Question about Fuji J38 Digital Camera
Fuji j38 won't turn on.
Camera will only turn on after a while connected to electrical outlet power.
4 Suggested Answers
  • 11967 Answers
SOURCE: Fuji j38 zoom error
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 23, 2010
lock123
  • 6831 Answers
SOURCE: zoom error on a fuji finepx j38 digital cameraa
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Sep 07, 2010
  • 102366 Answers
SOURCE: i cant download my images
You don't need any special software. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program, such as iPhoto and Windows Photo Gallery.
Posted on Oct 31, 2011
How do I get the date and time stamp to print on my pictures from a Fuji j38?????
Try to use the following software TimeToPhoto to add dates from EXIF to photos automatically:
http://avpsoft.com/products/timetophoto/
Regards
Feb 15, 2013 | Fuji FinePix Z10fd Digital Camera
My fuji finepix s5000 has lost power
see this causes and proceed . God bless you
If the camera won't turn on, check the batteries, or connect the camera to an AC adapter. If that doesn't work, remove all batteries, disconnect the AC adapter, wait a minute, reinsert batteries and reconnect the adapter.
If the flash doesn't work, the camera won't take pictures, or the screen keeps turning off, check that the batteries are strong.
Oct 16, 2012 | Fuji FinePix S5000 Digital Camera
I have put new batteries in my FinePix A360 camera but it doesn't seem to power on.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Nov 10, 2011 | Fuji FinePix A360 Digital Camera
I cant download my images to the computer. ive lost my disc Fuji pinepix 12.2 j38
Jul 29, 2011 | Fuji FinePix S304 Digital Camera
My camera won't turn on and the lens won't close
Perhaps you have bad batteries? Connect it to another power source such as an AC wall outlet and use your power adapter and see if this helps. If it does not or you have already tried this then your camera may need to be serviced.
Jun 29, 2011 | Kodak Cameras
I have a digital camera model #fine pix j38 no.9UD36889 i'm having a problem deletting pictures. can you help with directions. thanks maria..PS LOST MY MANUAL WHERE CAN I GET A FREE MANUAL
Hi, If deleting from the camera isn't working you should be able to connect it to a computer and delete the photo's off the camera from the computer. Also here is the manual for free online: http://www.fujifilmusa.com/shared/bin/finepix_j38_manual_01.pdf
May 12, 2011 | Fuji Cameras
I turned on my camera fujifilm j38 and it said "protected card" how do i fix it?
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jan 09, 2011 | Fuji J38 Digital Camera
Everytime I turn my fujifilm finepix j38 on it says protected card. I can't take pictures erase pictures....nothing. How can I fix this problem?
Your camera uses an SD type card so on the upper left side there is a white sliding switch make sure this switch is pushed forward to the top (towards the gold contacts) to put it in the unlock position.
Dec 23, 2010 | Fuji J38 Digital Camera
Camera will work while in outlet but once removed wil not?
This sounds more like the battery is dead and won't hold a charge rather than the resetting it, trying to charge it or the card.
The fact that you have said that it works when plugged into the mains power is an indication that its the battery which is at fault here and nothing else.
Regards.
Jul 19, 2010 | Fuji Cameras
Fujifilm finepix j38 series reads zoom error and wont take a pic.
If you have some skills, you can open the camera and cline your zoom lens with toothbrush and compressed air. Try to separate zoom lens from the electric motor. usually is 2 or 3 screws. You will see a lot of sand inside the camera and lens. And next time when you will go to the beach, you will take more care about your camera.
Solution 2, and more easy is to buy another zoom lens from ebay.Or another camera same model with broken LCD or other technical problem than zoom lens.
May 31, 2010 | Fuji Cameras
Fuji J38 Digital Camera Logo
19 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
