Question about Singer Electronic Steam Press
Where would i get an instruction manual for a **** steam press GP2001
Singer magic steam press 7
singer magic 7 is used carefully as it is closely to iron so check if wires are connected correctly
Jan 22, 2014 | Singer Electronic Steam Press Iron
The water that is spitting out when I press the steam button is clear and boiling hot. A LOT of water comes out.
Check to see the amount of water the iron requires. If too much is added it will spit water out can also come out of where the water goes in plus the holes the steam should come out. In order for the iron to steam the water must boil inside the iron. Check the instructions and see how mmuch the manufacturer suggests. You may have to fill it several times while doing the ironing. If there is no instruction try consulting the manufacturers web site for information on your make and model of iron. They should have instruction manuals available for download. If that is not the problem it could be cracked on the inside. Give the water adjustment a try first though a lot cheaper in the long run.
Aug 06, 2012 | Irons
Can I get instructions on how to use Steam Press SF680 please?
You can download the complete instruction manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Apr 08, 2010 | Hamilton Beach Steam Excel 14770 Iron
English Instruction Manal for Tevion DBS2400 Steam Generator Iron
Hi. I am looking for an English Instruction Manual for Tevion DBS2400 Steam Generator Iron. Can anyone help please. Thanks very much Regards
Mar 21, 2010 | Irons
My tefal aqua is not taking out creases but i can see steam coming out of the iron I have tried the instructions according to the manual for cleaning but still no good please help
Some creases cannot be removed with any steam iron.
Dampen the area with the creases or place a wet press cloth over the area and try again.
Feb 20, 2010 | Tefal Aquaspeed 170 Iron
Need manual for swan steam generater iron model s15040
you have probably solved this by now but
I just got the same model new
switch on instructions as follows
press and HOLD the POWER button for 3 seconds to switch the unit on
once temperature has been reached, press and HOLD the steam button on top of the iron for up to 20 seconds
this will prime the steam pump and only has to be done once for each ironing session
the pump noise will stop once it has been primed with water
hope this helps if still needed
if you need the user guide, let me know, I'll scan it for you
Wendy
Jun 29, 2009 | Black & Decker Steam Generator SG200 Iron
Lost intruction manual Magic Steam Press csp-1
Follow the link or copy it to your browser - http://www.singerco.com/accessories/manuals.html - and search for your Singer.
Kind regards Ryno
Jun 20, 2009 | Singer CSP1 Iron
ProSteam Plus 34'' Steam Press with Steam Burst - Lost Manual
Prosteam Plus 34 steam press- the cloth has wornout. where can i buy. QVC has no contact details
Jan 26, 2009 | Irons
My husband threw away the opereating instructions for our iron.
SELF CLEANINGIt is important to “Self Clean” the iron at least every two weeksto remove scale, calcium, etc. The harder the water, the more often the iron should be self cleaned.1. Set the variable steam control dial to any steam position.2. Fill the water tank up to the “MAX” level.3. Stand the iron on its heel. Plug the iron into the electrical outlet.4.Press the electronic temperature control button until you get the “MAX” temperature setting on the display panel and wait until the iron heats up and temperature setting light stops flashing.5. Turn the variable steam control dial all the way to the right to the self-cleaning position and hold the iron horizontally over the sink (Fig. 8).6. Boiling water and steam will now be ejected from the holes in the soleplate. The impurities and scale are washed away with it. 7. Move the iron back and forth as this happens.8. If there is any water left in the water tank after the iron stops steaming, just empty the remaining water in a sink following the instructions for emptying the iron. 9.Turn the variable steam control dial to the “0” position when the water tank is empty.10.Place the iron back upright on its heel to cool down before storing.
Nov 23, 2008 | Euro-Pro Shark GI490 Iron
Singer Electronic Steam Press Logo
42 people viewed this question
Top Singer Irons Experts
russ davis
ray gallant
L Pfaff
L Pfaff
Are you a Singer Iron Expert? Answer questions, earn points and help others
