Error code AO1
Error message A01 means -Acqua stop operated due to a leak or overfill. Check if there is still water in the machine after it stop pumping. In case you still have water - your problem is with the pump or with a blockage drain line.
If there is no water in the machin, it might be a water level sensor issue - stuck physically in the high level position or become defective.
Try to reduced the water presure and leveled it up by the water entrance tap to the machine, it might solve your problem.
Goog luck !!
