Refrigerator has no power to start relay of capacitor
I replaced the start relay and then realized there was no power to the start relay and no power to the capacitor. I do have power to the fan and it is running
  • hughftmalone
    hughftmalone Feb 20, 2012
    wrong category sorry
  • hughftmalone
    Thanks for hte respond.. Would the secondary power supply be made up of components on the main control board.. looking at the schematic it shows AC lines going directly to the run cap starter relay and overload components around the compressor.
  • 43 Answers
If you have no power to the relay you are missing the stand by power , you need to check voltage from the secondary power supply , you need to have 12vdc at the relay
Posted on Feb 20, 2012
Starting capacitor failed. Replaced it and found new capacitor getting very hot. Does anybody know if this is a capacitor start or permanent split cap electric motor? No easy way to open the motor case to...
hi, more than likely a psc motor on a `small pressure washer.
The usual problems with the capacitors failing is down to a poor power supply, wether it be using a long extension lead of too small a size, or the power supply itself.
check voltage to machine while using it, a voltage drop will cause characteristics of motor to change, phase angles etc..
A refrigerator starting relay would not have the required amperage ratings for a pressure washer..
hope this helps , andy
Oct 12, 2013 | FAIP 1500 PSI Electric Power Washer
Compressor will not start on a frigidaire refridgerator
The compressor gets power from compressor capacitor or compressor relay.On some models there is capacitor and on some there is relay.May be that relay or capacitor got shorted causing the problem.
But if that checks out ok,then its faulty compressor causing these.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 24, 2012 | Refrigerators
I have an Amana refrigerator model abb2224dew. The compressor becomes very hot and will not startup. The start relay/capacitor is making a buzzing/clicking noise every few minutes but the compressor will...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 06, 2011 | Refrigerators
The maytag skybox doesn't get cold anymore. we had it outside for a while (we didn't realize you couldn't have it outside) & it worked great all last summer. this spring, we realized it...
First you need to find out if the compressor is kicking on or not. If it isn't then it could be the starting capacitor (item 23), start relay (item 7) or the compressor itself. Since you had it outside I would suspect the capacitor or relay. http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Refrigerator-Parts/Model-MBV1976AAB/3048/0168000/M0510224/00001
Does the skybox make noise (like your refrigerator starting a cycle)? If not, I would unplug it for a short while and let it set. Then when you plug it back up listen for noises on whether the compressor kicks on or not. If it doesn't then you can check the cap and relay board. Or have your compressor checked for operation and freon.
Jun 21, 2011 | Maytag SkyBox MBV1976A Beverage Dispenser
My ref. is only 4 months old and I just realized that the bottom freezer is not freezing and the icecream is maelted. The door wasn;t open. Help!!! Heidi
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Sep 09, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
My haier beer dispenser model HBF05EBSS will not turn on. Compressor is hot and keeps clicking on and off. How can I fix
Try to change the capacitor and start relay first...then maybe if that don't work the compressor...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Refrigerator Troubleshooting Refrigerator Compressor
heatman101
Aug 31, 2010 | Haier (HBF05EAVS) Beverage Dispenser
I just replaced the start relay (start device) on our KitchenAid side by side refrigerator. The new relay I received was exactly like the original except it did not come with the plug in capacitor. I...
Leave the capacitor on and don't worry about the cover. The capacitor really helps the compressor to not use as much electricity, thus saving energy.
Jan 06, 2010 | KitchenAid Refrigerators
Capacitor for a refrigerator
A capacitor gives the compressor extra starting power (or running power) to pump refrigerant thru the system .It can work without one but most overload/relays can accept the existing capacitor . Some compressors say on a sticker " Do not use without starting device".My advise would be to use the existing capacitor but wire it correctly with the overload/relay .
Jul 06, 2009 | Refrigerators
We can't replace the capacitor because the value is erase. i don't know the right value.. And is there an specific starting relay to use? Or is there any compatible capacitor and relay for it?
The capacitor would need to be checke when not connected to power. There may be another reason for the capacitor and relay heating. For example the motor winding are breaking down or the wiring to the compressor is incorrect. below is a photo of where to locate the model number of your refrigerator. I will help you if you like, Thanks, Sea Breeze
May 27, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
