Question about Marantz SR-5200 Receiver
Marantz SR5200 - front speakers not working unless direct
My Marantz SR5200 has decided not to put signal through the front speakers unless the signal path is switched to direct. In any other mode, including 6 channel stereo or DTS, I only get a signal in the centre speaker, sub and 2 rears. I've tried the test tones and same applies... nothing in front L & R. Even the on board tuner only does the same, so its definetly internal. Is there any way to do a complete reset of the SR5200 or does it need to go to a techy for a service?
  • 3 more comments
  • Craig Saward Aug 28, 2006
    Saved by Techman!
    Obviously my 20 second power out didn't help but the suggested 24 hrs seems to have done the job. Thanks heaps!
  • Craig Saward Aug 30, 2006
    All too early.... happened again and this time no 24 hour solution. Off to the repair men it seems!
  • ibantxo28 Mar 21, 2009
    Anybody solved this problem? I have the same problem. Suddenly a very loud "pop" is hear from the speakers and center speaker is gone out. No voice is been hear, only music. In front-center speaker a noise is hear (in a very low level).
    I think it must be because Digital to Analog converter is working very bad.
    Any help?
    Many thanks
    Any help?
    Many thanks
  • hoang viet
    hoang viet Feb 15, 2017
    I've fixed it by replacing CS4391 IC. After changing sounds very good Left speaker but Right speaker also be too small. Help me fix it
    Thanks
    President:
  • 3,130 Answers
If you try and unplug it at least 12 to 24 hours and it does the same thing, then its time to take it in to the shop.
Posted on Aug 26, 2006
Hello, I have a SR5200 and am experiencing a very similar problem. Usually the system works fine, but every so often the front channels cut out and in stereo mode all I hear is base from the subwoofer. Sometimes the front channels return if I power the unit off and on - but sometimes they'll only return for a few minutes before cutting out again - sometimes they don't return. Sometimes the front channels cut out for a few seconds then come back themselves! Strange... Has anyone had this problem repaired? Any ideas what it could be? Thanks, Danny Blair
Posted on Apr 27, 2007
Dear Muzzleblast Did you solved the problem with your Marantz 5200. I am from Brazil, and I am having the same problem with my 5200. Thank you Eduardo
Posted on Oct 31, 2006
Marantz SR5200 Turns on and off by itself
Thermal cutoff is operating. There is excessive heat being generated on the heat sinks of the Amp. This happens when there is a shorted output transistor or a speaker load changing.
Nov 09, 2017 | Marantz Audio Players & Recorders
MARANTZ sr5200 Left Speaker larger sound right speaker
If you are saying that the left side is LOUDER than the right it could be DC offset on the recording or it could be phasing issues.
Feb 15, 2017 | Marantz Audio Players & Recorders
Marantz NR1402 AV receiver Going to standby Mode
There could be a short in one (or more) of the speaker connections. Try disconnecting all speakers and turning on the receiver. If it still switches to standby, there may be an internal problem.
Mar 03, 2014 | Marantz Nr1402 Av Receiver
I am thinking of replacing my now very old JVC AX 330 amplifier with a Marantz PM7003 amplifier and want to know if this is a suitable replacement in terms of power output etc.
You, sir, are a rare adherent to stereo-only electronics. Are you replacing it for cause (showing its age)? The PM7003 is only 2 x 70 watts like the JVC but it also has separable preamp/amps so you COULD upgrade or augment the power output with external amps and still control it all locally.
Of course, any current AVR's do that too and bring digital sources and multichannel audio to the mix for as little as the PM7703 may cost.
Jun 23, 2011 | Audio Players & Recorders
My marantz sr5200 powered off and won't turn back on. What do I do? There is a light flashing red. this is not an overheating problem or fuse problem. It happened when I was trying to program the...
try to reset the memory circuits, the info on them may be corrupted, try this:
1 disconnect the plug from the AC line supply
2 wait 10 minutes then, reconnect the plug to the AC
outlet
3 try to operate the equipment.
now.. if above does not work you may have to contact the manufacturer as
the issue could be related with the internal circuitry.
good luck!
Apr 11, 2010 | Marantz SR-5000
My marantz sr5200 dont reproduce dobly digital signals , maybe junt 2 channels.
I have the Marantz SR5200, unable to get the Set-up / t.tone button to work, don't have the instructions,
Mar 19, 2010 | Marantz SR-5200 Receiver
Receiver Sr5200 shut down in 5.1 mode
chances are you have the volume too loud and the speaker wires are crossed.
all speaker wires need to be with the positive on the right and negative on the left if you have them anywhichway than it will work on low volume and not a very good sound.
look closely at the wires and they should have a red or so color on one side or the wire jacket itself will have a round side and a flat side
Apr 21, 2009 | Marantz SR-5200 Receiver
No sound out of speakers (Marantz SR5200 receiver)
sounds like you might need to open it up and check the speaker wires that you plug your speakers up to it might be lose or something else like that cause it happened to me before and that was it.
Feb 21, 2009 | Marantz SR-5200 Receiver
Marantz SR5200 receiver works only with remote not manually
Check for a stuck/jammed switch, press each switch if one doesn't make a normal click sound or it doesn't move at all that's your problem.
If that's not it check the owners manual for how to reset the receiver (not all manuals will tell you how to reset it) Another way to reset it is to short the memory cap, but that is better left to a tech.
Feb 11, 2009 | Marantz SR-5200 Receiver
Marantz SR-5200 Receiver Logo
1,657 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
