watches
escapement
  • 2334 Answers
SOURCE: How to adjust Skagen watch band.
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 10, 2009
SOURCE: Watch Band Adjustment
I think maybe we're all too familiar with the little old watchmaker image, loupe in right eye with tiny tools at hand......The links that have the arrows on them are indeed removable, it just takes more force than you might think. I'm in my office, so I used a pushpin (like for bulletin boards) and yep, it took more force than I thought, but the pin did come out the other side. A little tug with needle nose pliers and out it came. Remove link, repeat as necessary. Good luck
Posted on Jan 10, 2008
slp11508
  • 43 Answers
SOURCE: adjust expandable watch bands- Timex watch
Most expandable watch bands aren't sizable. IF it is sizable you will be able to tell when you stretch the bracelet out. If it looks like you can unlatch the links when you stretch it out then you might be in luck, but like I said, most are not sizable.
Posted on Jan 05, 2009
  • 12 Answers
SOURCE: Adjust-a-Casio-S-1087DY-Watch-Band
On most brands, there are pins that form hinges for the links of strap. You need to push them out to remove links. Usually you would find arrows marked from inside of the metal bracelet which show you the direction in which to remove the pins. You can remove it if you have a small watch maker's screwdriver but you have to be careful. or get one of these ..
http://www.amazon.co.uk/Watch-bracelet-link-adjuster-remover/dp/B001ZKIL2S/ref=sr_1_1?ie=UTF8&s=watch&qid=1254695541&sr=8-1
which should help you to remove the link pins safely without scratching.
Posted on Oct 04, 2009
escapement
  • 2334 Answers
SOURCE: Adjust Watch Band
Click on my profile, then click on TIPS AND TRICKS. There you will find explanation how to add or remove links. Rate me, plz.
Posted on Feb 25, 2010
Montres Carlo. How can I shorten the band?
WATCH BAND ADJUSTMENT / RESIZE - HOW TO - YouTube
? 5:51
https://www.youtube.com/watch?v=N42D4lwD5Ok
Dec 25, 2013 - Uploaded by Phil Crockett
This video shows how to adjust the size of a watch band by removing extra links. This video is "to ... +Jay Carlo Aguilar Glad my video helped you out! Makes my .... Can't wait to challenge my smartass Grandkids to figure it out.
How to Resize / Adjust a Watch Band - YouTube
? 6:39
https://www.youtube.com/watch?v=o3NfebIjLlU
Sep 15, 2012 - Uploaded by Nils Rasmusson
Learn how to adjust a metal / silver / gold watch band or how to resize a ... A couple of pins on my watch broke and I bet I caneasily fix this for ...
Jan 19, 2016 | Watches
BEVERLYHILLS POLO CLUB WATCH MEN
Put a screw driver in the hole on the clasp. It shouls flip up and then you can slide the clasp up and down the watch band.
Dec 26, 2012 | Watches
Can the band on my Ed Hardy watch be adjusted? It is much too large. Do you think a jeweler can make the band smaller? There is some kind of clip on the underside of the watch band.
yes, it can be adjusted. just bring it to watch expert and surely they know what to do. any watch are made are adjustable to fit in customer's wrists.
Jul 18, 2011 | Watches
Adjust Watch Band
Feb 24, 2010 | Timex Ironman Triathlon Hi Ti Watch,...
How do you adjust the band?
Read my tips and tricks. Watch band is called bracelet as well.
Jan 23, 2010 | Casio Wave Ceptor Atomic WV300DA 7A...
How to adjust Relic ZR15539 watch band
Depends on the type of band. Is it a twist-o-flex or solid link? Your best bet is to seek out a local watch repair business and let them adjust it for you! Unless you do these often it can be frustrating and you could lose small parts!
Jan 09, 2010 | Relic Watches
I just bought a skagen stainless steel mesh band watch. I am trying to adjust the band to make it shorter. I have the piece the moves open, but I cannot figure out how to get it shut again.
http://www.skagen.com/service/watchInstructions.fx#adjustment
your watch has the skagen signature mesh band. its actually very easy to adjust once you figure it out all you need is a small screwdriver.
Dec 21, 2009 | Skagen Signature Mesh watch
Adjust expandable watch bands- Timex watch
Dec 29, 2008 | Seiko Diver's Watch
How do I adjust my timex wr 30m watch stretch band?
It's very difficult. You have to take the decorative link covering off first, then continue with the actual stretch band by following these directions.
http://www.watchmaterial.com/How_to_size_a_watch_band.asp
Feb 13, 2008 | Watches
Watches Logo
1,270 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
