Question about Sewing Machines
The stitches from my toyota sp20 start at the correct size but within a few inches they start to decrease in size and end up tiny
  • Sewing Machines Master
  • 7,365 Answers
Sounds like something is wrong with the gear & needs to be serviced
Posted on Feb 21, 2012
4 Suggested Answers
  • 13433 Answers
SOURCE: Singer 7462 buttonholer
try adjusting the size, see if it changes the result and go from there, you might also want to ask other experts, sewing machines are not my speciality.
Posted on Sep 28, 2008
SOURCE: Buttonholer will not stitch correctly. Lever won't signal the foot to go backward
no working
Posted on Sep 29, 2008
  • 192 Answers
SOURCE: inconsistant stitches
Take it in to your dealer where you purchased and describe symptom. You may need to have the feed mechanism replaced. It will all be under warranty through your dealer.
If the machine is very new, less than 2 months or so, ask if they can still replace through sales rep. Husqvarna Viking guarantees proper operation of the machine for the first 15 hours of operation, or "run" time. That way if something wasn't assembled properly in the factory, you don't wait for repair/adjustments. A very small number of machines have had problems with a joint in the feed mechanism.
Your dealer can take care of that issue for you. That's what we're here for and why you continue to buy your machines from us.
Posted on Nov 17, 2011
What size needles for bulky/12py wool?
It depends on your project. You need the size needle that will give you the stitch width and stitch length called for in the pattern. The pattern calls for a specific gauge, so you'll need to try out different needles, knitting a swatch on each needle size, and counting the number of stitches across and down to match the pattern specification. Does the pattern not give you a needle size? Needles come in either straight or circular in all various sizes as long as you stay within the same brand needle. (Needle brands differ from one to another, so try to stay within only one brand.) So a straight needle size 6 should be the same size as a circular needle size 6 (of the same brand).
However, although it may call for a specific size needle, you will still need to knit some test swatches because knitters usually knit looser or tighter, so one needs to adjust the needle size to accommodate those differences, ie someone who knits tightly may get 8 stitches to an inch, but a loose knitter may get only 6 stitches. But if the pattern says to cast on 48 stitches in for row 1, that means the 8 stitch gauge will yield a project that measures 6 inches wide (48/8=6). But a 6 stitch gauge will yield a project of 8 inches wide (48/6=8). The result would be one project will be 2 inches wider than the other.
But that is only half of the problem as you would still need to measure the number of rows per inch to get the length of the project. If there are more rows to the inch than specified, a garment with say an armhole that may be too small. If there are fewer rows to an inch, the result may be an armhole that is way to big.
Be very careful with your pattern and yarn selection. You will be much more successful if you stick to the number ply and yarn weight specified in the pattern, ie if the pattern calls for 2-ply 2 oz yarn, there may be some particularly difficult issues with substituting a 4-ply 4 oz. yarn. You may end up with a project that will not fit. For instance, you wouldn't want to use a heavier yarn to knit a baby garment. Baby garments usually call for baby yarn which is a specific ply and weight.
How to Measure Your Gauge in Knitting
earthguild com
3 Things You Might Not Know About Knitting Gauge Adjustment
Oct 30, 2016 | Sewing Machines
Machine does not appear to have a button to sew in reverse
try these suggestions
Reduce the stitch length to zero. The machine will stitch in place and form a locked stitch
1) rotate the material and sew over the same stitching. Leave the needle down in the work and raise the presser foot, then turn the fabric around.
2) decrease the stitch length to very small for a few stitches
OR
3) hold the fabric and prevent it from feeding at the beginning and end of a seam, which makes very short stitches
4) stitch about 1/2", raise the needle and presser foot, return the fabric to the beginning position and stitch over the first half inch of seam again. Do the same at the end
Jun 17, 2015 | Euro-Pro Sewing Machines
How do I make a large buttonhole ..( 1 3/8 inch).. the button doesnt fit on the buttonholer.
You do it using narrow rows of side by side zig zag stitches and bar tacking the ends of the rows. Make a line where you want the hole to be. Set the zig zag stitch width very narrow, whatever is closest to what suits the fabric. Coarse or loose weaves need a wider width, finer ones a narrower width. Experiment on some scraps to get it right. Number of stitches per inch, or stitch length, should be very fine, at least 20 per inch, but not 0. Try a few more experiments on scraps to make sure it looks right. Make a test hole to be sure it is the right size for your buttons.
Stitch a straight line of zig zags down one side of your line, with the edge of the stitching not quite touching your line. Stitch a second row directly on top of the first one.
