Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
Oil shooting out of cap - Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
  • Craftsman Master
  • 885 Answers
Two probably causes are:
1. Too much oil in the crank case. Compressors don't have a lot of oil in them and the oil level must be at the full mark on the dip stick or sight glass. Over filling it will make the motor work harder and some oil will get forced out the vent cap.
2. You may have compressed air going into the crankcase causing oil to get blown out the vent cap. This occurs if compressed air is getting past the piston, either through a hole in the piston or past the rings because either the rings or cylinder are damaged.
Posted on Feb 21, 2012
V6 ENGINE LOSING OIL THROUGH FILLER CAP
The obvious answer would be to replace the filler cap. But I would look int why so much pressure is building under the valve cover. A Chilton/Haynes manual should give you some answers under the trouble-shooting heading.
Sep 23, 2014 | Cars & Trucks
Excessive oil pressure
Too much oil in the tank, the oil level on dipstick must be between the two mark.
Apr 05, 2014 | 2001 Harley Davidson FLSTF - FLSTFI Fat...
What will cause a blow back
there will be,if it shoots the cap off while you are unscrewing it then you might have an issue,but oil will come out with car running and cap off
Nov 13, 2012 | 1991 Toyota Camry
The fan motor is noisy. How can i fix it?
what you can try to do is turn power off and then pull out the slide out unit check the motor for any tiny yello or black slip caps if you have them pull them out shoot wd in them just a small amount and then oil it with 3 n ! oil or just drpos of car oil works fine
Apr 08, 2010 | Friedrich QuietMaster Deluxe RS12L10 Air...
Left side rollers are releasing excess oil.. getting oil shooting out onto carpet.
On that left side end cap has a liquid wax hose assembly with nozzle on/off switch, this is used to refill the wax bladder underneath the running deck for lubricating the running belt itself. their are 2 screws that hold the end cap you will see the nozzle make sure its turned off make sure hose connections are snug. If any cracks in hose replace accordingly.
Mar 17, 2010 | Life Fitness 9500HR Next Generation...
22re motor 88 toyota pickup
this vehicle is only fit for the scrapyard unless you are prepared to spend lots of cash on a engine rebuild
Jan 25, 2010 | 1988 Toyota Pickup
No spark when trying to start my 1992 Toyota Celica GT. The engine died while I was driving. It will crank over but won't start.
Remove the distributor cap and see if you see a rust colored dust inside. If so, the the distributor is bad and needs to be replaced. The igniter in the distributor is not working properly
Jul 24, 2009 | 1992 Toyota Celica
I have a 1.5 hp 3 gallon craftsman air compressor. When I turn it on, oil shoots out of the vents in the oil cap? Why is this? How can I fix it?
hi mate it is probably due to too much oil and when it starts the oil inside is splashed out the oil cap i reccomend start the compressor and let it run for 2 mins to get the oil warm take the plug out and drain the oil and the refill with p68 oil and on the oil sight glass refill it untill it reaches the red dot in the middle if it has one or on the dip stick it has a measurement good luck
Jul 07, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
High presser in tappit cover volvo 84 gl
Check your PCV valve. Its the device that provides ventilation to the crankcase and valve covers. If its clogged or non functional it will cause the engine to **** or blow air from an area with less resistance, which is probably the filler cap. As its blowing air out of the engine it will shoot a little bit of oil with it
Aug 17, 2008 | 1984 Volvo 240 Series
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
258 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
