Manual for strong 540se digital set top box
Model 540se digital set top box
2 Suggested Answers
rodamo
  • 224 Answers
SOURCE: no manual for bush digital set top box model
http://www.usersmanualguide.com/
try here
Posted on May 04, 2009
Need a manual or connection diagram for a AWA set top box Model No. 2030
Hi Anonymous, The link below is a FREE 10 page user manual for an AWA digital set top box model number 2030..........CHEERS..
http://cncms.com.au/AWA-IMs/SetTopBox/DT2030.pdf
May 02, 2016 | Televison & Video
Strong srt 5406
Try a code search method. Refer its user manual for details. If it too doesn't help you, buy an other remote control, which have setup codes to your device. If you wish to buy a genuine remote control, contact the authorized service center, or authorized dealer. If you wish to buy a universal remote control, you should first make sure about the number of digits in the set-up code, for the device you have. For example: some brand sets will have four digits in its set-up code, some of them will have three digits, and so on. There are devices that need even a single digit or 2 digit or 5 digit codes. Check how many digits code your device has to synchronize with. It is so easy to check, just enter any digit from your remote control, when the set asks for code. See, if you're entering Zeros, repeatedly, when the set asks code, and the set allows you to enter only 3 Zeros, means, the set-up code to your set should have Three Digits one.
Now visit the sites I've linked here. Both the sites have set-up code list, and set-up procedure to many popular brand remote controls. Check it, and find out which brand remote control have setup codes to your device, and buy that one according to availability. Keep in mind; when you buy a universal remote control, it will have setup code list, and setup procedure along with its catalogue. Never accept a remote control, with out this document. See the sites by "Mosaic" view; which will make surf easy.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Jan 24, 2014 | Televison & Video
Can not tune tv since change over
The KV-32FS100 only has an analog tuner (NTSC). Unless there is a low-power analog station still broadcasting in your area, you will not be able to watch OTA stations. (I've got one in my area that barely comes in.) If your local cable still sends an analog signal, you won't need a set top box to watch that subscribed service.
Otherwise, you need a set top box to watch TV. A digital to analog converter (the boxes that were available with the government coupon before the switch over) will give you over the air stations. The basic models only provide SD output; there are a few HD models available. Otherwise, you can use a satellite reciever, cable box (for digital cable service), or something like the Boxee or Sling with tuner. (There are a few different models of the Boxee; one added a tuner with a USB dongle. The newest model of the Boxee has the ATSC tuner built in.)
Note: OTA digital signal quality is either a strong enough signal for the tuner or no signal will be present. You need to point the antenna in the correct direction to receive the signal from your local transmitters. The type of antenna and its placement will also change the number of watchable channels. You can use antennaweb.org or tvfool.com to get more information. Antennaweb assumes an outdoor antenna but gives a conservative list of stations. If the signal is split to several devices, you may need an amplifier to get a watchable signal. (Sometimes amplifiers fail and you won't receive any stations, so test without the splitter or amplifier by using a direct cable to one TV.)
I hope this helps.
Oct 26, 2012 | Sony FD Trinitron WEGA KV-32FS100 32" TV
I have a sonic qmedia set top box model DVB16 and have lost the manual and cant set up the set top box to get digital tv. is there an easy solution..cheers..Norm
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Mar 28, 2011 | Televison & Video
Universal Remote Control code for Strong STB
i need the code of strong reciver for remote control
Feb 13, 2010 | Televison & Video
Strong 5405E set top box
Strong SRT 5006 Set top Box - how to unlock Channels so they dont require password everytime??
Jun 19, 2009 | Televison & Video
4 digit code for handheld remote control to program a Crest Universal remote control
Here are the codes for the RCP3 and RCP5:
RCP3 1023 1024 1074
RCP5 1014 1024 1074
May 12, 2009 | Televison & Video
Canon 20D strong blue cast to pictures
You probably have the White Balance set to a setting other a
than "Auto White Balance" (AWB). On the top of the camera, above the exterior LCD panel, there is the "AF-WB" button. Turn the camera on--past "on" to the bent line. Press the AF-WB button once. On the left side of the exterior LCD panel there is a vertical, reticular box with the symbol of the selected setting for WB. Normally, the setting should be set to AWB. If it is not, turn the command dial at the back of the camera until "AWB" is showing. Try shooting again-the color should be better.
In the "auto" modes (green box, portrait, landscape, etc) the AWB is automatically set. In the "advanced" modes (P,Tv, etc) the WB is manually set for whatever light source you are using. The command dial may have been accidently turned to different setting. Hope this helps.
Jan 23, 2008 | Canon EOS-20D Body only Digital Camera
Strong high definition set top box
Binkanath:
This posting is in the area for Canon Fax JX200 issues. In order to receive a response from an expert in the area you need, I would suggest seeking out the proper equipment make, model, etc., and reposting the question. However, you will need to include the details of your equipment for us to help you. Thank you for using and rating FixYa!
Oct 04, 2007 | Canon FAX-JX200
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