Repeat on the other side of the line. Ideally you should still be able to just see the line you drew when the rows are done, but not see any bare fabric on either side of the line.
Then move to one end of your rows. Leave the stitch length the same, but change the width to match the width of your two side by side rows. Stitch a bar tack, about the same length as your two rows are wide. If your two rows are 1/8 inch wide, your bar tack should be 1/8 inch long. Do the same at the other end. Make sure the bar tack covers the very end stitches in the rows as it is the anchor that will prevent unravelling. This is exactly what machine buttonhole makers do, but they do it all for you.
Carefully slit between the rows to open the hole. I like to put a drop of Fray Check or something similar on my buttonholes after I cut them open. It makes them much stronger and they will never come out.
Oct 09, 2014 | Sewing Machines
The lower stitching on my machine is not consistant, why?
Wrong size needle or wrong type of thread for the weight or type of fabric. For instance, you should use smaller needle size for light weight fabrics.
Jan 15, 2013 | Sewing Machines
My Juki MO-655 serger will sew a few inches then the needle thread becomes disengaged in the stitch process. The machine will sew a few inches more then stops making stitches. I have cleaned the thre
Make sure you are threading the machine correctly. Make sure you are using serger thread that isn't old. Make sure you are undoing all the threads when it breaks and thread it from the beginning.
Make sure you have the right needles in their respective places. My Juki MO has two different size needles.
Sep 02, 2012 | Juki MO-655 Mechanical Sewing Machine
My bobbin stitch is loose. I have tried adjusting tension and have changed the needle.
A. To correct loose stitches, try the following: (1) Balance the thread tension. If the stitches are loose on top of the fabric, decrease the tension to the next lower number. If they are loose on the underside set the tension to the next higher number. (2) Make sure the needle/upper thread follows the threading path. (3) Check to see that the bobbin case is threaded properly. (4) Use a different size needle. For fine fabrics, use a smaller needle (size 9, 11); medium-weight fabrics require a size 14 or 16. And use a size 18 or "Denim" needle for heavy corduroy or denim.
Sep 20, 2010 | Singer Curvy 8770 Electronic Sewing...
My Memory Craft sews great until I start to quilt or use one of the different stitches and then the stitches either skip or become so tiney I can't pick them out.
Skipping could indicate you need to use a larger size needle.
Tiny stitches could be save reason, or the top thread is hanging up.
Sometimes the thread can wrap around the spool pin or catch on a rough surface on the end of the spool.
Be sure to use the correct size spool cap and if the thread is wrapping around the pin, a thread net can help.
Give the machine a cleaning according to the maintenance section of the manual for your machine, including cleaning the feed dogs, bobbin case, shuttle and surrounding area.
Make sure the feed dogs are up unless you are free motion quilting and the presser foot down.
This may seem elementary.........just trying to cover all the bases.
May 02, 2010 | Janome Memory Craft 9000 Computerized...
Pfaff varimatic 6091 sew a rag quilt with jean and flannel,I can't get my tension right it seems to be funny on the bottom stitch,where shoulf the top tension be set at 4 1/2 ,when do I adjust the bobbin...
Hi! The bobbin tension rarely needs to be adjusted. First, make sure you're using the appropriate size needle and thread for your fabric (I'd probably use either a 'denim' needle or a universal size 14) and also that the upper thread and bobbin are threaded absolutely correctly. These can throw off the tension! Also, take the time to clean out the bobbin area. That can throw your stitch off also.
If the stitch on the bottom is loose, so that you see the top threads, then the top tension is too loose. If the top stitch is too loose and you see the bobbin threads on top, then the top tension is too tight.
It helps to thread the machine with different color thread on top and in the bobbin, and then stitch an inch or so on the same type of fabric as you're using in your quilt. Check the stitch. If you need to adjust the top tension, make sure the pressure foot is down! Adjust a little, stitch a few inches, and check again. Repeat until you don't see any (or very little) bobbin thread on the top or top thread on the bottom.
If you go through all these steps, and the bobbin thread is still loose (and you've tightened up the top tension), then there is a tiny little screw on the side of the bobbin case that you can use to adjust the bobbin tension. Turn the screw just a little bit (less than a quarter turn), stitch, check, etc. Once the bobbin tension is set, you shouldn't ever have to change it.
Let me know if this helps, ok?
Happy sewing!
Feb 10, 2010 | PfaFF Sewing Machines
Sewing Machines Logo
48 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
