Question about HP Compaq Presario V5000T Notebook
Laptop wont turn up
I have a compaq presario v5000 and it will not pwr up. i plug in the cord and still nothing. i dont think its the batt. i hit the pwr button and the battery lite blinks.?
  • sakdsfhsl May 11, 2010
    Does the backlight come on (does the screen get noticeably brighter) or when you try to power up does nothing happen (besides the blinking battery light)?
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    ok..remove battery and run it on the mains only..and report back please..
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
Check the adapter.If it is good then its the DC jack.The only other thing it could be is the motherboard.
Posted on Jul 03, 2009
My compaq presario v5000 does not power on?
Please try to plug the power cord into the source and used DC power source. Let the laptop charge for 5 - 10 minutes then after the given time please turn on the laptop. If it does not work extend the time from5 -10 to 15 - 30 minutes then repeat the stpes again. If it does not turn on then please try to check if the battery is charging. Then if all the procedure you have already perform and still no positive result then i advice you to please find a computer technician in your please and let that person fix the problem for you.
Thanks
Aug 04, 2009 | Toshiba Satellite M40-S417TD Notebook
Computers turns on and turns off in about 5 seconds by itself
may be your reset button is pressed on....so you better unscrew your computer and then remove the plugged in botton that is lined from reset button (u can follow the layout diagrams inside the computer)... ..i think it may help you ... later you can take out the pressed reset button as well....
Apr 12, 2009 | Compaq Presario V5102NR Notebook
Compaq laptop won't turn on
Take out the battery completely and only hook up the adaptor and see if it turns on then. If it turns on then your battery is bad. If you try both adaptors and get the same flashing lights then the motherboard is bad.
Feb 04, 2009 | HP 435768-001 - Compaq Presario C300...
BSOD when volume turned up on compaq presario v5000
This is usually caused by a fault on the Motherboard, nothing much will help in this case except replacing the motherboard.
Jan 30, 2009 | Compaq Presario Notebook
Needing to fix a compaq presario v5000
The screens on these computers can and will go dead after a while, afterall its an old computer..try an external desktop monitor by plugging it in the back(blue port)
If you want a new screen go here
Good luck..and if you have any questions about your armada just ask.. I have 5 of them.
Oct 01, 2008 | Compaq (241995001) Plug-In Module (Laptop)...
S-Video port on my Compac Presario V5000 Laptop
try installing manufacturers Drivers for your video card... You're probably using the "default" drivers.. Might fix it to get the current ..
May 17, 2008 | Compaq Presario-Notebook 900 Series Video...
Compac Presario V5000 S-Video problem
Perhaps you can change your resolution or your refresh rate on the out to TV? Give it a try.
May 17, 2008 | HP Compaq nc6230 Notebook
Compaq presario v5000
This series of compaq laptops have an issue with current draw on the mainboard, you will need to send it to compaq for a new mainboard.
Feb 18, 2008 | HP Compaq Presario V5000Z Notebook
My compaq presario v5000 shut down and wont restart
Depending on your Bios Version I think later then V44 fixed a bug that would cause your computer no to start if the battery was dead with the V5000. Remove the battery and try booting from just AC power.
I have also had the same issue when my bios battery is loose or dead. The battery can be accessed from the memory area. Once you open it on the left should be memory and on the right will be the wifi card. You don't need to unplug the cables just remove the wifi card and examine the battery. The battery is held by a very very flimsy piece of platic and really easy to break. The best thing I have found is using a little piece of cardboard from a box or something and using it to keep the battery tight, just dont go shaking the laptop alot and it will hold it. It might also be possible your bios battery is dead.
From what I say I would hit power it would power for about 3 seconds the power light would flash then turn off.
Nov 01, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V5000T Notebook Logo
87 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
