Question about Del-Rain 1500-V 1500 Watt Ceramic Heater
Heater has been working great for a few years. Now when I turn it on all the red lights flash and nothing else happens. Is there any hope?
Filter is clean and the fan turns easily by hand.
  • Marshallmam Feb 22, 2012
    Solved it myself with a little help, There is a small metal ball that tells the heater when it gets turned over. Sometimes the little ball gets stuck. Gave it a good shaking or what ever, what have you got to lose? and it worked!
    The customer service number on the bottom of this sweet thing is a joke.
Why doesn't the fan on our comfort zone heater turn on when I turn on the power?
You need too hit the temp button increase temp then hit enter or set
Dec 01, 2014 | Comfort Zone Heating & Cooling
Light on but nothing happens
Sound like the diodes stuffed FOR THE MAIN UNIT.
I'd be taking back to the supplier/ STORE
Apr 30, 2012 | DeLonghi BC0261 Espresso & Coffee Maker
Hi i have an isis tv and have lost the manual to it. I can not get the tv to switch on, every time i turn the power on and try and use the remote to turn it on nothing happens and the led red light on the...
Hi can anyone please help me a have a isis tv only a year old was working fine last night aye want to put it on tonight and the red light flashes for a bit than comes on but no sound or picture what could it be the scream is just dark
Sep 13, 2011 | Televison & Video
Zanussi zwf 1430s,power going to machine but when button pressed green light does not come on just a red light nothing on display panel
Count how many times the red light flashes and how many the green light flashes.If its 1 green and 1 red thats water problems.If 2 flashes of red light check filter is clear and pump is free to turn.
Hope this helped.
May 18, 2010 | Washing Machines
Ihave a rca 27v414t. the problem is it won't turn
Any malfunction associated with a flashing light usually indicates a circuit problem or defective component. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Sep 13, 2009 | Televison & Video
LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
Jan 28, 2009 | Televison & Video
Filter light still on "Red"
try holding ice type and child lock together for 3 seconds that worked on mine
Mar 30, 2007 | Maytag MSD2454G Side by Side Refrigerator
Oil filled Heater will not turn on and heat.
First thing make sure: · Ensure that your circuit breaker or fuse is working properly. · Be sure the heater is plugged in and that the electrical outlet is working properly. · Check for any obstruction. If you find any obstruction, turn the heater ?OFF?. Unplug the heater and wait a few minutes for it to cool down. Carefully remove the obstruction. Plug the heater in and turn it on again by referring to the OPERATING INSTRUCTIONS. Second, If you're NOT still under warranty you should at least open the heater and look for anything strange like a blown fuse. A lot of times you can buy replacement at a local electronic or hardware store and they're easy to replace.
Dec 03, 2005 | WeatherWorks CH3001 Oil Filled Radiator...
Del-Rain 1500-V 1500 Watt Ceramic Heater Logo
57 people viewed this question
Top Del-Rain Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Del-Rain Heating and Cooling Expert? Answer questions, earn points and help others
