Question about Cps Products (CPSCC220) Compact High Capacity Charging Scale CC220
Not showing any display unless i bend out the display screen and for a split second and it has new batteries
What do i need to check and can i do it with an ohm meter
Hi i just replace a new lamp for my panasonic but the message on the screen still show u need the reset the lamp hour meter ! please show me how to reset the lamp hour meter
Be sure the power cord is plugged into a properly grounded wall outlet. Then, press the POWER button on the projection display or the remote control to turn the unit on.
While pressing the VOL- button on the projection display, hold down the PIP or SPLIT button on the remote control at same time for more than 5 seconds.
When reset procedure is complete, the screen will indicate that the lamp has been reset!
NOTE: When lamp time reset is finished, the LAMP indicator goes out!
Tom Miller
Broadcast Eng
Mar 04, 2011 | Panasonic Televison & Video
Night vision monocular, 2x42, mariner 1st generation waterproof and floats,developed a bright point near the centre of viewer after switching on,still on 1st battery,tried new battery but no...
it has a physical damage and its a serious problem. unscrew the housing and observe the damage area or lost connection. unless replace the display unit.
Dec 17, 2010 | Bushnell Optics
My Dell Demension E310 has a battery showing on the motherboard and also my screen will not stay on. Does this mean the Cell battery needs replacement or what. For a while I was able to keep shutting off...
Sounds like your power supply is gone.
A local shop can easily test, generally for free if you buy a new one from them. I'm not talking big box stores.
Aug 14, 2010 | Dell Dimension E310 PC Desktop
Fan works but compressor does not start. Its a brand new unit
Hi!!
By fan woks you mean inside unit right? assuming so, check remote control settings and battery, set temp.to 70 degrees, a light should come on at the display and seconds later, the compressor should kick in. If Unit is brand new, it should be it. If split units, try another remote, some times those remotes show the display but do not send signal strong enough that the unit can receive it. Try getting closer to the unit.
Keep me posted! Rate this post!!
Aug 14, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
My lg laptop screen seems to be split in 2 almost. It only shows three quarters of the screen and at the bottom the screen starts again
Try to turn off the pc and remove the cables and battery on the laptop. Press and hold the power button for 5 seconds, then reinsert the battery and the cables on the pc. Turn on your laptop and check if the screen will finally splits sucessfully...
May 15, 2010 | Computers & Internet
My Soehnle scale shows an out2 error - how do I fix?
How to calibrate when "out2" is shown.
With the power off andthe scale on a stable surface, hold "g" and press "on". Some number will show up, probably a negative number. Press the "on" button again and the scale should display "Zero". Wait until it says "200.0". Gently place a 200 gram weight on the scale and wait a few seconds. If your successful it will say "Pass" and your scale will work again, yay!
May 14, 2010 | Salter 2001 electronic kitchen scale
Display in thermostat not showing
Please check the thermostat display connections. If it
doesn't improve, we have no other option but to replace
it. Thermostat Display always have a clear display unless it becomes defective. Hope this will help you.
Jan 06, 2010 | Mitsubishi MSZ09UN Air Conditioner
Indigo light is not working properly, battery needed?
Timex suggests that you have a watch repair person change your watch batteries. I think it would be a good idea to try and replace the battery, but if that fails to work, contact Timex for advice. If they suggest that you should replace the entire wath, keep the battery. I have no guarantee that any of that would work, though.
Jun 01, 2009 | Timex Watches
Pictures won't show on screen
I have checked to see if I can simulate your problem on my D70.
There are no settings on the Set-up menu to turn off the display.
The display should show for a minimum of 6 seconds after a phot is taken.
You can reduce the screen brightness but that will not turn it completely black.
I presume you have eliminated all other possibilities by changing batteries, card, lens etc..
If so, it would suggest an LCD screen failure which would necessitate a repair by a Nikon agent.
Jan 21, 2009 | Nikon D70s Digital Camera
T30 always comes up with record-ready display screen
T30 defaults to an opening display screen based on where you were when you last used the device. When leaving from the record folder and record mode, you will always open with the record-ready screen. If you left your T30 while in the music folder playing a music file, you will be returned to that.
This record-ready display screen has a numeric and bar time line. The numeric values of the line are in hrs:min:seconds. This line is also split: the right half of the line indicates the total amount of available recording time, while the left half indicates your time as you record. If you compare the values of the right and left sides of the numeric bar while you are recording, you will see that the right side is diminishing as the left side increases in numeric value. When you complete your recording and save your track, the right side will now indicate the new total time (the amount your screen first displayed LESS the time value of the track just recorded).
When you are playing a music file, if you watch the time display, you will see the numeric information changing in the same way. The left side indicates how may hrs:min:seconds your track has played while the right side indicates the total time value for that file and will be correspondingly decreasing while you play your music file.
So in the short, you don't need to worry much about your display screen unless you open in the wrong folder or you need more recording time than is available. Then it has a message for you.
Nov 06, 2008 | iRiver T30 MP3 Player
Cps Products (CPSCC220) Compact High Capacity Charging Scale CC220 Logo
43 people viewed this question
Top Cps Products Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Cps Products Measuring Tool and Sensor Expert? Answer questions, earn points and help others
