Question about Jandy Laars Lt 250,000 Btu Heater
Jandy lt 250L pool heater problems
When i try to light my heater, the blower comes on for only about 5 seconds, does not try to light then goes off, then comes on again for a second or so, then off, then on again for a second or so, this goes on for a couple of minutes then it shoes an error message of air flow switch ( air flo- sw)
    Top Expert:
  • Jandy Master
  • 6,498 Answers
Bad ignitor
Posted on May 28, 2015
  • 22 Answers
SOURCE: Jandy, Lite 2 Pool heater wont kick in
3/4 pipe line will work and will keep heater from sooting up.
Posted on Feb 18, 2009
SOURCE: low pressure reading on Pool Heater
I had this problem with ours last year. I replaced the water pressure switch and it began working fine. We later had a symptom that the blower would start but it would not ignite. The ignitor rod was corroded so I took it out and sanded it with some sandpaper---worked fine...until I dropped it trying to reinstall and it broke. Bought a new one and it works fine now.
Today's problem is related to the blower now.... it is always something, isn't it?!?
Posted on May 30, 2009
  • 128 Answers
SOURCE: Where is the Air Flow switch on a Jandy LX natural
The air flow switch is in the upper panel on the inside of the heater. There are gray hoses plugged into it.
Posted on Aug 23, 2009
  • 8404 Answers
SOURCE: Jandy Aqualink RS4 randomly turns on blower, pump, heater
Re program your assorted timer functions and make sure you set AM and PM or use a 24 hour clock. I think your model allows for a 24 hour clock setting but I am not certain.
I hope this helps you
a
Posted on Oct 09, 2009
  • 246 Answers
SOURCE: getting error code 188E on Jandy Model LT Lite 2
press the arrow key for 10 sec this will reset the heater. if code replace control board, if not enter time date and set temptures for pool and spa
Posted on Oct 16, 2009
I have a jandy LT200 propane heater which doesn't turn on. When power is on the lights on electronic board all flash once and then go off. 2amp fuse going to transistor is fine, not blown. I replaced the...
If this heater is hooked up to automation check the temperature reading on the indoor remote. If it reading over 104 the sensor is bad and the heater will not fire thinking that it is at set temp.
Oct 29, 2013 | Jandy Laars Lt 250,000 Btu Heater
HEATER IGNITES AND WORKS FOR A FEW MINUTES, THEN SERVICE LIGHT AND AIR FLOW LIGHT COMES ON
either air flow switch is faulty, blower isnt producing enough air pressure or blockage in venting
Mar 17, 2013 | Jandy Laars Lt 400,000 Btu Heater
Jandy pool heater wont stay on the blower kicks on the ignitor glows it lights and then 4 seconds later goes out and i get ignition fault code. please help me out
most likely problem is incorrect gas pressure or a clog in the gas line. If this is a propane heater (you did not specify) then the owners manual is wrong on the gas pressure, you should call the manufacture to get the correct settings for propane.
Either way you need an experienced gas person to come set the gas properly.
Also I had serious problems until I had the gas company install a regulator right next to the heater (so the entire under ground gas line was high pressure). I use to have a regulator next to my house so low pressure fed all the way from my house to the heater (200ft) and this caused serious problems like this.
I also had a regulator break on me one year. It basically stopped putting out the right pressure.
Lastly the flame sensor could simply be bad. If you are still having this problem I can explain how to remove and test the flame sensor. It is easy to test and easy to replace.
Apr 04, 2010 | Jandy Laars Lt 400,000 Btu Heater
Service light and ags light comes on after a minute or two
I had this problem. Jandy ended up replacing the burner from day 1 with the heater (LT400 propane). It was a manufacturing defect. Of course it took 5 trips from the "warranty" company to not fix it before they finally punted to Jandy. Then, there's only one Jandy service rep from VA to ME (I'm in PA).
Jan 27, 2010 | Jandy Laars Lt 400,000 Btu Heater
Power light blinks after blower turns on. Water is barely coming out luke warm after 30m of running. No other status lights lit.
The water is mixed with cool water as it leaves the heater and will only be eight to ten degres hotter than when it goes into the heater so as to avoide scalding. You need to ck the total heat rise of the water after about an hour in a spa and after about three or four hours in a pool.
Nov 21, 2009 | Jandy Laars Lt 400,000 Btu Heater
Laars Lt heater will not start- pressure switch light
it is time to check your filter make sure is not dirty and if your filter is clean and still doing this then the problem can be with one of the safety sensors they do have 2 hight limit switch located in the heater heather they re round with two wires on each one turn power off to heater and get a voltemer reader and check the hight limits for continuty they should read zero on your metter it can be your temp sensor heaters are so complicated that it is always good to have a pool tech service it I was a pool tech in california but now I am located in georgia
Jun 13, 2009 | Jandy Laars Lt 250,000 Btu Heater
Heater doesn't come on
check pressure switch and copper tube
Feb 28, 2009 | Jandy Laars Lt 400,000 Btu Heater
Teledyne Pool Heater
I am having the same issue. The heater will go through a cycle of where first a blower starts, then the heater ignites, runs for about 10 seconds, and then stops. Then it does the whole cycle again. It will do this over and over.
I have read the problem is that the ignition detection switch may not be working. they suggested using some emory paper to clean it off, and then try again.
Dec 13, 2008 | Jandy Laars Lt 250,000 Btu Heater
Jandy Laars Lt 250,000 Btu Heater Logo
106 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
