Question about Philips Televison & Video
Tv will not turn on. Checked fuse is good & power goes to it.
  • 43 Answers
The problem on your tv is after the secondary power supply is a capacitor problem
Posted on Feb 20, 2012
Why won't my TV turn back on even manually??
total dead usually means the fuse---unplug the set for safety and remove back cover---follow power cord just inside and you will find the fuse in a snap in holder--check to see if bad.............if good let me know and I will try to assist you.
Apr 03, 2012 | Televison & Video
47 inch vizio blown fuse
i am having the same problem and my power light wont even turn on so i think it might be tht power fuse. Is tht what was wrong with urs?
Dec 18, 2011 | Vizio VO47LF 47" TV
Vizeo 42 hd plasma tv (model v42hdtv10a)won't turn on. I checked the fuses and found one burnt out on the upper left board (when looking from the back of the tv.) I replaced this fuse (4 amp 250v...
Hi, do you know from what area the smoke came from?
4 Amps seems a little high. Sounds like power transistors have blown, maybe even a capacitop or a main filter cap has gone short.
Sorry i can't help much, is there anywhere inside that would indicate a different manufacturer?
Board numbers, chassis numbers , i will try and help.
Regards - Anthony
Feb 08, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
The tv just turned off can't turn it back on tried everything nothing works
Checked Power cable is proper after that remove power cable & open the tv set and checked Power Supply Board.Check AC/DC fuse if its ok than replace that board.
Jan 21, 2010 | Protron PLTV-32 Television
When I power up I hear a clicking sound. Goes into stand-by mode
I am having the same problem. It happened today for the first time. This morning the TV was working, now, in the afternoon, I tried to turn it on and I get no image. I can't even access the Menu, therefore I have to stick with the HDMI connection, eventhough it would have been a good idea to try other inputs.
Dec 12, 2009 | HP PL4260N 42 in. Plasma HDTV
Buick Regal dying
You have a problem in the fuel pump relay circuit for sure then. I'm betting the relay, but it could be that dropping resistor.
May 11, 2009 | 2000 Buick Regal
Hi i have a 600 watt sony xplod amp model xm-554zr and it recently stopped working. when i turn my car on the amp turns on but only for a sec then the protection light comes on, on the amp and it wont...
sounds like maybe a speaker short, try unhooking your speakers and then powering up your amp, if it then powers up with the speakers unhooked try hooking up each speaker one by one untill the amp goes back into protection and then you have your bad speaker.
Mar 08, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
No Power to my TV after power outage
A lot of times its simply a fuse that goes out. Either way someone is going to have to open it up and inspect the fuses first. It 's a fairly inexpensive service call.
Hopefully the fuse took the hit from the storm.
Jun 04, 2008 | Televison & Video
Rockford Fosgate Power T20001bd goes into protect upon power up.
In most of Rockford's amps, the low voltage detection is connected to the remote input. If the remote voltage is too low and they use the same circuit on this amp, it could trigger the protection circuit.
Disconnect the head unit's remote from the amp. Use a fuse holder with a 3 amp fuse to jump between the B+ connection and the remote terminal of the amp. If the amp powers up, the head unit's remote output may be defective. If it blows the fuse, the remote input or part of the power supply is damaged. Do not try it with an unfused jumper.
Oct 21, 2007 | Rockford Fosgate T20001 bd Car Audio...
Televison & Video Logo
19 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
